I’d rather have a Osram “White Flat” emitter (or the new Boost HX, if available) and a decent linear driver with max output tuned to best performance of the emitter. Make the head a tiny bit longer, so the reflector can be a bit deeper. Get the focus right for best throw (obviously). Don’t change the battery size. Keep the 18650. Good idea to use the Blue™ springs.
Some background to the driver problems, and how DEL improved it with a simple mod.:
Nevertheless these FETs were poor, even with the gate driven with a full cell (4.2V minus Schottky diode drop, and sag/internal resistance) after DEL’s mod. At real world cell voltages they are far higher resistance.
See DEL’s graphs at GB BLF LuckySun D80-SE Need long tubes? -3/3/16 - #2417 by DEL and GB BLF LuckySun D80-SE Need long tubes? -3/3/16 - #2426 by DEL
As supplied, getting only half cell voltage, minus Schottky drop, with say a cell at 3.7 or even 3.5V, sagging further under load, they were barely operating. That’s ignoring the poor tail spring used.
For comparison, a decent FET as used in a good BLF FET+1 is in the 5 milliohm class, at all cell voltages.
I suspect that prototype evaluation was only ever done with full cells. Also by others here. Not realistic.
Then there was the suspicion that the prototypes supplied to Dale etc. had superior emitters, production units from lower bins. He could never reproduce the results with production units. Even then, they never took the current that would be expected with a good FET.
The PWM was about 150 Hz. Horrid. And maxed. at 98% on turbo, yet another loss.
Then there was the nonsense with the tailcap switch retaining ring. Originally it had a shoulder on it to contact the tube, but they were sloppy, forever coming loose, and even failing to hold together at-all. My early one suffered this. So instead of doing it properly and going to a LH thread and making the threads fit properly they removed the shoulder and cranked them in super-tight, nearly to the point of stripping. But in removing the shoulder they forgot to lengthen the tube to compensate. Hence all the short-tube problems, and the need to make longer replacement ones, at extra cost. Famously Kronological “totally missed this”.
I just glued mine together with threadlock, which probably makes the switch unmaintainable.
Like I said, attention to detail is everything, as the FW3A team have found. Sometimes it seems like one step forward, two back.
If Lucky Sun can step their game, this would be a nice refresh. The original team sometimes expressed frustration at communication difficulties and un-discussed changes, for what should have been a straightforward tweak of an existing product, basically LED, MCPCB, driver UI changes, new logo, job done.
For this to be good, I see it needing a lot more work, but worthwhile.
Yes, a modern emitter with a lower Vf (seems to be the trend), together with a linear driver, even just an inexpensive stack of 7135s, would be better.
Lower Vf. meaning more consistent and efficient performance as the cell droops in real-world use, efficiency actually improving as the cell discharges and the LED Vf. vs cell Voltage transfer characteristic reaches optimum. Unlike FET drivers.
Reflector redesign and fine tuning essential to match emitters. This one is very finnicky to get right if you try a different LED, without obvious beam artefacts. It is already struggling to achieve balance of throw vs. spill, being so shallow.
Remember throw comes only from the reflector and the sideways projection of the LED. The spill is what shoots out of the front of the LED, missing the reflector entirely. Therefore precise LED characteristics will be very important.
A deeper wide reflector makes this much easier. And better. But that would not be a D80.
I`m way too green to have any useful suggestions however put me on the list for one whenever they are ready.
johnkey68 that is a very nicely composed picture.
Well, I was just asking for it to be a bit deeper. Don’t change the aesthetic too much, as others have said. I was never a fan of the Aesthetic of the D80, but I will probably buy it if they end up using the “White Flat” or the Boost HX emitters. I want a super-throwy hand-size light just to impress people with. I’m considering getting a GT Mini and/or Micro, but I’d be happier with one of these Osram emitters, perfectly focused in a well-designed reflector. :money_mouth_face:
The white flat could do it I think. Along with the other flat surfaced emitters that shoot light out sideways in a Lambertian manner.
Once they have a dome on, it changes for the worse (for throw). Hence all the de-doming discussions.
Of course there is far more to it than that.
But, fundamentally, the shallow reflector is unlikely to be the best for throw. Plenty of other, better, already available options for that, you have mentioned some.
It is a compromise, not really a great thrower despite what some would have you believe, more flood than I need. But that’s inevitable considering the dimensions.
If you have not held a D80 you may not appreciate the aesthetic. In the hand it is very nice (I think). Don’t be put off just by photos.
