Amazon Deal Alerts & Discussion Thread
Manage to snag 1 this time because I am online right now.
Limit of 1. Tried for another no dice.
it let me put 6 in my cart and get the discount on all 6
What is that Osram P9 led they talk about in that wuben deal?
You are lucky man. I could not buy anymore with code.
actually, I did not buy any with the code, I just was checking. :smiley:
Sometimes with these deals, you can create a single order of multiples and it will discount all of the items. Most of the time, you are not able to reuse the code to buy a second one on a different order.
Would this be of any interest for modders or not-particularly-picky folks who need a couple of knock-around lights?
Two 18650 C8-type lights for $12.50.
Jardlite L1100
I went that routeā€¦ ainā€™t worth the ag.
Probably get a plastic reflector, plastic front-ā€œglassā€, crappy driver, crappier LED, and by the time you replace everything to make it even halfway useful, you spent moreā€™n you couldā€™ve paid for a Convoy or Sofirn generic C8.
Been there, done that, got the teeshirt which was too small anyway.
Itā€™s hogwash or pipedream. In the manual they state Cree XP L2 for their L50
http://www.wubenlight.com/Upload/pictures/20180328/2018032818314398.pdf
YM4UZ55J code invalid. WTF
Code posted 2 dazed ago? Too dazed to go.
Yep, late to the party happens sometimes.
Yaā€™ snooze, yaā€™ looseā€¦ā€¦ :wink:
Even if I link this page to my devices, up here we get hit with extra charges to get a light from Amazon.com
I have a few Amazon.ca links for certain lights on all my devices, so I donā€™t miss them. But the first thing I do before I post it here is buy it so you Yankees wont storm the sales barricades!
/\ ā€¦ Smart moveā€¦ :+1: . :smiley:
LiFePO4 Battery: The advanced lithium iron phosphate battery is widely used in electric bus due to its safety. 2000 charge/discharge cycles and the battery life is up to 10 years.
Multi-Protection: When under-voltage, over-voltage, over-load, over-temperature and short-circuit occurs, the unit will shut down automatically to ensure safety.
Clean Power: No gasoline required. Environmentally and no acid or heavy metals inside.
A friend sent me a $60 discount code for this product in Amazon:
Code:5IBHPLEE
code start date:3/18/2019 09:00 PDT Expireļ¼š03/23/201923:59PDT
Link: https://www.amazon.com/dp/B07KPYSN3S?ref=myi_title_dp
Edited. Tks.
This very attractive power bank is rated at 166 Wh. Does that mean it could run a 150 watt - 115 V AC appliance for about one hours? A 100 Watt - 12 V DC appliance for about 1.5 hours? Thanks!
Edited again:
The conversion from 12 V DC to 110 V AC would cause about 10% power loss right?
Third edit:
Is the stated 51875 mAh capacity realistic for eight LiFePO4 batteries? That would equate to about 6400 mAh per battery.
I like that power bank as wellā€¦ Iā€™m concerned about only having an 8 month standby timeā€¦ if that is true, that is some pretty bad standby drain.
1100- 1500mAh is what I would expect for these. Times 8 is half what I get from a 20,000 power bank that can fit in a large pocket and cost >$40
https://www.amazon.com/IMALENT-Flashlight-Generation-Powerful-Searching/dp/B0751D1VBQ?ref\_=Oct_LDealsC_3180261_0&pf_rd_p=65609f00-3b65-58a1-928f-35588d26980c&pf_rd_s=merchandised-search-5&pf_rd_t=101&pf_rd_i=3180261&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=6Q6WT3ZZPGRWNV3Q54S1&pf_rd_r=6Q6WT3ZZPGRWNV3Q54S1&pf_rd_p=65609f00-3b65-58a1-928f-35588d26980c
DX80 Lightning Deal $299
Currently only two codes available.
For solar string light 50% Off
FMJH-Q9V29F-KZ4ZAY
FMCP-JKF3L7-5UNTAS
https://www.amazon.com/BOLWEO-Waterproof-Lighting-Indoorļ¼ŒOutdoorļ¼ŒWeddingļ¼ŒPatioļ¼ŒHomeļ¼ŒGarden-Decoration/dp/B07PLRXPCL
Please let me know if anyone required the products. Also make comment if codes are not working.
