It might not really matter, just worth a shot if nothing else is working.
I’m not sure if much will be very “drop in” worthy. I thought about designing a driver for it, but I’m not sure if it’s really worth it at the moment. The MCPCB adhesive seems to be the rubbery white stuff. I think a TIR works in the single emitter version, but not really this one. I dunno, maybe some small AAA light ones would work.
I tried a few more times, lot more force in a wood lined vise and nothing. Almost broke my best needlenose, and I got an adjustable spanner tool - bent the points on it, then sanded the off to get a better fit in the holes, got plenty of leverage and only accomplished some deep scratches off the holes. Mine seems to be sealed solidly, but it's still fine to use as-is.
Stock “20mm” TIRs sometimes actually run about 21mm. I’ve only really seen 20mm and 26mm (barring triples/quads), but someone mentioned another light that took smaller TIRs.
I wonder if boring out the bezel a coupla mm would let regular TIRs fit…
I was actually glancing at those. I think the diameter will be fine with a little sanding, but I’m concerned with the height. I’m curious to see what comes of them. Let us know (in a month or so!)
D25 is not as good for modding as D10: non standard, hard to remove led plate; non standard lenses, plastic bezel and you have to buy 2x leds and lenses instead off 1 like in D10. In my practical use D10 is getting to hot already on 1A, witch is no good , because, it overheats lithium battery! I’m pretty sure, D25 with 2 leds will overheat even faster so. D10 & D25 have cooling ribs inside battery tube
My story i bought one of these a few months ago and i ordered the 2 XML option of course more LEDs = more power lol. They sent the single LED option of course lol. So i argued with Aliexpress and i got $11 AUD back from the $20 AUD i spent probably the best $9 AUD light ever lol.
Its built well and the stock driver is on the better side for a headlamp and stock it is plenty bright for a headlamp i wanted your edition the double LED to make one side red and one normal output for fishing but oh well. Ill probably buy another i think.
Now i lost it i don’t know where and how but its gone i think my niece moved when she was playing with my lights. I am planning when or if i find it to put a new driver in it with the 3v XHP50.2. Probably need to hire Liam Neeson to find it lol.
Unscrewed mine and find out that copper ring on 17mm driver is almost broke off. I need another solution and it will be not cheap one, because there is no onesided programmable drivers on the market… there is no cheap dedicated and efficient, low current (1-1.5A), drivers for L shaped headlamps like H03 or H30
