Sofirn C01S SST-20 4.000K 95CRI / Low-High version available again!
694 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 11 min ago
Lo and behold...here is the thread about the new Sofirn C01S
The Sofirn C01S is a single 1.2V/1.5V cell AAA twisty with a HighCRI Luminus SST-20 LED (CCT 4.000K, 95CRI). If you are looking for the predecessing Sofirn C01, please click ► here ◄.
Pictures courtesy by Sofirn @ AliExpress (see order link)
Some specs about the light:
Emitter: Luminus SST-20 4.000K 95CRI
UI: twist head to turn on/off, quickly loose and fasten head to switch between 100lm / 3lm modes
Mode Order: High-Low
Battery: 1.2V NiMH or 1.5V Alkaline AAA
Size: 71,6mm in length, 14,5mm in diameter (head)
Weight: 15g (without batteries)
Body Colour: Black / Blue / Red
Price: Currently, there are no group buy conditions available. The C01S was offered during pre-launch for $ 8.88 and later on for $ 10.99.
Order link via Sofirn's shop on AliExpress:
Standard C01S (mode order: high - low)
https://www.aliexpress.com/item/32952525303.html
C01S BLF edition (mode order: low - high) - first batch sold out Sad
https://www.aliexpress.com/store/product/BLF-C01S-Mini-LED-Flashlight-AAA-Twisty-High-95-CRI-SST20-4000K-LED-keychain-Flashlight-Hat/2933049_33013541411.html
New revision as of late 2019:
Black: mode order high > low
Red/Blue/Gray: mode order low > high
C01S grey edition (mode order: low - high) is available now
https://www.aliexpress.com/item/33013541411.html
Diffuser caps can be bought from Sofirn here:
https://www.aliexpress.com/store/product/2pcs-lot-White-diffuser-for-sof...
Link to the user manual (German/English) on my sharepoint:
https://drive.google.com/drive/folders/1VFoxQ1hc2rKUoilGJK7i9GGg_Hd_WKQv...
Please note that I was asked to not change the name of the flashlight in the manual as it has already been printed with its former project name "C01 Pro" and is part of the content of each shipped C01S now.
BLF special edition of the C01S
Djozz is in negotiation with Sofirn about a special edition for BLF members. It is planned to differ from the original version as follows:
- reversed order of modes (L-H instead of H-L)
- clear anodization instead of black/blue/red
- BLF insignias
... [to be supplemented]
Update 2019/03/14
  • Sofirn confirms possibility for approx. 200 pcs w/o anodization (no clear anodiozation!)
Update 2019/03/15
  • Reversed mode order is feasible
  • Insignias are yet to be defined (e.g. "BLF C01S", "C01S BLF edition")
Update 2019/04/15
Update 2019/04/24
  • BLF edition is produced but mode order was wrong and needs to be reworked on the lights. Thus, Sofirn needs to remove the drivers and reinstall them again. There's a chance that drivers will become loose and need to be re-glued (by the customer).
Update 2019/05/13
Update 2019/05/23
  • First batch of BLF edition is sold out completely
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
Edited by: Lux-Perpetua on 01/20/2020 - 04:57
Lux-Perpetua
Some of my impressions about the Sofirn C01S in comparison to the Sofirn C01
Both flashlights were bought by myself at Sofirn's shop on AliExpress.
Date ordered: 03/08/2019
Date received: 03/28/2019
Close-up of the C01
Close-up of the C01S
Comparison of size and light source
Comparison of beamshots/whitewall shots (WB: 4.000K)
Some final words:
The C01S is a very nice and useful keychain light that comes in 3 different colours you can choose from. Sofirn managed to use another HighCRI emitter with much more power than the Yuji BC in the C01, the Luminus SST.20 4.000K 95CRI. Both flashlights arrived well packed and without any obvious defects in build quality. In fact, the quality of both lights is very good, the chosen tint in combination with the lens in the C01S is very appealing. While the C01 with its low output und floody beam is more or less good for reading purposes at night or for close-distance orientation the C01S can also be used in situations when you need more than just "a blink of an LED" Wink . 100 lumens is very useful even when outside with the need to look farther than just before your feet. Since there's a special lens in the C01S you get a nice spot with useful throw. On the later/new batches of Sofirn's C01 they must have reworked the reflector coating as the first samples had a very smooth beam profile while later ones show a distinct spot with more intensity.
What could be improved?
  • I would have preferred a reversed mode order (low-high instead of high-low)...don't miss the chance to get the BLF edition that should come with a reversed mode order Wink
  • The front end of those clips look somehow bent a bit leftwards when attached onto the lights, see picture above. They also come off too easily when you pull on them. It's nothing serious but maybe worth to mention.
  • Threads are totally dry. A small bit of silicon grease would be the icing of the cake, if there's anything left to complain about.
Cheers,
Thomas
teacher
teacher's picture
Last seen: 9 months 2 weeks ago
Nice job Lux-Perpetua!! Thumbs Up
Lux-Perpetua
Thanks for your kind feedback teacher! Roll tide! Smile
djozz
djozz's picture
Last seen: 19 min 55 sec ago
Thumbs Up Will report when mine arrives too (package has not left Sofirn yet)
teacher
teacher's picture
Your welcome my friend!! Thumbs Up . ROLL TIDE!!
I love that picture….. Beer
lotrbfme
lotrbfme's picture
Last seen: 13 hours 48 sec ago
Ordered 1 at $8.88 price
rost333
rost333's picture
Last seen: 1 month 4 days ago
djozz wrote:
I am in conversation with Barry about a BLF version of the C01S, I hope to achieve a version with the mode order reversed (so start in low)…
This video (https://www.facebook.com/sofirn.cn/videos/1989311321364409) shows that C01S is starting with low mode first.
