I’m not sure the copy in trunk
is calibrated correctly for Convoy’s drivers. Each flavor of driver has slightly different calibration values. The one I sent Simon is in the Convoy branch instead. However, it’s otherwise generally recommended to use trunk
whenever possible, since it’s kept more up to date than individual product branches. It just might not have the calibration values set right for individual products. Those values are still only approximations though, and it’s ideal to measure each driver individually with the tools in the battcheck/
directory if you want things to be exact.
TL;DR: It should work, but the LVP activation point might not be quite right and the battcheck mode might be a little off.
