chadvone
(chadvone)
January 20, 2019, 8:40pm
281
Lexel, Shipping was shorter(faster) then I expected it to be. I should of said shipping was faster then I expected. You beat orders from China ordered at same time.
Thank You for providing these drivers.
On skilhunt driver I want to remove some 7135s without removing the single channel 7135. I know where the single channel is on the modded drivers you sent. I need to know if the single channel 7135 is in the same place.
Anthon
(Anthon)
January 20, 2019, 10:28pm
282
just installed in my Q8 a driver from Lexel, great quality and max 7135x15 regulated brightness, also running with anduril!
I also wanted to thank Lexel for all his help when installing the driver!
Lexel
(Lexel)
January 20, 2019, 10:38pm
283
chadvone:
the usual 21mm for H03 has the single on always on top side
the ones with on down side originate from C8F 21700 design and have it always in that position, but other sizes can be differnt
rjd
(rjd)
February 24, 2019, 11:48pm
284
Any chance you could flash a version Anduril instead of NarsilM?
Lexel
(Lexel)
February 25, 2019, 6:44pm
285
Its no problem to flash Anduril or Emisar Firmware as the drivers are compatible
rjd
(rjd)
March 7, 2019, 10:47pm
286
Maybe I should have asked “can you sell them already flashed with Anduril or Emisar D4S?” to avoid confusion.
If you can I’d like to order 2x 17mm drivers with Anduril.
Thanks Richard.
hello, am i able to order a 30mm driver for an Convoy L6?
JasonWW
(JasonWW)
March 26, 2019, 7:42pm
288
Yes, Lexel will send you a personal message asking you what options you want.
Unloco
(Unloco)
April 8, 2019, 5:05pm
289
Is there a possibility to tactically use the tail button in the Convoy L6 with Narsil or Andúril as in the Sofirn C8F 21700?
JasonWW
(JasonWW)
April 8, 2019, 6:27pm
290
Yes
For the initial power on option you can choose two blinks, turbo or nothing.
Lexel
(Lexel)
April 8, 2019, 6:37pm
291
this is for NarsilM Anduril I dont know how to change that start up
Mikeadoo
(Mikeadoo)
April 8, 2019, 8:45pm
293
L6 30mm diameter driver, NarsilM 2S either Blink at the tail cap or Turbo at the tail cap?
I’m in for 1. Already PMed you Lexel.
Unloco
(Unloco)
April 13, 2019, 7:55pm
294
OK.
Thanks.
Interested in one L6 NarsilM, PO=turbo.
Lexel
(Lexel)
April 16, 2019, 1:14pm
295
I have also made a crowdfunding campaign for the new reflow oven as I will not make the drivers more expensive
X31
(-X3-)
April 16, 2019, 2:44pm
296
Hi Lexel, I’d need a 30mm 1S driver for a tail-clicky host (Olight M22).
Bistro UI would be cool
Lexel
(Lexel)
April 16, 2019, 2:52pm
297
sure there is the 24-30mm Bistro 1S possible to build
X31
(-X3-)
April 16, 2019, 5:05pm
298
Can I get a quote by private message please?
Inkidu
(Inkidu)
May 22, 2019, 2:08am
299
I would like to buy (2) 20mm drivers for the Convoy M21A & Convoy S21A
robinogi
(robinogi)
June 25, 2019, 2:16am
300
I’m fairly comfortable with a soldering iron but have never “modded” a flashlight. What would I need to add Narsil to my Astrolux MF01?
