Prototype off-road/boating spotlight - King COB!
253 posts / 0 new
LouieAtienza
Last seen: 1 year 1 month ago
The TIR and housing from China… there’s also a heatsink base that I did not buy because I’m making my own.
The TIR lens is 100mm. The housing is quite massive!
prototype3a
Last seen: 2 weeks 3 days ago
That thing is pretty crazy looking. What did it cost?
LouieAtienza
The lens was $15, and the housing (sans screws) was $5, amazingly…
prototype3a
prototype3a
I was looking around on CDI’s site to see what else they have and I came across GAGGIONE. They have some 67mm TIR optics than can work with the Bridgelux 18mm COBs (~6000lm @~36w). I was thinking this might be an interesting option to make a giant quad. However, under-driven Vero29s or CXB3590s would be more efficient, I don’t know of a TIR that would approach a 67mm unit for compactness. The downside to Gaggione is that their website is a glacially slow dumpster fire and I don’t know if the entire line can actually be purchased.
Looking at datasheets and such, the MW boost drivers are actually really interesting since at only 1A output, they basically stop when the ~36v COBs hit a nice output/efficiency ratio. At 1A, the CXB3590 I have is right around 195lm/w and putting out about 7000lm. Sure, it may only be 6000 OTF depending on the optic/reflector but that’s still pretty amazing. Also, at just $9 each, they’re a pretty affordable option for something silly like a quad. I guess I’ll see how heavy they are later today. I noticed last night that they’re larger than I thought. Luckily, I have tons of room inside the Battle Lantern.
LouieAtienza
The casing and the fact it’s fully potted make them pretty hefty. I accidentally fried one and took it apart. But you can remove the casing which would give you about 3mm or so of extra room…. And probably adhere itto your lantern to dissipate additionaal heat….
prototype3a
So much for free overnight shipping. Looks like I won’t have that driver until tomorrow.
prototype3a
Went for a walk with the ghetto rig to test the MW driver. I think it needs the tighter Angelina reflector. It is interesting to walk around with a ~6000lm light but it’s not full-on-giggle-mode.
LouieAtienza
Nice…. pretty wide beam from the Angelina. I got a wide beam from the Stratus LED driver, but it still lit things up about 275ft. away with their reflector.
Work parking lot, no light (around 5:45am)
With the CXB3590, Stratus LED driver and reflector, 3s LiPo:
Way brighter than the RAB COB floodlights we have at the parking lot. Though they are a bit warmer in tint.
If you’re interested, I have a spare Stratus LED driver to sell cheap, for playing around with…
prototype3a
I need to find a dark parking lot or field or something to try this thing on. It does throw some light but the light hitting the ground right in front of you is almost like daylight. This is one reason why I think the… spot?… Angelina would be better as it would throw more of the light into the distance.
LouieAtienza
Yes, because even a “spot” optic with a COB will still produce a relatively wide beam…
Here’s the outdoor floodlight I got from my friend. Installed the MeanWell LDH driver, running it with a 3s LiPo…
Control pic of back yard, some ambient street light in the back:
And with the battery plugged in!
Just have to make a yoke to fit my tripod. Worked great as a work light when I had to do some repairs on my car the other night.
prototype3a
I think I’m going to switch the Battle Lantern to a Bridgelux Vero18 as the smaller LES is closer to the size that I think the Angelina reflectors were designed for. I’m also going to order the sublens and a few more reflectors in the Angelina series to play with. Basically, CDI has really good prices on LEDiL stuff so I might as well get a bunch of items to play with to make the most of their expensive shipping.
I also really want to find a driver that can push the CXB3590 to full output to play with.
LouieAtienza
You must have read my mind because I ordered a couple Vero29s in 5000K 70 CRI, 12k lumens at a more manageable 2.1A. They have solderless connectors and are cheaper to boot. Plus they are rated at max 4.2A so I’m thinking they’ll work better with the Stratus LED drivers. Going to save the CREE CMA COBs for some indoor lighting, and use the Bridgelux with the TIRs…
prototype3a
I really want to use the 72v Vero29 but I need an optic or reflector for it… and a driver. LOL. I could use the Hyperboost but I know I’ll want to build a triple or quad and 4× $40 for drivers is not something I’m exactly keen on.
The 70v version of the COBs you just bought will do 19.5klm at 120w and 32klm at 250w. Crazy
I’m still skeptical of what that StratusLED driver can do since StratusLEDs said it wouldn’t output over 25-26v.
LouieAtienza
The input limit is 28V. I’ve measured over 42V at the LED but don’t have an ammeter to measure the current. It won’t do more than that, and it won’t power the CMA3090 which needs 48V. I’m thinking the Stratus driver puts out more than 3.5A because it trips when I try to crank the dimmer pot all the way with the CXB3590.
