curious what CCT?
If you remember my video of the faulty RRT01… here’s a brief update. HK offered a replacement and I sent it back… they got the return on the 26th. I emailed them Monday if they had sent the replacement yet. They said they hadn’t gotten my return. I still had the receipt and tracking info… provided them that and pretty quickly got a refund for my purchase price and my shipping back to the NJ address. Was hoping for a replacement but I guess that won’t happen. So just a reminder- if you deal with HK Equipment and have a return keep your tracking info (like any retailer really). For now I’ll watch all the cool mods you guys will do with them. I’ve already spent that money on knives. I figured it was a little overpriced for what it was- maybe the price will come down and I’ll buy it again. I have to many zebralights and Emisars already.
AHH couldn’t take the pressure anymore. Ordered one with the madmax code.
What emitter are you guys thinking off for this light?
Will be between the 3000k sst-20 or 9080 sw40s for me.
Posted by LumenMax:
New RRT01 triple mod :+1:
cool, thanks
fwiw, it shows that to enable strobe does not require going to maximum, same is true for my Eye10
One of the features I like about the RRT-01 is that the strobe can be dimmed too
I really like my old RRT01. It’s the best ring-control light I’ve tried, and I got really lucky with the tint. 5000K and it seems to be right on the blackbody line. It just needs low voltage protection and a battery check mode instead of SOS.
With an Oslon White Flat emitter installed, the new RRT01 could become a very popular light. With such a throwy beam, it would really stand out.
Dang it. After reading this thread, I pulled out my modded jetbeam tcr1. I love the UI so much I couldn’t resist the group buy and bought an rrt01. Curses…
hi,…does this take only Protected 18350?.
I have a Keeppower Unprotected 1200mAh 18350 flat top
thanks.
no
I have Keepower Unprotected 1200mAh and it works in my original RRT-01, so I suspect it will also work in the new RRT-01
otoh, my Keepower Unprotected 750mAh does not work (the button top is wider)
if you want the option to use Protected… the new model does
still no battery check, but now theres a strobe
I would buy your old one…
LOL
congrats
you already have the best TiRotary, and it did not cost $1000 (HDS)
See the video from Vinh (Skylumen) posted in the last pages!
I just got mine and can’t wait to get home and mod it with a Nichia 219b 4500 LED.
I noticed the LED already in it does not have a dome. Should I de-dome the Nichia as well?
No, do not dedome that LED. It has a small enough die and great beam for this type of EDC light.
This. It's got a good amount of throw and flood.
Thank you sir!
thanks. I have a flat white RRT 01 build on way, but on the look out for another RRT 01 to compliment it, but what to have as an LED?.
E21A?, Optosolis?, or even a triple?.
thanks
E21A if Clemence makes a retrofit “kit”, depending on the beam type he can achieve.
I would choose a single LH351D over a triple if you want floody.
yes I am on E21A too.
Single. Thanks.
I just got mine. Other than off and turbo, I don’t have detents on the ring, it’s just smooth.
My V11R does have a far better feel when turning the ring. Was there a post how to disassemble the light, so I can regrease the ring?
doesn’t sound like you’re thrilled?
Not really actually. The ring action doesn’t feel nice. It has some scratches out of the box and the clip is made out of tin foil.
Guess it needs some modding love, for now I like my V11R better.
