Test/review of Molicel INR21700-P42A 4200mAh (Gray)
26 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 19 min ago
DSC_5264
Official specifications:
  • Rated typical capacity: 4200mAh
  • Rated minimum capacity: 4000mAh
  • Nominal voltage: 3.6V
  • Standard charge current: 4.2A
  • Maximum charge current: 8.4A
  • End of charge voltage: 4.20V +/-0.05V
  • Continuous discharge current: 45A (Cycle life is reduced at high rates)
  • End of discharge voltage: 2.5V
  • Typical impedance:
  • Cycle life: 500 cycles at 4.2A charge and 10A discharge for 80%
  • Operating temperature: Charging: -20°C ~ 60°C, Discharging: -40°C ~ 60°C
  • Storage temperature:
Molicel%20INR21700-P42A%204200mAh%20(Gray)-info
This is a 21700 high current cell with good capacity.
DSC_5263
DSC_5265 DSC_5266
DSC_5267
DSC_5268
Molicel%20INR21700-P42A%204200mAh%20(Gray)-Capacity
The two cells match just about perfect and capacity do not really change with load.
Molicel%20INR21700-P42A%204200mAh%20(Gray)-Temp-20.0
Molicel%20INR21700-P42A%204200mAh%20(Gray)-Temp-30.0
I forgot the temperature sensor with the first battery.
Molicel%20INR21700-P42A%204200mAh%20(Gray)-CapacityTimeHours
Molicel%20INR21700-P42A%204200mAh%20(Gray)-Energy
Molicel%20INR21700-P42A%204200mAh%20(Gray)-PowerLoadTime
Molicel%20INR21700-P42A%204200mAh%20(Gray)-TripCurrent
Molicel%20INR21700-P42A%204200mAh%20(Gray)-Charge
Conclusion
This is good high current cells.
Notes and links
The batteries was supplied by N-Power Energy for review.
Graphical comparison to 18650 and other batteries
Graphical comparison to 26650 and other batteries
Table with all tested LiIon batteries
Edited by: HKJ on 02/22/2019 - 11:50
Agro
Agro's picture
Last seen: 5 hours 11 min ago
Beats 40T except for the very first moment. Really, really good cell. Smile
BTW, you have a typo in a link, 16650 instead of 26650.
HKJ
HKJ's picture
Thanks, it is fixed now.
Superstocker
Superstocker's picture
Last seen: 4 hours 53 min ago
I’ve been using your reviews for a long time. Thank you for all your work. Great test and very helpful.
HKJ
HKJ's picture
I hope a lot of people can get something useful out of my reviews.
DavidEF
DavidEF's picture
Last seen: 3 min 4 sec ago
Yeah, I just looked at the Comparator. The 40T is the only one that comes close, and it is very close, but this Molicel beats it except right at the beginning, like you said.
Li-Ion Wholesale has these Molicel’s and they claim to be the “Exclusive Distributor” in the USA. Their price is $12.99 Volume discounts are available if buying more than 4 cells.
- The YKK Philosophy
wolfdog1226
wolfdog1226's picture
Last seen: 4 months 1 week ago
Yes,,,my hometown dealer is the ONLY authorized USA Distributor of this cell and the other Two[20700/18650-P26A] Molicel flavors that it sells! Thumbs Up
I have the 18650P26A cells in my TN42vn 90,,,,,,,,,,they are also GREAT cells!
https://liionwholesale.com/collections/batteries/molicel-npe
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
SKV89
Last seen: 23 min 8 sec ago
Wow these Molicels are real impressive. Beats the 40T especially in the lower currents below 7A, which is the majority of the use cases. 21700 performance is really progressing fast.
klrman
klrman's picture
Last seen: 17 hours 18 min ago
Never heard of Molicel before.  Wonder if they go through the rigorous testing of samsung batteries before coming on the market. They also cost a few dollars more and since Liion sells them, not worth their shipping cost to Canada.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 16 hours 6 min ago
Thanks for the review HKJ. The name of the company makes me LOL.
vapcell Dennis
vapcell Dennis's picture
Last seen: 9 hours 7 min ago
Great molicel P42A ,Thanks HKJ Thumbs Up
vapcell Dennis
Hey @HKJ,are you not doing constant current discharge tests for more than 30A now because the battery holder burned down?
Some high drain batteries, such as 30T, 20s, we would like to see 35A or even 40A tests.
If this is the reason, I think it can be solved.. Blushing
HKJ
HKJ's picture
There are two reasons for the 30A limit:
1) My clamps has a tendency to melt.
2) More work, my standard automatic test station only goes to 30A, for higher current I have to move to my main work/test station that has 4 30A load I can use in parallel (My software support this and I have used it for some tests).
It is very few batteries that really need to be tested above 30A.
vapcell Dennis
Thank you very much for your reply.
It’s just my personal need. Maybe the same fans want to get more current data.
Take the molicel P42A specification as an example. The maximum discharge here is 45A. I hope to see the discharge data of 45A. Their batteries are also used in many high-end areas and are trustworthy.
Some batteries are overloaded and still discharge to a good capacity, but some batteries have a rapid voltage drop, such as the 14500, 18350, 16340 batteries you tested, which is very common.
