Anyone Have Any Experience With Acebeam’s Customer Service? My UC15 Experience.
Send me a video of the issue. That might help move things along.
I’m not capable of doing that LumenMax as I’m technically challenged. :frowning: All I can say is my example is totally wonky using 10440 cells but works normally with NiMH cells.
As stated, I bought this light to use with 10440 cells and it doesn’t! I’m bummed because it doesn’t work with them as advertised!
I would be willing to ship this back to get a replacement but I still say Acebeam’s customer service is crap! Chinese New Year’s aside, they still won’t answer my emails even when C.N.Y. is now over.
Why do we here on BLF let them still advertise here when they won’t even answer several emails and others have the same problem?
Gebe,
Acebeam said to email them with your issue: info@acebeam.com or sales@acebeam.com
Thanks LM but I did many times! I’ll try it again. Thank you.
I only have two acebeam lights, but seeing they have not answered yours and my email, it's a red flag. Their lights are really expensive and since their customer service seems to be non existent, they'll be another brand I will avoid from now on. For me I will put them in the same group as HaikeLite. I have three friends that want an X80 after they saw mine but I told them they never replied to my email about a concern I had with their lights and that was it, case closed, none of them want anything to do with acebeam. All it takes is being honest with your friends and they'll look elsewhere to buy lights.
Is your concern related to the heat issue?
No. I knew it would get hot fast and that's fine, but the battery indicator light is way off. Acebeams silent treatment for so long is enough for me to understand their ethics. Don't get me wrong though, the x80 is my favorite light, I just won't be buying any more acebeam stuff that's all.
I want to thank LumenMax for his concerns in this matter. I don’t want to go into details about his help with me concerning this but he went above and beyond trying to help and had a small influence with them but to no avail.
Again, some folks here have had the same problem as me concerning nonexistent answering of emails and nonexistent customer service and again, why does BLF let them join us here when they can’t even answer an email?
Their stuff may be good IF if they work but forget about it if they don’t. NOT GOOD ACEBEAM and your company should be ashamed!
I'm thinking about putting up a youtube vid to explain Acebeams attitude. Never did it before, but I feel they deserve to get bad press this time.
I wonder if the problem isn’t the light, but rather your batteries.
What brand of 10440 are you using and where did you get them? Cheap cells might not be able maintain the current this light requires which could cause the behavior you described (inability to stay in turbo for more than a second, etc.).
Also did you buy button-top 10440 cells? If not, then your cells might be making very poor contact, which could also cause the behavior you described.
I have a UC15 that I emitter-swapped to XPL HI. Works just fine with Efest 10440 from Mountain Electronics. My 10440s were flat top. I soldered pieces of copper on their tops to convert them to button-top.
Please klrman, I wish you would! They deserve it!
Thanks for that Firelight2 but if you read through this thread, I already stated I used button top 10440’s and in fact, I used the same 10440 Efest cells you used!
It’s just crazy that a manufacturer that WON’T answer a simple email to a customer here, they SHOUDN’T be allowed to advertise here!
Sorry, but I think ACEBEAM should be banned here unless they come aboard and answer all these complaints directed to them.
I’m curious about this as well. I have a Wowtac A4 and put in some cheap Zanes 18650’s and the light wouldn’t work on turbo. It would flash on and return to low mode. Just couldn’t handle the amps required for turbo. Could be a legitimate problem. Seems like the NIMH work ok which leads me to believe that is possibly the problem. Hope things work out or have worked out.
Edit-The Effest should have worked. That is odd. Guess there are just bad lights. I got a Haikelite that was bad. Took 3 months to rectify. Good luck.
Best company I ever dealt with was Thrunite. From the four Thrunite lights that I owned, one was defective and they didn't hesitate to offer a full refund or replacement right away. Not so many companies around like that anymore.
Acebeam is on the other end of the spectrum, as they refuse to reply to even a simple question, not even a warranty claim. Talk about a company that doesn't care at all about their customers in the slightest. They do make awesome lights though overall.
Thanks for the replies! I’ve decided I’m not going to let this die until Acebeam comes aboard here and answers why they at least don’t answer emails?
Gebe. They claimed that they didn't receive your inquiry. Send your email to both info@acebeam.com and sales@acebeam.com and copy me. I'll PM you my email.
I just sent an e-mail off to sales@acebeam.com and it came back as undeliverable.
Hi, Shall we know which e-mail address you sent ? You could send us PM.
Could you please send PM ? I will check what the reason about UNDELIVERABLE.
I just sent(~30minutes ago) an email (“Just Checking”) to sales@acebeam.com and no report back on any problems from my ISP.
