In the minimax series of lights I looked at on their website some use only the printed manual as their entire item description and others say nothing at all about the light except the following warning message:
This is the MM18II entire product description from the manufacturers website. I’ve seen non-detailed item info but this is a whole other level:
DETAILS
MM18III
Warning
Please caution when using higher output levels. Light body gets hot when the light is on for long period of time and avoid shinning the beam directly into the eyes. This product is high power device and capable of causing eye damage.
Specifications are subject to change without prior notice. Please always refer to our official site for the latest information
Specifications are subject to change without prior notice… means we don’t really know what it does but it’s bright… you should buy one!
I think, that 191mm Diameter is wrong for the new thrower ! May be they mean 101mm…
My luxmeter shows 517.680 cd for my BK-FA30S and 117.400 for my MM18III.
Niwalker made a mistake, the add an 0 to their cd for MM18III…
I think, that 191mm Diameter is wrong for the new thrower ! The discription shows 91mm !
My luxmeter shows 517.680 cd for my BK-FA30S, 117.400 for my MM18III and 41.000 for my MM18Jr.
Niwalker made a mistake, the add an 0 to their cd for XHP70 of MM18III and it looks like they made the same mistake at the new MM18JR…
@freeme: The discription shows three colours (black, blue and red). What colour does it mean, the anodisation ?
We have a long conversation with them on this issue. Candela value will corrected to correspond its distance value. As for the throw distance, it is up to them to decide.
so based on Maukkas reviews their lumen outputs appear to be bang on. to jump from 2200 in the BK-FA30S to 2600 in the two new ones is a 20.1% increase in output so it definitely looks like it's possible to achieve the additional throw.
Unfortunately the MM18JR didn't even come close to the throw specs but if they're indeed driving the leds 50% harder up to 15 000 lumens maybe they finally achieved the previous throw specs which were way over actual spec or they're only driving the 70.2s 50%+ harder to achieve the lumens and will have similar dismal throw specs lol I can't decide if I need them or if I should just save my pennies for the eventual MF03 or MF05 or GT4...