It’s just my personal advice. I’m very supportive of your work.
Thank you again for your hard work Smile
shadockan
shadockan's picture
Last seen: 2 days 3 min ago
You may have never met them, but we have known them for years.
The E-One Moli is one of the leading companies in the Li-Ion battery.
I once read somewhere that it is one of N.A.S.A’s suppliers.
In general, the quality of Moli is equivalent to well-known companies
Panasonic (Sanyo)
Murata (Sony Energy)
Samsung SDI (SDIEM)
LG Chem.
If I remember well those who built the MNKE, they were E-One Moli employees and their batteries wanted to be of comparable performance and quality.
Now MNKE belongs to IMREN …… and of course ….. was lost ….
So do not worry about Moli …
They are similar to the batteries of major manufacturers.
vapcell Dennis
Panasonic (Sanyo)
Samsung SDI (SDIEM)
LG Chem.
Where did you get the information? I’m curious Shocked
shadockan
shadockan's picture
Panasonic (Sanyo)
Samsung SDI (SDIEM)
LG Chem.
The truth is that I do not remember where I read it …..
Unfortunately …..
I think I had read it here, but I’m not sure.
On a personal level, I would like it to be untrue … and MNKE will continue to be on the market ……
vapcell Dennis
Panasonic (Sanyo)
Samsung SDI (SDIEM)
LG Chem.
Unfortunately …..
Ok, Thanks。 I have news here that mnke batteries are made in Jiangsu, not in Guangdong.
Sales are now falling sharply because technology hasn’t been updated for many years.
We have vapcell 26650 4200 MAH 32A and mnke 3500 mah.
shadockan
shadockan's picture
Panasonic (Sanyo)
Samsung SDI (SDIEM)
LG Chem.
Unfortunately …..
I’m glad I learned this, Dennis .
It was the only company that had good batteries in the market a few years ago in size 26650.
One of the good companies in my opinion and it would be bad to withdraw from the market.
The last battery I had from this company was 4000mAh.
Many years before ……
I personally do not deal with this size, but it is good to have good choices in the market.
The latest 26650 batteries I came into contact with were the YDL 4200mAh (Aspire / Ijoy), the Basen 4500mAh (I do not know the manufacturer) and the PLB 5000 (Liitokala 5000A).
I can say it was good as a performance, but for the size of these batteries I personally think it’s still far behind the 18650 ….. and of course well below the 21700 …
Today I think this size does not have a future, because of 21700.
We already have 5000mAh with 10 – 15A and size 21700 is …. baby …
- The 21700 will surely surpass 26650 if the 26650 build continues with today’s data ….
vapcell Dennis
Panasonic (Sanyo)
Samsung SDI (SDIEM)
LG Chem.
Unfortunately …..
You are right,21700 battery is amzing. we also have those 26650 batteries except 26650 4500mah
HydrAxx
HydrAxx's picture
Last seen: 1 day 1 hour ago
Panasonic (Sanyo)
Samsung SDI (SDIEM)
LG Chem.
Unfortunately …..
Yes but only the specific format “26700” reaches to reach 40 continuous amps, when I say that I think about Molicel cells “IBR-26700A” (2800mAh Typical Capacaty and Max Continuous Discharge of 40A) and “IMR-26700A” (2900mAh Typical Capacity and Max Continuous Discharge of 40A), I know for cells of diameter 26mm their respective capacities are rather weak, but it was the sacrifice necessary at the time of their designs to obtain a continuous maximum discharge of 40 Amperes. There is no secret in it, you can not have both an extremely high capacity and a maximum continuous discharge extremely high too, you must choose one or the other, or create a balance / compromise between these two main features Wink
Moreover, for the record, the two models of Molicel cells mentioned above were the first to be used concretely in various cars or electric racing vehicles at the start, as well as the first Formula “E” versions, I think that their maximum continuous discharges 40 Amps played a lot in favor of their primary and major uses in these racing cars, hehe … Let’s hope that the 20700 and 21700 formats far exceed their records of pure power and time on the racing circuits used!
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
Spartan
THANK YOU, you have done a great job.
I saw all the tests and very impressed.
Moses came from the mountaintop carrying a tablet. The Words were....WITH GREAT LUMENS COMES GREAT REPONSIBILITY.
lawallac
lawallac's picture
Last seen: 1 day 3 hours ago
Unfortunate because it appears their headquarters and manufacturing is done in Maple Ridge BC, as well as in Taiwan.
shadockan
shadockan's picture
HydrAxx ….
I did not know that there is
IBR 26700 A.
I only knew about
IMR 26700 A
Thanks .
HydrAxx
HydrAxx's picture
shadockan wrote:
HydrAxx ….
IBR 26700 A.
I only knew about
IMR 26700 A
Thanks .
You’re welcome.
If you want to test the Molicel IBR26700A, there are still in stock on the site that I will give you (German site, but they deliver everywhere in Europe) but they are a bit expensive you’ll see, but it’s the only place where they are still available to my knowledge.
https://shop.lipopower.de/LiIon-Rundzelle-Molicel-IBR26700A-37V-2800mAh
shadockan
shadockan's picture
Thanks HydrAxx .
Thank you very much my friend ….