I have 2 TaskLED drivers right now, but have to figure out how to power them for the CMA3090s. I need 168W to get them to max, so assuming 90% driver efficiency I’ll need close to 190W at input. I believe I read the TaskLED had only been tested to 130W so maybe I shouldn’t be so greedy. But I’m not because the 36V Vero I got will do over 12k lumens at about 76W (2.1A). Reason I picked them was specifically so I could use the Stratus LED drivers, and specifically because they are the cheapest solution currently.
prototype3a
I forgot to say that I found the control chip the StratusLED driver uses. It’s some made in China part with no english datasheet. I don’t think that board was developed here. I think it was a contract job so who knows what it’s true ratings and such are.
prototype3a
Have you tried running the StratusLED driver off 6s?
We went for another walk tonight with the ghetto rig and had clear skies and nearly a new moon. This thing definitely needs a tighter reflector to limit the spill on the ground close to you. I’m probably going to switch to a Vero29 and an Angelette-S as I think I can just barely fit it inside the battle lantern. It is deeper and wider than the Angelina series so hopefully it will work better. I really wish they had something in the Angelette series inbetween the S (10deg) and the M (50deg).
I asked LEDiL about using the CXB3590 with the Angelette series because it isn’t listed in the datasheet but I can’t see a reason why it wouldn’t work.
Agro
Agro's picture
Last seen: 8 hours 50 min ago
That’s Kunrui, right? Does it work well?
LouieAtienza
Yes… Link on page 3.
Don’t know yet! Waiting for the Bridgelux LEDs to … Don’t feel like taking apart the CREE rig as removing the reflector is a great pain.
prototype3a
Do you have any ideas for large diameter tubing to use for something like a triple? I may need something ~7” ID. Long ago, I made a mini wind tunnel to take to trade shows using a large PVC pipe coupling…
LouieAtienza
You can get PVC pipe coupling up to 14” diameter. They get MEGA expensive after about 8-10” or so. A way cheaper solution is to buy drum shells – 5, 7, 10 or more plies so they’re very stiff… You can buy them wrapped with metal or wood veneer. You an even get clear or opaque acrylic.
prototype3a
… like… musical drums? I didn’t know that was a thing you could buy.
LouieAtienza
There are quite a few folks out there that make bespoke drums, and very, very few of them laminate or bend their own shells! Or have the convenience of 5-axis CNC to do secondary operations like milling the edges or drilling and pocketing. Many manufacturers also outsource the shells. And different numbers of plies can affect the sound of the drums as well, so they are tuned to a player’s preferences.
So, a 3-up COB cannon… nice! I think you may have to start building a trailer to haul that thing…
prototype3a
Looking at 36v Vero29se, LEDiL Lenina-S reflectors, StratusLED drivers, 6s lipo, server/workstation heatsinks and a single fan.
LouieAtienza
What would be nice for the Stratus LED drivers is to find a 10kOhm slider pot that is panel-mountable. I’ve found a few but they’re board (pin) mount and I don’t feel like jury-rigging one, though I suppose I could make two L-brackets out of scrap copper sheet and solder them on to the ends. But yes, I think a combination of Vero29SE 36V and Stratus LED driver is about the simplest solution around. I really need to procure a clamp meter to check the current going to the LED.
I do like the Lenina-S and the efficiency with the VeroSE is really good; thing is I’d need to figure out a clear lens solution; which would mean building a housing, These housings I bought with the TIRs – still can’t believe I got them for $5 each. There has to be about $5 of aluminum – and that’s before it’s extruded, cut, ground, machined, and anodized. Just amazing. It’s like buying a $20 housing and getting a glass TIR for free.
prototype3a
Yeah. ~50k lumens from something ~7” in diameter ought to be fun. I’ll probably use the 6s16k lipo packs I have so the c/g is pretty far to the rear so you’re less likely to accidentally flash yourself. The hilarious thing will be that it can do 36k lm without really even trying.
LEDiL makes a lens that fits into the Lenina reflectors.
I ordered one of the StratusLED drivers to play with and also to see where its limits are.
One thing I may do is basically put a momentary switch in parallel with the pot so you have instant access to “turbo”. I was also thinking about doing something similar to allow for temperature regulation/protection.
LouieAtienza
There a re a lot of possibilities… I’d like build an array myself and control it remotely and program different configs with raspberry pi… But I have to get them running first LOLOL
LouieAtienza
So in regards to the Meanwell LDH-45-1050 boost drives, I cross-referenced COBs at DigiKey that operate between 35-42V and max 1.05A, and got some interesting result… CREE CXB1820, which tests at 2690lm @ 550mA, and up to 160-180% rated output at max current. And just over $10 each!
Some more at Mouser… a Lumileds L2C5 that does 4900lm 900mA, and CREE CXB2540 rated at 4860lm 1.1A.
prototype3a
The only downside to the smaller LES COBs is they’re not as efficient but you may not care about that if you have other driving factors.
LouieAtienza
Yes – for one they’re smaller… which means better selection of optics including lenses. Second, they could be better with reflectors for more down-range illumination.
The ones I listed above are still about 130lm/W even with the LDH-45 driven to max…
