Polymer Optics makes zoomable TIRs even a 7-up version….
Optical Design Consulting Services | Photopia Optical Design Software
LTI Optics provides optical design consulting services for a wide range of optical design projects.
Indeed. I was interested in it a lot some time ago but stopped caring because beam shape when zoomed out.
They have a really cool color mixing TIR with a spot beam…
As well as 7-up XHP50.2 lenses. Hint! Hint!
I said I didn’t expect good beam shape from multi-led Fresnel lenses.
Now I see that Khatod makes PL1172, a 90 mm 9-up:
http://www.khatod.com/EN/product-1010/Fresnel-Lenses-for-Power-LEDs—Autofocus-Lenses.html
Beam actually looks OK except that flood is not spotless it’s more like a reflector than like aspheric.
Here I see a reference to PL1175 - a 50 mm triple Fresnel but I fail to find anything more about it.
The description states PC with aluminum coating… I can only postulate that the center is not coated; helping to effect the large beam angle. And it’s a HUGE angle…
That said, out of curiosity I requested a sample…
Those are used for these type of setups:
That’s what I thought…but then I couldn’t find anything but COBs under acrich name.
Thank you thijsco19!
Could be either a clear or matte dome… or a fresnel + reflector setup, that’s where I’d bet my money.
With the central dome being hollow, it can’t be (single-surface) refraction towards the reflector.
Doing some searches I stumbled upon interesting quote:
Reflector and lens optics have been designed for LED headlamps and lanterns for the leading outdoor equipment manufacturer Black Diamond. All headlamps use compact Fresnel/TIR collimator style lenses allowing low profile packaging designs
Any pictures of BD headlamp lenses?
Aaaah now that makes sense! :person_facepalming: :person_facepalming:
Look what else I found… SORAA has been at this for a while (this is from 2015 or even earlier):
14.19 MB
I see the MR16 or GU10 spots (50mm) go for 40€ apiece on Amazon, but on ebay a few pop up for 10-15GBP (+shipping )
Is that Yajiamei lens RXI as well?
https://www.aliexpress.com/store/product/COB-LED-lens-diameter-69MM-12-degrees-CREE-CXA-Condenser-lens-Plastic-plating-reflection-lens/209770_32639660451.html
It doesn’t look like RXI but it’s flat and narrow.
Note: there are variants from 50 to 75 mm.
Page Not Found - Aliexpress.comIt doesn’t look like RXI but it’s flat and narrow.
Description says optical grade PC……
RXI is just fine with PC. It’s all about folding optical path. Light goes up and is reflected (by TIR or metalization) down towards the bottom and towards the sides. Then the main reflector directs it forwards.
Refraction as the light enters and leaves the lens is usually used as well.
A while back I remember a camera “lens” that was relatively flat ike Carclo’s catadioptric but used multiple folds…
BTW every time I see that flat 50 mm optics I can’t help by wonder:
BLF Q8 has 4 domed XP-L.
XHP70 has 4 XP-L dies under a single dome.
How would the beam of Q8 compare to XHP70 under a flat optics?
Similar LED config.
Similar size, most XHP70 lights tend to have long heads but this one wouldn’t. Actually it would be shorter.
The flowery spill wouldn’t be there.
Those flat lenses don’t tend to be as narrow as possible. Would they have a donut hole?
Assuming a lens is wide enough to eliminate the donut - what would throw better? Q8 loses some frontal area due to being a quad. Lens needs to compensate for the donut.
Thoughts?