I’m confused. So which mode is first one? Low or high? Can someone clarify please? Thank you! Wink
Tech25
It looks like high- low to me. They put in the battery and screwed it in all of the way onto high, then when he put it in front of his hand, he turned it onto low and then continued the cycle.
djozz
djozz's picture
That took 3 views to unravel: she (small hands btw) switches it on (high), then off, then on again (low) then off-on (high). The off-time after the first switch-on was short enough for the driver to detect a mode change instead of interpreting that as a switch-off.
So my conclusion: high->low
rost333
rost333's picture
Yes, thank you, it’s in line with their description on Aliexpress page: “no memory function and default brightness is High mode”.
mortuus
mortuus's picture
Last seen: 3 hours 36 min ago
looks interesting, on bg its a long date ahead before they get in stock it seems Sad i will order it later i guess. I asume using 10440 in this light is not working ?
...where Frugal meets with Flashlight!
Di_Joker
Di_Joker's picture
Last seen: 3 hours 1 min ago
Low mode 3Lm seems useless to me. Optimally it would be low mode to make 10-20Lm.
Sorry for my poor english.
MtnDon
MtnDon's picture
Last seen: 1 hour 36 min ago
Looks like a nice little light.
Depends. There will be many opinions on what the lowest brightness level should be. They are all correct for the particular user.
Myself, I prefer around 1 to 2 lumen maximum for the lowest level. Even lower if there is a Medium level as well as Low and High. My favorite general purpose pocket light has 0.5 lumens as the lowest, then 7, 70 and 250. (4 in total with the highest seldom used.)
If you are in a truly dark place that is plenty of light and usually not enough to shock your eyeballs. Totally useless if there is any amount of background light, but ideal if you are in a truly dark place.
I do prefer lights to start on the loweset setting and cycle up and back around. I can’t think of many times I have wanted a light to come on in the brightest mode.
shirnask
shirnask's picture
I find 0.5 Lm to be very useful and starting on high a big disadvantage
mortuus
mortuus's picture
no its not, in total darkness even 1lm is more then enough for a light and to save battery.
lightboks
lightboks's picture
Last seen: 9 hours 10 min ago
I find 3 lumen low pretty ideal for general use on a keychain. you don’t always use these in pitch black, so a bit more is alright.
If it had firefly/moon, I actually would have preferred a 3rd low mode at 8-10 lumen, but that’s what the thrunite ti3 and astrolux a1 are already doing.
but yeah, for me the BLF low-high version would be nicer.
But ideally, it should work like in that old discontinued pre-2014 Thrunite AAA twisty light: head fully tightened for max, slightly loose for low, unscrew further for off. That would be ideal. Too bad I missed this light back then, would buy 5 of these.
rost333
rost333's picture
- Any word from Barry about BLF version?
- Is clear anodization essential?
- Could we ask for copper head version?
lightboks wrote:
I find 3 lumen low pretty ideal for general use on a keychain. You don’t always use these in pitch black, so a bit more is alright.
+1
gchart
gchart's picture
Last seen: 1 hour 29 min ago
Lux-Perpetua wrote:
BLF special edition of the C01S… reversed order of modes (L-H instead of H-L)
If this happens, I’m in for a few!
P33
Last seen: 17 hours 32 min ago
Copper version would also be great.
djozz
djozz's picture
Quote:
- Any word from Barry about BLF version?  - Is clear anodization essential?  - Could we ask for copper head version?
1)Yes it seems like there is going to be one, 200 pieces without anodisation (took half a year to convince them that there are people who actually would want an unfinished flashlight), but no confirmation about low first yet. Btw, I’m not going to arrange a dedicated group buy for this, I’d be ok with that it just goes for sale at the Sofirn store.
2 and 3) based on a longterm discussion about the C01, I believe a no-ano version is nice as a BLF-special, and it is clear from the poll that most people want the mode order to be low->high so that is what I asked as well. Sure there will be endless other possible versions thinkable (my own preference would still be purple Party ) but I think this version is a good choice that many will appreciate.
P33
I’d defo be getting one of clear ano versions. No matter what the mode order is. It doesn’t really matter to me in such a small light.
djozz
djozz's picture
This not about clear ano, but no ano at all. This will look and feel more rough because it is in fact what comes straight out of the CNC machine. That is why they don’t get why we want this Big Smile .
polarweis
polarweis's picture
Last seen: 1 week 4 days ago
no ano blf edition sounds good
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
sochi111
sochi111's picture
Last seen: 11 months 2 weeks ago
No Ano looks polished and shiny or has a matte layer of Alum oxide ?
P33
For me it’s gonna be a keychain light, anodization will be gone in no time anyway so I’m fine to start without it in the first place Smile
rost333
rost333's picture
After seeing this beauty I changed my mind and now I’m all in for clear version.
mortuus
mortuus's picture
haha thats funny, sofirn shakes their heads why anyone would want a raw unfinished light.. Big Smile
djozz
djozz's picture
I think that the beauty of a rough and used tool does not fit in chinese culture.
Barry confirmed that low->high will be possible, he asked for what lettering it should have and I suggested C01S BLF no-ano edition, or if too long C01S BLF edition, or if too long C01S BLF Ed. Any objections or better ideas for the text?
rost333
rost333's picture
That’s great news Smile Thanks djozz!
djozz wrote:
200 pieces without anodization
So will there be a limit per order per person? I would buy more than one if that’s possible.
djozz wrote:
…he asked for what lettering it should have and I suggested C01S BLF no-ano edition, or if too long C01S BLF edition, or if too long C01S BLF Ed. Any objections or better ideas for the text?
C01S BLF edition would be great imho.
hodor
hodor's picture
Last seen: 3 hours 35 min ago
How about BLF C01S?
