ALL THINGS BUDGET KNIVES
It reminds me of the D’ALLARA 3.
Hey,
I have this knife too, and it’s very hard to open!
I think it’s because of the very small flipper tab.
Does yours have the same issue?
Hello
I’ve had the same issue but I was reading about it before I’ve bought it on the bay for $43
The trick is to keep your fingers away from the lockbar. That happens with some framelock folders, the SRM 9103/4 is such an example.
When the finger is out of the way mine flips like a dream, even better after I disassembled it and cleaned out the grease.
The biggest issue I have with it is the clip though, it should be closer to the back of the handle instead if laying over the framelock relief.
This way it’s a real seam catcher which makes it difficult to draw. I’ve sanded away a bit but afterwards I couldn’t get such a nice anodisation.
Maybe it will get a rock pattern someday, right after my SRM 813 has its carbon fiber scale :wink:
It’s a replica of replica of Michael Zieba Gentleman’s G-2 knife :slight_smile: With very soft steel.
Original: http://forthenrycustomknives.com/product/michael-zieba-g-2-gentlemans-zdp-189-front-flipper-skyline/
I have replica from CH Outdoors, named as ZiebR (Zieba Replica) with HSS steel 1.3343 (not ZDP 189, but so close), 62 HRC:
CH Outdoors 3504 D2 G10
CH Outdoors 3504 Titan Blue S35VN
Swap the blades
Thank you for the info MaksVasilev!! :+1: . Good looking knife & great pictures too.
TwoSun TS20 :slight_smile:
Not exactly budget but, a nice knife on Massdrop. Brad Zinker Dogtooth, multiple handle materials available. Lefty version too. $119 and up.
I think I got the affiliate type link removed from the address.
That is a well-built knife!
O rings that’s interesting.
THESE are on sale again at GearBest.
I got one of these several weeks ago & then they sold out. GB just listed them again. I’m hoping they are the same quality as my first one.
In 25+ years of buying knives, this is probably the best deal I have ever run across. This little jewel is one heck of a knife.
The only con is a clip that must be bent in a couple of strategic places to allow it fo function properly. No big deal at all though.
You lose if you miss this one…… . :wink:
7.7cm D2 blade and a G10 handle:
https://m.gearbest.com/pocket-knives-folding-knives/pp_009152095568.html?wid=1433363
Thank you. Grabbed a couple. One to keep and one for a gift.
Your welcome. :+1: … I got enough this time to have gifts covered for a while. :wink:
Can you show before/after on the bends please?
Thanks!
I grabbed a couple, thanks. If they are as good as the kwaiken version I’ll be more than pleased.
Your welcome. My prediction, based on the first one I got; is that you will be “more than pleased. :wink:
Let us know what you think when you get them. :+1:
Does this knife run on washers?
Thanks
I have not disassembled mine to see. I can tell you it opens as smooth as glass & there is no blade play.
Fit n’ finish is about as close to perfect as possible.
Great edge holding. I have been trying to dull the one I have by cutting old miscellaneous cardboard boxes I had/have. No luck yet, it still shaves hair off my arm. I have cut +well over+150 yards of cardboard at this point. The 150 yards is a conservative estimate too.
At $9.99 it’s a nobrainer. Quite possibly the ’deal of the century’ as far as I am concerned! :smiley: . :+1: . :wink:
@ Muto … Before & after?? Yep, I’ll do that as soon as my next one arrives. I’ll get the “before” & then bend it to show the after.
It is just bending the tip of fhe clip up a bit so it slides easier onto the edge of the pocket.
And then two very slight bends up at the top, just down from where it attaches to the knife; to give it more room to accommodate a Blue Jean pocket: which is usuall thicker material than dress pants.
It could even be the clip on the only one I have was misformed all along I guess. I just didn’t/don’t have a second knife to compare it to at this time.
I was concerned the clip might break while bending, but the first one did not. :+1:
Are these legit knives or just decent clones?
https://www.gearbest.com/pocket-knives-folding-knives/pp_009582970839.html?wid=1433363
https://www.gearbest.com/pocket-knives-folding-knives/pp_009654979244.html?wid=1433363
THANKS
Keith
I’m not sure about the first one.
But the second one was discussed HERE and REVIEWED HERE.
