Technically, not only for casting soft shadows, but to have the C8’s better heatsinking ability compared to S2, it is very useful to have a frosted lens in front of the reflector (if someone goes for a bit more powerful flooder).
I’ve noticed that Convoy’s Biscotti driver are locked (to prevent flashing), and some people already mentioned to make a cut with a knife on some pin number. I’ve tried doing the cut on a Biscotti driver, but still couldn’t flash successfully — it could be my “cut” wasn’t deep enough though.
I was wondering, if these bare Biscotti drivers can be fixed with a reflash?
May I ask which Biscotti .hex file to use for re-flashing affected Biscotti drivers (since I now have a few Convoys with Biscotti drivers) and fix the fuse issues or timing issues, if that’s possible?
Though that’s a disappointing one. Please let me explain…
Most of my friends who actually use flashlights are backpackers. They tend to pick headlamps. Always plastic ones; Black Diamond, Petzl and such. Sometimes I try to convince them to get something brigher, more efficient, with better tint, tougher, with more battery….and I always fail because even 92 g of Skilhunt H03 with 18650 cell is a lot for them. Similarly skinny light with 18350 would have a chance. And one that allows to pick tube size - even more so. I see that H1 with 18350 will weigh roughly as much as Skilhunt H03 with 18650. I see little reason to use 18350 then…
Also - I’m a backpacker myself. And a weight weenie on top of that. I have quite a few uses for H1 even as it is now (most importantly: a worklight, after putting a TIR in it) but it won’t become my ultimate headlamp; there will still be significant uses where it’s just too heavy.
Anyway I fully expect that H1 will be on my list of lights worth recommending - but not to everyone. Significantly - not to most of my friends.
I’m not sure the copy in trunk is calibrated correctly for Convoy’s drivers. Each flavor of driver has slightly different calibration values. The one I sent Simon is in the Convoy branch instead. However, it’s otherwise generally recommended to use trunk whenever possible, since it’s kept more up to date than individual product branches. It just might not have the calibration values set right for individual products. Those values are still only approximations though, and it’s ideal to measure each driver individually with the tools in the battcheck/ directory if you want things to be exact.
TL;DR: It should work, but the LVP activation point might not be quite right and the battcheck mode might be a little off.
I did this a while back with some free diffuser samples. Works well with the L2 because it has a fairly thick lip on the reflector to hold it in place.
In my opinion Biscotti is what elevates the Convoy C8 and S2+ from great hosts to great lights that I happily recommend to non flashoholics. I’ve used a few Convoy Biscotti purchased from Banggood drivers myself and I haven’t had a bad one yet.
I’d rally like to thank you ToyKeeper for making your firmware freely available. The majority of my lights are running Biscotti, Bistro, or Anduril and I don’t think I would have got into the hobby if it wasn’t for the BLF drivers and your firmware.
The axes of the CIE 1960 colorspace are labeled “u” and “v”. Duv is “delta uv”, or the distance between two coordinates. As used in maukka’s reports, it’s the distance from the blackbody line at the correlated color temperature of the light to the actual color coordinate of the light, or more simply, how red or green the light is.
More than +/- 0.005 is a very large Duv - very obviously red or green, easily noticed even without comparison to another light source. A positive Duv is green, and a negative Duv is red. +0.0075 as seen with this C8/219C sample is extremely green such that the color of everything illuminated with it will appear distorted despite the high CRI.
Almost nobody here likes light that is very green. Some people like light that is noticeably red (and seek out rare LEDs like the Nichia 219B sw45k to get it), but almost everyone will be happy with light that is purely white (Duv less than +/- 0.001).
I hate this UI. I find it difficult to understand why anybody would design a UI like this.
The biggest problem is that changing modes too quickly results in strobe. Accidental strobe is no fun at all, especially if you’re trying to switch from medium to low, so you click the button again quickly after you get high. The combination of a single click to change modes and a double-click as a shortcut to anything is bad, but especially bad if it’s strobe.
Long-press for off also tends to confuse people. If I had a light to someone without giving instructions, they will expect a single press of the button to turn it on, and another press to turn it off. There’s a reason Thrunite, Olight, Acebeam, Emisar, Haikelite, and the popular open source firmwares for e-switches (Narsil and Anduril) all have roughly the same behavior:
Single-click: on/off
Long-press from off: lowest mode
Long-press from on: change brightness
Double-click: highest mode
Simon, I imagine you’re buying drivers with this firmware already on them, but do you have any way to get a different user interface on them? This one is very bad.
Do i understand it right. The sideswitch on the H1 has no led behind it?
Why not?
To make the reflector cavity compatible to use TIR optics sound like a very good idea!
This would allow people to change it from throw to flood like they prefer.
And the use of a TIR would allow me to mod the H1 with a TIR backlight like i did with my H03.
Thanks for your explanation.
i will launch H2 H3 H4… in the future,
You made me understand the needs of the users. In terms of weight, I will design a headlight that is more suitable for the user.
The DUV is super high, which means this emitter will look very green . Hopefully Simon can source some hi cri emitters with low DUV like SST-20 with FA1, FA4, FD1, FD4 tint bins or Oslon Squares with below the BBL tints.
