MF5SV1 is the one I am interested in thanks
[♛ FreemeGB] 2019 Niwalker Group Buy, Rare Opportunity - MF5SV1 / BK-LR7SV1 / BK-LB11SV2 -【 ACTIVE 】
I dug everything up I could to try and estimate:
lumen claimed | lumen tested | candela claimed | candela tested | throw claimed | throw tested |
BK-FA30S | 2200 | 2199 | 650 000 | 563 000 | 1600m | 1501m |
LR7SV1 | 2650 | 903 500 | 1900m | |||
LB11SV2 | 2650 | 903 500 | 1900m | |||
MF5SV1 | 10 000 | 9 350 | 440 000 | 61 000 | 850m | 494m |
MM18JR | 15 000 | 440 000 | 850m |
so based on Maukkas reviews their lumen outputs appear to be bang on. to jump from 2200 in the BK-FA30S to 2600 in the two new ones is a 20.1% increase in output so it definitely looks like it's possible to achieve the additional throw.
Unfortunately the MM18JR didn't even come close to the throw specs but if they're indeed driving the leds 50% harder up to 15 000 lumens maybe they finally achieved the previous throw specs which were way over actual spec or they're only driving the 70.2s 50%+ harder to achieve the lumens and will have similar dismal throw specs lol I can't decide if I need them or if I should just save my pennies for the eventual MF03 or MF05 or GT4...
MF5SV1 ordered, thanks freeme.
MF5SV1 should be brighterrated 5Klm more. They added knurling on battery tube to improve grip.
Thank you.
I also think the usable reflector is actually quite a bit larger.
While the head diameter of the 1st gen was 100mm, it had a 89mm reflector.
With a head diameter of 101mm, maybe it has a more optimized reflector for focus along with a physical larger head(maybe 93-95mm?)
Interested, Had a great deal with the BK-FA30S, Thanks
Interested.
Interested in MF5SV1 if available in NW
Sent.
TIP: Remember to login your Niwalker account before applying my coupon codes.
Need code for MF5SV1. Very interested.
Something went wrong today. I will send them out when it is available again.
Is the only difference between the two throwers the magnetic ring switch?
Yes.
Any fears on the functionality of that ring? The only time I’ve had one was with the Thrunite TN32. Never had problems, but other than that, don’t have to much experience with those.
Niwalker BK-LR7SV1 is a brand new design. It is 16mm longer and has more mass to dissipate heat than BK-LB11SV2.
All replied. Pm me if coupon is invalid or has expired.
Buyers, please login your account to verify your order is in place.
There has been some hiccups on their site, but Niwalker was with me the whole day to address to every single issue. If you noticed any unusual activities, do alert us ASAP.
Fingers Crossed
