Eneloop went thorough the washing machine
29 posts / 0 new
Trippwire
Last seen: 1 year 2 weeks ago
A loose aa eneloop went through the wash, is it safe to use once dry? A quick google search says I should throw it out as water would have gone in the vent hole. Another search result says dry it and if it charges its fine…
Surely I’m not the first one on here to do this, any thoughts? I don’t want to damage any of my lights for the cost of a new battery.
bilakos10
bilakos10's picture
Last seen: 12 hours 46 min ago
I wouldn't use the cell in a good flashlight, or any other device that I care about.
The chance of a NiMH leaking is very low, but it can definitely increase after going through a wash cycle Smile
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 22 hours ago
Well, was it completely dry?
If not, then I would not trust it.
WalkIntoTheLight
Last seen: 2 months 2 days ago
The vent hole should only open when the internal pressure inside the battery gets so high that the cell needs to vent gas. It shouldn’t allow water into the light.
I’d run it though a couple of full charge/discharge cycles, and measure its capacity to make sure that it hasn’t been damaged. Then leave it for a couple of weeks, and make sure it doesn’t self-discharge much, or show signs of any leaks. If it checks out okay, go ahead and use it.
Henk4U2
Henk4U2's picture
Last seen: 3 min 36 sec ago
And don’t lose your charger out of sight!
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
JamesB
Last seen: 4 hours 45 min ago
I would toss it, for peace of mind, eneloop are so cheap.
sochi111
sochi111's picture
Last seen: 9 months 2 weeks ago
I would bury the AA in rice for a day or 2 and then leave it alone for a few days and then charge discharge etc just as Walkintothelight described.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 5 min 18 sec ago
I done this to a AAA Eneloop its still okay. I was hesitant do use it but i left it for a weeks and it held charge fine.
Tumbleweed48
Last seen: 5 hours 2 min ago
I’d never toss something that I could learn from – I’d be letting it dry thoroughly for a few days (the rice method is fine, but the humidity here right now is 20%) and then putting it on the charger. Sure, Eneloops are cheap but science comes first! Big Smile
Science test to see how fast the firefighters can get there? lol Silly
WalkIntoTheLight
I don’t think NiMH can catch fire. If this were lithium-ion batteries, yeah I’d be more concerned.
hank
hank's picture
Last seen: 16 hours 9 min ago
Here’s a site that tested six common household materials for their ablity to dry out soaked electronics:
https://www.gazelle.com/thehorn/2014/05/06/gazelles-guide-water-damage-t...
kuzuna
It should be noted that while getting water out of electronics is well and good, if corrosion has already happened, drying them out may not help. And corrosion can happen FAST, especially if the device is on when it gets wet. I’m talking within seconds of getting wet for certain components.
Nev
is the AA eneloop clean ?
Lightbringer
Lightbringer's picture
Last seen: 7 min 7 sec ago
It is now
teacher
teacher's picture
After the thorough cleaning did it retain any charge?? Just curious….
Firelight2
Firelight2's picture
Last seen: 1 hour 46 min ago
Holy cow! I had no idea Coke could destroy a computer so fast! Sick
Lightbringer
Wellp, a few things…
Perhaps he should look up “electrolysis” when he talks about “corrosion”.
Coke has phosphoric acid. Perhaps he should look up “naval jelly”. It’s used to clean crapped-up objects down to the base metal, dissolving nasties along the way. It also has phosphoric acid.
Also, he’s running 18V through that board, vs just dropping it in a deenergised board. Back to “electrolysis”.
Last, I’ve heard of people dropping phones, etc., into puddles, toilets, etc., but not into buckets of coke. Back to phosphoric acid (vs plain water).
It’s like he’s complaining how badly oven-mitts can get burned on a stovetop, but then turning on all the burners and dumping gasoline all over the stove. “Wow! Lookit all that damage to the mitts in just a few seconds!”
teacher
teacher's picture
Wow!! . Shocked . Very interesting video kuzuna, thanks for sharing it. Thumbs Up
I’ll say it again Lightbringer, you have a great way with words!! . Thumbs Up Your cracking me up with your analysis. An accurate analysis too I might add. Wink
Firelight2
All true.
However, the video did have a point:
When people accidentally drip Coke into their computer, it probably IS powered on. And it sounds like the damage can occur in just seconds with an energized board.
teacher
teacher's picture
/\Thumbs Up … That too. Wink
Lightbringer
teacher wrote:
Wow!! . Shocked . Very interesting video kuzuna, thanks for sharing it. Thumbs Up . I’ll say it again Lightbringer, you have a great way with words!! . Thumbs Up Your cracking me up with your analysis. An accurate analysis too I might add. Wink
I just get really tired of all the disgustingly dishonest clickbait on yootoob.
It’s almost as bad as the “10 things in your kitchen that can kill you! News at 11…”. (Carving knife, meat-cleaver, skewers… uhh, yeah, and…???)
Or the “road-rage” flicks showing some very-well-endowed chick in a spraypainted-on sweater… who’s nowhere to be found in the entire vid! Wtf??
Lightbringer
Wellp, I might accidentally drip something onto/into my keyboard, but I’d have to be actually physically climbing on the desk to drip something into my computer.
And anyone who slovenly drips cokola into a phone either has to live in a sty and drips everything everywhere, or just plain deserves the results.
I’m having a really hard time finding sympathy for either.
Firelight2
Hahaha yeah.
I know someone who accidentally tipped their Coke into their desktop computer years ago. He had his desktop box positioned in such a way that a spilled drink would go right in. Some poor planning there. Facepalm
It died instantly. Never worked again.
Lightbringer
Is he one of those who used the cd-drive’s tray as a cupholder?
I’m telling ya, I see people do things where I’d swear I can hear the Loony Toonz theme playing in the background…
Boaz
Boaz's picture
Last seen: 9 hours 57 min ago
Clean energy ?
Rice seems like a great idea .
 Now what happens when you run it thru the rice cooker ?
Eneloop .... will it blend ?
teacher
teacher's picture
A CD-Drive tray as a cupholder…… Facepalm . Facepalm
My, my… Loony Toonz for sure!! Kinda scary thinking they have already, or may breed one day. Big Smile . Big Smile
Trippwire
An update, it was at 1.3v when it got dried out. Charged up as normal, operates as normal. I guess it’s ok.
teacher
teacher's picture
Thanks for the update Trippwire, that sounds good. Thumbs Up
