Vinz???
20 posts / 0 new
forumname05
Vinz???
Is Vinz still around???
I currently have 3 Vinz drop-ins and I’m looking to upgrade. I cannot seem to get in to contact with him.
If Vinz is not around anymore, what would compare?
At work I currently carry 2 Oveready modded Surefire 6P hosts with Vinz drop-in’s.
On my duty belt I carry more of a ‘flood’ pattern and in a cargo pocket I carry a ‘thrower’
My department recently issued Pelican 7600’s to everyone and they are making my current Vinz lights look a bit weak. So, I need to upgrade my drop-ins!
What would you guys recommend???
I’m not quite up on all the new stuff, but I guess this is what I’m looking for…
- 1 drop-in that is more flood, a real workhorse. Then another that is a pure thrower.
- Compatible with my Overready bored out 6P bodies
- Ran on an 18650
- High (1500+?), Medium (250-500?), Low (50?) lumens of nice white light (no yellow)
- No mode memory, but a fast mode reset (.3sec)
That’s the gyst of what I have right now, but I don’t think mine are anywhere near 1000 lumens. The color temp may be throwing me off though. I’d just really like to blow these Pelican 7600’s out of the water.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 56 min ago
Y’mean Vinh? Yeah, he had a thread that was fairly active a little while ago.
BlueSwordM
BlueSwordM's picture
Last seen: 13 hours 56 min ago
How much do you want to pay?
Because there are 10-20$/drop-ins: http://kaidomain.com/Flashlight-DIY-and-Tools/led-drop-in/KDLITKER-P6-LED-Drop-in
And 100$+/drop-ins: https://skylumen.com/products/p60vn-light-engines-p60-hosts
Henk4U2
Henk4U2's picture
Last seen: 7 hours 16 min ago
Hé guys, the name of the wanted man in the OP is spelled correctly Facepalm
On social media he is/was also known as VinzCPF (from Germany, not Vinh from Washington).
Haven’t seen him there since Xmas 2017.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
MascaratumB
MascaratumB's picture
Last seen: 7 hours 28 min ago
Deleted my post! Sorry for the bad info I gave Oops
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
DrDevil
DrDevil's picture
Last seen: 21 min 53 sec ago
I´m quite sure he means Vinz, a German Modder and creator of a line of drop ins which are sure still ´state of art´
http://budgetlightforum.com/node/23595
https://www.taschenlampen-forum.de/threads/massiver-d26-einsatz-md26e-xm...
I´m not sure if he ist still active from time to time; On TLF he is absent more than a year Sad
forumname05
Yup, that is the Vinz I’m talking about. Beautiful drop-in’s and an amazing guy to deal with.
forumname05
I don’t mind paying, if said drop-in is worth it.
If I remember correctly, my Vinz drop-in’s were in the $75-$100 range.
Lightbringer
Aha, okay. Learn something new every day. Big Smile
polarweis
polarweis's picture
Last seen: 13 hours 29 min ago
wouldnt a normal flashlight with a shelf have much better heat transfer?
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
KawiBoy1428
KawiBoy1428's picture
Last seen: 31 min 45 sec ago
I buy the copper Surefire quad/triple pills oversize from member kiriba-ru and machined the 6P/9P C2 for the 18650 and leave a step at the head for a battery stop, in case I want to weapon mount it. I hand fit to a press fit the quad shell, can’t stand copper wrapping. Made delrin dowels up that are hollow in the middle and seat on the rim of the copper pill to press it back out if needed and it is needed during fitting. I use the Mtn, FETDD guppydrv 3 18awg leads. It’s got a Tactical mode/program that locks that mode you choose in, I highly suggest it.
I build the Z59 switch with a KAN9 250v 10amp Fwd switch Blue spring 18awg bypass.
The latest one I built made 4500+ lumens.
I have made a few of them… the 9P’s are 3S Triples running 3×18350’s making just over 4000lm. All hand fit with press fit copper pills. Even my home made 3P Triple…
KB1428 “Live Life WOT
forumname05
Hmmmm, can you elaborate?
forumname05
Do you mind PM’ing me with more info and pricing
Lightbringer
Drop-ins are generally loose-fitting, unless you wrap them with Cu/Al foil and then wedge them into the light to give them better heat-transfer to the case. That’s always been the biggest weakness of drop-ins.
An integrated shelf means what the LED is mounted on is part of the flashlight body itself, no “seams” to hinder heat-transfer. A drop in would just kinda flop around with minimal contact to the body unless the rather huge air-gap would be filled.
The_Driver
The_Driver's picture
Last seen: 13 hours 36 min ago
Vinz is not around anymore and to be honest – there is nothing compareable. Vinhnguyen’s lights are not on the same level, but that is not a suprise when you consider how many he mods/makes.
forumname05
Damn, I was hoping that wasn’t the case
aL1
aL1's picture
forumname05
KawiBoy’s stuff looks pretty good!
Is there anyone else you guys may recommend? Overreadg? Vinh/Skylumen? Sportac?
I honestly do not care THAT MUCH what the drop in looks like outside of the body (although, I greatly appreciate VINZ’s works of art). I just want high performance that I can trust!
KawiBoy1428
Of course there is..https://www.pflexpro.com/category-s/1855.htm Randy Brogden is also a BLF member, I have a few of his dropin’s when he started out on E-Bay, 6-7 years ago, their bomb proof, check him out. If you send your light to him, he will copper wrap it, like no one else can. Thumbs Up
https://www.pflexpro.com/P60-Drop-In-s/1821.htm
nokoff
nokoff's picture
Last seen: 4 hours 44 min ago
Dave from CustomLites had made thousands of drop-ins for members, he did me a shock proof weapon P60 last year, and a red XPG2, been using him for 10, years.
https://www.customlites.com
Nokoff..still Made in China 山寨主義
