【convoy】convoy S12 / M21B / M4U
1931 posts / 0 new
ZolkoW
Last seen: 7 months 2 weeks ago
+1 for the X3 style.
Ryzbor
Ryzbor's picture
Last seen: 3 hours 27 min ago
+1 ×3 style
It looks boring, but still better then the other designs and seems practical.
virence.com rosy 3500K R9080 Wizard Pro
sochi111
sochi111's picture
Last seen: 4 months 3 days ago
Simon,
Not sure if anyone asked you already this question but as you are already working on new S2 host maybe its a good time to ask.
Would you be able to produce a 18350 style headlamp with the head and reflector in the middle?
something like this (TN-20)
or this (EHL0628)
or even like this Facepalm (S3 “eebowler”)
justanotherguy
Last seen: 26 min 11 sec ago
any chance on codes for 580 lumen convoy s9?
I need 12 asap
anyone in NE ILLinois into get togethers?
Simon Mao
Simon Mao's picture
Last seen: 4 hours 13 min ago
To: sochi111
following one will be available in one week
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.
Simon Mao
Simon Mao's picture
I need 12 asap
what about S9 2500mA version 900-100lm
BlueSwordM
BlueSwordM's picture
Last seen: 18 min 26 sec ago
@Simon, that headlamp looks amazing!
Would it be possible to order with SST-20 4000k?
If so, it would be awesome!
bmengineer
bmengineer's picture
Last seen: 34 min 45 sec ago
Simon Mao wrote:
To: sochi111
max output 2500mA
!http://farm8.staticflickr.com/7862/46399418675_70a74b27ba_b.jpg!
What’s the UI on this? Long press for off, or single click? Will this be available with the 219C?
Find all my reviews of flashlights and more gear at www.bmengineer.com
justanotherguy
I need 12 asap
Maybe, though these are intended for regular non flashlight geeks…
So I am concerned about heat…and cost to an extent…
Last time around I think I managed $16 or something (i’d have to look that up) Best I see is $18
Simon Mao
Simon Mao's picture
I need 12 asap
$17.69 including 15%off
Simon Mao
Simon Mao's picture
bmengineer wrote:
Simon Mao wrote:
To: sochi111
max output 2500mA
yes,long press for off,and single click to change mode
only CREE XML2 version currently
Simon Mao
Simon Mao's picture
and i plan to produce charging version soon,
SST20 can be adding in plan
BlueSwordM
Still, thank you a lot!
I’ve been waiting for a Convoy headlamp for such a long time.
I love your lights’ user interface, build quality, and easy modification.
Is it easy to open for modification?
Thank you again.
contactcr
Last seen: 1 hour 13 min ago
I would love an 18350 tube for that headlamp, instant buy.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 9 hours 45 min ago
Looks like a screw-down bezel on that headlamp? Should be easy to swap emitter/MCPCB right?
Is the driver easily accessible for modding as well?
justanotherguy
I need 12 asap
I’ll take them. whats the specific ordering instructions
1400ma, correct?
Sparks65
Sparks65's picture
Last seen: 16 hours 38 min ago
Looks Good, Simon. I’ll be buying a headlamp and an S11 as soon as available!
Lightbringer
Lightbringer's picture
Last seen: 19 min ago
I was going to suggest that instead of using a hateful little reflector, standard 20mm TIR lenses would be ideal.
They can be swapped easily from narrow-angle to wide-angle in a minute or less, and would blend colors so much better to eliminate tint-shift and “fried egg” beams (yellow center hotspot, blue-white outside spill).
The 4C that’s commonly used in the S2+ has a fried-egg beam. White spill, yellow hotspot. After substituting a TIR lens for the reflector, the beam was perfect, like warm sunlight.
Nicolicous
Nicolicous's picture
Last seen: 1 hour 52 min ago
Simon Mao wrote:
To: sochi111
max output 2500mA
Nice light but it look similar to h03 skilhunt Silly
Anychance you selling host? I’m Looking to use different drivers and led.
Nico -.-
oweban
oweban's picture
Last seen: 1 hour 18 min ago
Simon why do you hate my wallet so much D:
Very sexy, hopefully easy to swap emitters! Agreed with the TIR sentiment; I still need to buy the 5pack to find the one I like the best.
sochi111
sochi111's picture
Simon Mao wrote:
To: sochi111
max output 2500mA
Wow Simon,
I know I was asking for too much for a centered headlight Maybe later
But that is an awesome light. Smile
Simon Mao
Simon Mao's picture
Thank you again.
it’s too compact to modify it ,but i can supply special version according to BLFers’ requirements
Simon Mao
Simon Mao's picture
ok ,add in plan
Simon Mao
Simon Mao's picture
I need 12 asap
1400ma, correct?
there are two versions
one 1400mA,other one 2500mA
Simon Mao
Simon Mao's picture
it’s special driver ,
it’s not easy to be modified
Simon Mao
Simon Mao's picture
Thank you for your suggestion. And I’m ready to launch a lens version.
Simon Mao
Simon Mao's picture
Nicolicous wrote:
Simon Mao wrote:
To: sochi111
max output 2500mA
Sorry, I don’t plan to sell the host. Because it’s too compact. It’s not easy to customize.
Clayman83
Last seen: 13 hours 48 min ago
Simon Mao][quote=bmengineer wrote:
Simon Mao wrote:
To: sochi111
Won’t it be more convenient to use short click to turn it on and off and long press for switching modes?
oweban
oweban's picture
Ooooh yes!
  • single press is on/off
  • long press from off is moonlight
  • double press from anywhere is turbo
  • long press while on changes low/medium/high
Agro
Agro's picture
Last seen: 2 min 34 sec ago
Simon, I love that H1:
  • knowing your lights – good quality
  • knowing your lights – superb value
  • moonlight
  • always starting low
I’d rather skip the strobe altogether, might be accidentally activated while changing modes.
And High CRI would be a nice option.
There was a big gap in the market below Skilhunt H03 and you’re the perfect maker to bridge that gap.
And 18350 tube is just a superb addition.
How much does H1 weigh?
