FlashCut CNC if I remember correctly was one of the first “prosumer/light industrial” controls that ran off a USB port. That was actually a pretty big thing back then, maybe about 12-15 years ago?
I wouldn’t say g-code is not a “proper” programming language; it’s been around forever. I used to hand-code stuff, but unless it’s something simple I do everything in CAM. While I like the look of efficient code, it doesn’t matter anymore today because there’s no worries about system memory. Heck even Mach3 is capable of over 100 million lines of code, which even a lowly Pentium I and a parallel port could parse, no problem. I have Cut2D for simple 2.5D stuff and a child could generate toolpaths with it, yet it’s capable of doing some complicated stuff if you use enough imagination. I grew out of that however and got VCarve for its signage capabilities. Finally for full-on 3D programming I got a seat of OneCNC; and I’ve used it since XR2 Mill Advantage which is at least 10 years ago, and have upgraded over the years (I’m at XR7 Mill Expert right now.)
At my old job the FlashCut machine made a family of micro-machined parts so I wrote a pile of subroutines that calculated tool paths, feed rates and spindle speeds on the fly. I could even do constant surface speed on ball mills to compensate for the contact angle. Anyway, with the set of subroutines, I could code new parts MUCH faster than any CAM operator could by piecing together the required subroutines.
When I say “proper language”, I mean, it could handle named variables, structured programming and could do a LOT of math. Sadly, last I checked, FlashCut still hasn’t updated it at all. The only problem I had with it was that it had a memory leak so you would have to restart the control software a few times each day if you were running really complicated code.
I used one on a 50W outdoor flood light given to me with a bad druver. Works like a charm, dimmable, and I was able to work on the car at night for about 2 hours with my 3s LiPo only dropping to 3.6-3.7V according to the LVP I had connected to it.
I wonder if an aspheric zoomie COB light could be built. Maybe use one of the ~9mm LES COBs? Since it’s a COB and not something like an XHP70, it wouldn’t have that goofy square throw beam.
I was looking around on CDI’s site to see what else they have and I came across GAGGIONE. They have some 67mm TIR optics than can work with the Bridgelux 18mm COBs (~6000lm @~36w). I was thinking this might be an interesting option to make a giant quad. However, under-driven Vero29s or CXB3590s would be more efficient, I don’t know of a TIR that would approach a 67mm unit for compactness. The downside to Gaggione is that their website is a glacially slow dumpster fire and I don’t know if the entire line can actually be purchased.
Looking at datasheets and such, the MW boost drivers are actually really interesting since at only 1A output, they basically stop when the ~36v COBs hit a nice output/efficiency ratio. At 1A, the CXB3590 I have is right around 195lm/w and putting out about 7000lm. Sure, it may only be 6000 OTF depending on the optic/reflector but that’s still pretty amazing. Also, at just $9 each, they’re a pretty affordable option for something silly like a quad. I guess I’ll see how heavy they are later today. I noticed last night that they’re larger than I thought. Luckily, I have tons of room inside the Battle Lantern.
The casing and the fact it’s fully potted make them pretty hefty. I accidentally fried one and took it apart. But you can remove the casing which would give you about 3mm or so of extra room…. And probably adhere itto your lantern to dissipate additionaal heat….
Went for a walk with the ghetto rig to test the MW driver. I think it needs the tighter Angelina reflector. It is interesting to walk around with a ~6000lm light but it’s not full-on-giggle-mode.
Nice…. pretty wide beam from the Angelina. I got a wide beam from the Stratus LED driver, but it still lit things up about 275ft. away with their reflector.
Work parking lot, no light (around 5:45am)
With the CXB3590, Stratus LED driver and reflector, 3s LiPo:
Way brighter than the RAB COB floodlights we have at the parking lot. Though they are a bit warmer in tint.
If you’re interested, I have a spare Stratus LED driver to sell cheap, for playing around with…
I need to find a dark parking lot or field or something to try this thing on. It does throw some light but the light hitting the ground right in front of you is almost like daylight. This is one reason why I think the… spot?… Angelina would be better as it would throw more of the light into the distance.
I think I’m going to switch the Battle Lantern to a Bridgelux Vero18 as the smaller LES is closer to the size that I think the Angelina reflectors were designed for. I’m also going to order the sublens and a few more reflectors in the Angelina series to play with. Basically, CDI has really good prices on LEDiL stuff so I might as well get a bunch of items to play with to make the most of their expensive shipping.
I also really want to find a driver that can push the CXB3590 to full output to play with.
