How does the overall quality of this light compare to others like the TC20 or ODF30C? Any beamshots of this light?
Thanks for the review!
Timestamp | Lumens |
0s | 4040 |
30s | 3850 |
1m | 3745 |
70s - 3m | 2500 (Stepdown) |
3m - 10min | 1820 |
It worth noting that the timestamp of the initial stepdown (at 70s) is variable, depending on the flashlight's actual temperature.
At 3min10s the flashlight stepped down to ~1800 lumen and stayed there until the end of my test. The flashlight's temperate was pretty consistent.
In all cases, the body's temperature stayed within the comfort zone :)
Here's a few outdoor beamshots.
Turbo is too bright for 10m distance :)
@30m
@75m
A true pocketable, flood monster :D
Finally, an honestly specced flashlight with a very useful UI. From their website you have choice of cool or natural white emitters - albeit unknown how you specify which one (no dropdown sub menu). Orange peel reflector is stated as “glossy” - no other choice. But may matter as the new 70.2 has no “quad” artifact. Price a bit steep, if had coupon may just sweeten the offer.
The TS70 is 59USD on BG through the 15th, no coupon needed, and they list both cool and neutral white. I have given a few similar UI to family so this will go well with them.
…and about the reflector, it’s a “Digital car system and vacuum plating high performance aluminum alloy glossy reflector” lol. I hope it’s a BOSE or B&O system; those are my favorite factory car systems. What a deal lol
@ mihlit & nokoff:
Thanks, just looking onto and considering …
Hi bilakos10
Great test. I’m definitely interested in this light. One concern however… The test show that at 3.8v the turbo drops out of regulation. What is the resting voltage of the cell once turbo cannot be engaged anymore? The 3.8v you measured was obviously tested under load, thus voltage sag conditions, right?
So how many turbo runs can one expect from a fully charged cell?
Judging by my results, I believe 5-6 is the maximum amount of full-power Turbo runs that one can squeeze out of the cell.
Thank you so much for the tests! This seems to be a decent boost driver in this light. I am waiting to see how the Astrolux MF01 Mini turns out, then I’ll decide. This looks like a good light for extended walks at night.
Cheers man
This might relate to the last few posts, but I noticed that after using this flashlight for a bit anytime I try to use turbo it immediately steps down…is this because the battery is below 3.8 volts?
Yeap, the battery’s low voltage is probably why Turbo won’t engage.
(or it could be thermals).
How does this compare to a D4S?
I wish I could tell you, but I am missing a D4S
At what temperature does thermal control work?
Unfortunately I don’t have a temperature probe but it might be time to get one
In the mean time, maybe someone else can enlighten us!
Hi all. I have a simple question. If with Mhvast ts70 let’s say from MID i double click and go to turbo if i click once will it go back to MID or turn of the light. And if i longpress from turbo will it go low mid high or do something else.
Can’t remember I will clarify it in a couple of hours, after I get back home
Thanks.this will be very helpful in my decision of buying the flashlight.
