I’m not sure the copy in trunk is calibrated correctly for Convoy’s drivers. Each flavor of driver has slightly different calibration values. The one I sent Simon is in the Convoy branch instead. However, it’s otherwise generally recommended to use trunk whenever possible, since it’s kept more up to date than individual product branches. It just might not have the calibration values set right for individual products. Those values are still only approximations though, and it’s ideal to measure each driver individually with the tools in the battcheck/ directory if you want things to be exact.
TL;DR: It should work, but the LVP activation point might not be quite right and the battcheck mode might be a little off.
I did this a while back with some free diffuser samples. Works well with the L2 because it has a fairly thick lip on the reflector to hold it in place.
In my opinion Biscotti is what elevates the Convoy C8 and S2+ from great hosts to great lights that I happily recommend to non flashoholics. I’ve used a few Convoy Biscotti purchased from Banggood drivers myself and I haven’t had a bad one yet.
I’d rally like to thank you ToyKeeper for making your firmware freely available. The majority of my lights are running Biscotti, Bistro, or Anduril and I don’t think I would have got into the hobby if it wasn’t for the BLF drivers and your firmware.
The axes of the CIE 1960 colorspace are labeled “u” and “v”. Duv is “delta uv”, or the distance between two coordinates. As used in maukka’s reports, it’s the distance from the blackbody line at the correlated color temperature of the light to the actual color coordinate of the light, or more simply, how red or green the light is.
More than +/- 0.005 is a very large Duv - very obviously red or green, easily noticed even without comparison to another light source. A positive Duv is green, and a negative Duv is red. +0.0075 as seen with this C8/219C sample is extremely green such that the color of everything illuminated with it will appear distorted despite the high CRI.
Almost nobody here likes light that is very green. Some people like light that is noticeably red (and seek out rare LEDs like the Nichia 219B sw45k to get it), but almost everyone will be happy with light that is purely white (Duv less than +/- 0.001).
I hate this UI. I find it difficult to understand why anybody would design a UI like this.
The biggest problem is that changing modes too quickly results in strobe. Accidental strobe is no fun at all, especially if you’re trying to switch from medium to low, so you click the button again quickly after you get high. The combination of a single click to change modes and a double-click as a shortcut to anything is bad, but especially bad if it’s strobe.
Long-press for off also tends to confuse people. If I had a light to someone without giving instructions, they will expect a single press of the button to turn it on, and another press to turn it off. There’s a reason Thrunite, Olight, Acebeam, Emisar, Haikelite, and the popular open source firmwares for e-switches (Narsil and Anduril) all have roughly the same behavior:
Single-click: on/off
Long-press from off: lowest mode
Long-press from on: change brightness
Double-click: highest mode
Simon, I imagine you’re buying drivers with this firmware already on them, but do you have any way to get a different user interface on them? This one is very bad.
Do i understand it right. The sideswitch on the H1 has no led behind it?
Why not?
To make the reflector cavity compatible to use TIR optics sound like a very good idea!
This would allow people to change it from throw to flood like they prefer.
And the use of a TIR would allow me to mod the H1 with a TIR backlight like i did with my H03.
Thanks for your explanation.
i will launch H2 H3 H4… in the future,
You made me understand the needs of the users. In terms of weight, I will design a headlight that is more suitable for the user.
The DUV is super high, which means this emitter will look very green . Hopefully Simon can source some hi cri emitters with low DUV like SST-20 with FA1, FA4, FD1, FD4 tint bins or Oslon Squares with below the BBL tints.
Probably, most people will be happy with emitters spot on black body line (duv +0.001 to –0.001). I think, reddishness (or rather rosiness) to duv –0.003 is acceptable (and helpful with recognizing blue and red details), below that I consider it a bit of special use.
In practice, while SST-20 LEDs are promised to be on black body line with tints FA2, FA3, FD2, FD3, they are a bit more yellowish, when used on lower currents. This is why SKV89 recommended to source the tints above (FA1, FA4…), because they can hit the black body line better (especially, when not just bare led is measured, but optics as well).
In practice, I found the FB4 tint of SST-20 very appealing for outside use, if it is driven around 2A, because the tint changes, so it is noticeably rosier, than if multiple same LEDs were driven at a much lower current each.
It is very difficult to source Nichia 219C with proper duv values, and this is more visible for emitters in the 2700K-4000K CCT range. But for me, even a slightly greenish (duv up to +0.003) 219C is fine, if they are in the 5000K-5700K CCT range.
To cover the ‘cool white’ range of CCTs with high CRI emitters, do you consider to get Samsung LH351D emitters (they have 90 CRI for both 5000K and 6000K CCT)?
Those emitters are a bit less throwy, than 219C, but overall, they have somewhat more output (also, it is safe to drive them far past 4A with good heatsinking) - and maybe a bit less green.
LH351D in 5000k with 90CRI is very nice - popped some in a Wowtac A2S and an Olight S Mini. Unsure about the lumen drop from the original emitters, but the A2S on turbo can still spit out a lot of light.
