Tried them all, I liked MG Chemicals, but went back to Kester EP256 63/37. I buy from CML Supply it seems to be fresher because they sell a crap load on Amazon/FleaBay and in my experience it flows a bit better/faster/cleaner with a hot air/reflow station and last longer, IMHO, it was $17.99 free shipping 3 days to the door, usually.
SnBi based solder paste has very BAAAAD thermal properties and very brittle. EDIT: I only use it for [wire pads] on hard to solder MCPCB, mixed with approximately 30% Sn60Pb40 to make it slightly flexible. Never use it for LED or anything requires good thermal conductivity.
AFAIK, Sn52Bi48 only has 19W/MK TC. For comparison: copper ~400W/MK, Aluminum ~200W/MK, Brass ~100W/MK, Stainless steel ~16W/MK, Sn63Pb37 51W/MK, SAC307 62W/MK.
Except mixed. I mixed it with ~30% Sn60/Pb40. But don’t forget to heat it first to temp slightly above 60/40 melting point. Otherwise the 60/40 granules will stays unmixed. You still get around 150C combined melting point
All the resistor’s plus cap’s (size 0402) and other components are reflowed with the Chipquik and a hot air.
I use this same stuff for all my led reflows too, I haven’t found a need to try anything else, if it’s not broken why fix it.
I agree 100%. I haven’t found anything better. The added silver also helps improve conductance.
I know Micro Center has locations in PA, so if you have one near I’d suggest checking out their soldering supplies. I used to order everything after Radio Shack went away until I finally realized Micro Center has just about everything you’ll ever need.
How do you reflow? If you are using hot air for a PCB or hot plate for MCPCB paste is really helpful. I have been using the same cheap syringes of paste for a few years now without issues.
A lot of pastes technically expire like 6-9 months after date of manufacture. I rarely reflow stuff, so that paste just goes to waste with me. I’m also not real comfortable using it after the expire date. It’s probably okay, but eh.
Figured there would be plenty of choices and just like when I first visited here, I have no clue what a lot of the terms used in the above posts mean and don’t need to know just need what works all around best for an amateur hobbyist and it looks like this stuff will do well.
Thanks again
The thickness of alloy is very small to have a significant effect on final heat dissipation. An more narrowed space- the p-n junction to thermal pad. You was compare the junction themperature with different alloy, with infrared thermometr?
It is significant. 50W/MK vs 86W/MK TC made huge difference in output. Haven’t tested 19W/MK vs 50W/MK but I suspect the difference would be much greater.
