Very low then high for me. It needs to have firefly mode, I can live with a lower high mode for a longer battery life
Something like: 0.05, 8, 24, 72
/\1
This is a 1xAAA twisty. It won’t get very bright, and it’s not very easy to “tap” for variable amounts of time like a reverse-clicky button, so it’s probably best to stick to only short and long intervals instead of short/med/long.
About log-spaced levels, that’s one of the options in the ramp calculator, but it’s not the default or recommended setting. Most research suggests a cube-root model instead of log. Here are a few “evenly spaced” ramps, using different curve types:
IIRC, the blf-a6 used a cube-shaped ramp. On some newer lights with higher output, I’ve used a fifth or even a ninth, in order to put the lower modes closer together at the expense of high-end resolution. I don’t think I’ve ever actually used log in a production light though, because it tends to cluster the low end together a little too much.
Voted L>H
LH…
thanks.
“Ideally more like 8 and 40 though, instead of 3 and 100.”
+1 what TK said.
It’s a small back-up light. The 8 would hopefully be like the C01, with a bump to 40 as reserve without draining the battery.
(I completely missed the “PRO” development.)
We all did for the most part, the “development” was not ‘public’.
The “pro” was already planned before the C01. When I asked Barry/Sofirn if they would make our Yuji 5mm twisty, they were directly interested because a small AAA twisty was already planned by Sofirn, just not one with a low output 5mm led. Still it was pretty awesome that they went for it . So the C01S is the type that they originally wanted to make. I did advice on how they could set it apart from other AAA twisties (especially the cheap and very high quality Olight i3s and i3e), so that is why it has modes and a high CRI SST-20 led. And the Noir-tail of course
I’m a Moonlight guy. 0.2-25-some high number here within reason.
+2
I am in for LH. Buy Low sell high
I think I agree with the fellows, I would prefer 5-10 Low and 50-60 for High. Just my 2 cents.
I was not involved in which modes Sofirn has chosen but the stock 3lm-100lm is perfect for me.
what ramp calculator are you talking about?
wle
but that is not what they are offering… it is 100-3… or maybe that is what you mean, you want the modes as is, just LH
maybe you could ask Sofirn to go LH?
but that is not what they are offering… it is 100-3… or maybe that is what you mean, you want the mode brightness levels as is, just LH
or, did you mean youre fine with HL, and are one of the 9% of the votes in favor of HL?
H-L is only usable for keychain light for me.
For EDC-light I prefer L-(M)-H with a sublumen mode.
Why did Sofirn go with H-L instead of L-H with these survey results? (C01S BLF on ali)
AFAIK there were no “surveys” prior to release.
> why …?
My guess is, the nghts in urban China are never dark enough to appreciate why some of us want low modes.
The launch of Shenzhou XI on Oct 17 and its subsequent docking with the Tiangong II space lab has reaffirmed the Chinese public's love affair with space exploration and astronomy.
Shedding light on China’s dark-sky problem
By Zheng Jinran | China Daily | Updated: 2016-10-25A recent survey suggests that for many people, a glimpse of the Milky Way or other parts of the visible galaxy is no longer possible as a result of the affects of artificial lighting.
The New Global Atlas of Light Pollution, published in the journal Science Advance, shows that 60 percent of people in Europe and almost 80 percent of North American residents are unable to see the Milky Way. More pertinently for China, it also shows that light pollution makes the nebula invisible to people who live in the areas around Beijing and Hong Kong.