It is great in hand. The reflector is great too. I have one with Bistro and a MTN-17DDm driver. It works wonderfully. No need to reinvent the wheel here.
Get the battery tube length right. I recall I had to buy a longer one separately to use my button top cells.
And I haven’t figured out what to do with the old slightly short battery tube.
Well heck, I must be the lucky one. Added DD driver and can’t complain about it at all. But then, I’m not a perfectionist.
The fault finders will find fault, even while in Paradise. But, that is what it’s all about here at BLF.
Added DD driver and can’t complain about it at all.:+1:
There you have it. It just needed a decent driver, the other niggles could be fixed up, with patience and perseverance, and some frustration.
Should not have been necessary for a BLF special, these are supposed to be well developed and good as-is, not the beginnings of a modding project, unless that’s your interest.
But it was a 2015 tweak of an earlier design, and things have moved on a lot since then, so a proper refresh could bring it up to date nicely and make it relevant again, rather than just a warm over of the original. Working properly it is a nice torch.
Several other BLF designs were right first time, live on still, have more than repaid their manufacturers’ faith in BLF engineering input and rigorousness, in continuing sales, and are still highly recommendable.
This V2 could do the same. Worth the effort.
I’ll duck out now, I’ve said more than enough. If the OP wants to pursue this I’d be glad to help where I can, behind the scenes. I’d like to see it succeed.
If they want to use a deeper reflector for some of the small die emitters on the market now they could just design a taller bezel and extend the new reflector into the bezel.
This way a new casting of the head would not need to be made.
Speaking of bezels, how about optional Foy bezels? Stainless of course.
Just a thought.
Also if they are rebooting the concept, how about some new colors?
That Olive drab that Klarus has might be nice and maybe some Reds, Blues.
Laterrrr
Keith
I could not sleep so i wrote with my LS contact. Like it was said in other projects language is a huge barrier. And LS is not a huge company. So i do not think it would work out well to go with a Osram throw led + getting a reflector made (with prototypes a lot of testing . . . . . .).
If we had a contact there that could explain everything in their language i would go for it.
The D80 is having good throw and it would fit nice. But as it is i see way to much potential for a crash and burn.
After this short time i would say most people like the light and would be happy if they could get a fixed up version (tailstand, tube length, springs,driver,reflector quality increased and led hole size reduced. . . .) with new internals, UI. . .
To me, this type of question is a slippery slope. How much of the original can you change before it becomes something entirely new? (like an old old rock band that has none of the original members but still carries the same name )
I’d say refine details only if this is a D80.2 think-tank
Things like:
Improved reflector geometry/finish
Better springs
Double o-rings
Thermal management
New anodizing
Latest firmware/driver
LED options (for the non-modders)
blf d 80 is one of the very best special editions ever….
it looks great and has a great beam
improve it to what it should have been the first time
new driver, new led, dtp and good springs
at the same time, start working on a 21700 model with new xhp led
new driver, new led, dtp and good springsat the same time, start working on a 21700 model with new xhp led
Prefer 21700 too for me.
I think i found a way to improve heat dissipation (without changing the look). But i only have my tablet with me in hospital. So i search for someone that can help me to make a pic or 3d model to show BLF (and LuckySun if most people think its a good idea) what i have in mind.
If you want to help please PM me.
I hope it is clear to see on the pictures what i have in mind.
By adding material on the inside (creating another 2mm step a few mm below the first one) we could cut the lower finns deeper. So more surface area is in contact with the air (better heat dissipation). And if we make the driver cavity 2mm less deep we could add this 2mm to the led shelf (it is very thin at the moment).
Could someone else check his D80. I want to know how good the front lens sits. On my light the o- ring below is not compressed. Even the bezel is screwed in full.
This leads to bad sealing and no preasure on the mcpcb. This could be addressed by shorten the head on the front by ~0,5-1mm. This would also help to press down the mcpcb with the reflector a bit.
I hope some of the BLF driver gurus can help us. At the moment there is no updated driver layout available that can run Bistro HD OTSM without problems. And i really would prefer not to count on the driver manufacturer to make the layout changes.
Do you have the ability to test the effect of various fin designs? I’m not an expert in the field but my engineering background makes me suspect that if you decrease the spacing or deepen the fins, it may not have the airflow and thus, the heat dissipitation you want.
Logically speaking, what deeper fins between the body and head can probably do is lessen the heat transfer from the head. Decreasing the mass snc increasing the fin area there “should” help out by keeping the body cooler…and holding it longer.
Thermal cameras and empirical testing is our friend.
