The EDC05C is D-E-D right now, gotta try a charge. Can't see a way to get at the battery - might be the SS tail embedded cap unscrews. Will check it out down in the flashlight lab...
I must have been on FB with Neal talk'n bout it, and just forgot. Think they were gonna release it months ago, then it didn't happen. FB is acting up on me, real slowwwww right now so can't check. I've been interested in the dual LED lights like the SD Mini II which I have running with a special mod to NarsilM and cut/jumpered a driver to separate the 7135 from the FET - it works pretty well now.
EDIT: Ohhh, ok. The EDC05C's tail can unscrew with a regular screw driver or slim coin I suppose - sure enough there was no battery in it. UI works pretty well:
lo/mid/hi on the main LED, plus press&hold from OFF to access a low low
Dbl click from OFF or ON to switch to the side light, then lo/mid/hi on the side panel - pretty bright on a WindyFire 14500
press&hold to turn OFF, clicks to switch thru lo/mid/hi
The bezel is not notched so hope can use friction to unthread the bezel - if so, then should get access to the main LED and driver. Main LED looks like a CW XPL HI, with an OP reflector.
The GT Micro doesn't have a driver spring, but what looks like a button contact - I had one 14500 that couldn't make contact, but the button tops I got worked fine (gold VapCell 1000 mAh, EFEST 650's, etc.). In the tailcap it has the double spring we expect.
I got the NW version and doesn't seem to be a well defined hot spot, but maybe because of the small reflector. Tint is nice, maybe a little heavy on yellow in the corona. Seems like a warmer NW, maybe a 5A/5B/5C or so. The 5D's I got look better, but haven't carefully compared them.5D - comparing the,. looks very much like my 5D's in other lights.
Using a gold Vapcell 1000 mAh BT at 4.20V:
on max ramp: 1.93 amps, on turbo: 3.3 amps
on max ramp lumens: 586 (TomE) or 516 ANSI, both at start
on turbo lumens, start-15 secs: 1020-945 (TomE), or 900-839 ANSI
throw on turbo: 53 kcd (460 meters) taken at 5 meters
It's a nice look'n little pocket light. The new higher capacity 14500's are a good match. I got 4 of the gold Vapcell 1000's. I'll re-do the tests on a new EFEST 650 BT to compare.
Update:
Using a new EFEST 14500 flat top from MtnE @4.20V, I got much better results. Should be expected because it's rated up to 6.5 amps, plus flat tops are better:
on max ramp: 3.62.6 amps, on turbo: 5.0 amps
on max ramp lumens: 740 (TomE) or 650 ANSI, both at start
on turbo lumens, start-15 secs: 1275-1160 (TomE), or 1125-1020 ANSI
throw on turbo: 62 kcd (498 meters) taken at 5 meters
The Micro is still all stock at this point.
The obvious light to directly compare to is the Emisar D1, being they are similar size and similar head diameter. The D1 has the big advantage of an 18650 cell, but for some reason, I'm getting better throw #'s from the Micro, least what I measured back when I first got the D1 in it's stock setup. It should be noted the Micro has a deep reflector, and the diam/depth ratio seems to match exactly to the GT Mini - fairly narrow compared to most other small lights that dont' have the reflector depth this light has. It's an interesting difference, pretty unique for the Micro in such a small light.
Those 1000 mAh cells are sold under different brands I believe. Went nuts last night trying to find where/when I ordered these from, I think I have 4, definite 3 on hand.
Jon on Liionwholsale has them here though. The SANYO 840 mAh 14500's have been around a long time. I got a bunch but they are old, still expensive to buy - Richard sells them.
I tried to get cells from Liion Wholesale yesterday and the shipping rstes were ridiculous! Cancelled out and went over to IMRBattery where cell prices were a little higher but shipping was only $5.99 UPS Ground. Ordered yesterday and they will be here today.
I saw those 1000mAh Vapcells but current was so low they didn’t interest me at all. IMR was sold out on the Purple Efest 14500’s.
Yea, something happened with Liionwholesale shipping costs - agree, they are ridiculous now - for me, $7.50 for qty 4 of 14500's. Illumn, same order, shipping is $5, and they are west coast.
They'll be losing some biz for sure. For me, orders would have to be big with them.
Comparing Illumn vs. Liionwholesale for qty 4 Vapcell 14500's, $19 for Illumn, $24 for Liionwholesale. For these, Illumn is cheaper on the batts, cheaper on shipping.
My two GT micro lights and batteries just arrives.
Small…
Tested and they both looks fine.
(A little “flickering” on both, at the lower end of the ramp, and then it stops.) !!??
Thanks to all involved.
The little flicker might be when it switches from the FET to the 7135. I can see it in mine as well. It’s barely noticable.
Also keep in mind that narsil gives a single quick blink at the bottom and top of the ramp. This might be what you’re describing, the blink at the bottom.
Yes, sounds like the normal fast blink to show you reached the max or min.
I'm finding this little bugger can throw pretty well. It's beating my D1 with the D1 having a big advantage of an 18650 cell. Of course the problem is the Micro won't last for very long...
DHL just left, I eagerly rushed in the house and ripped open the bag, cut the tape on the box inside, pulled out the bubble wrapped black box… huh? A Fireflies box? Not 2 GT Micro’s? Nope, a black Fireflies E07 with a Samsung 40T inside it.
Actually, looking at the Fireflies website this particular light and with DHL shipping comes to $105 so someone is probably mad to have only gotten 2 GT Micro’s in their package. lol
This is a matte black E07 with XP-L HI 6500K emitters and the Samsung 40T inside. That’s a $20 extra for the emitters and $15 extra for the cell. Not sure how Neal is going to work that out but…
While that sounds good and all, the likelihood is quite slim. I’d be game to get it swapped out if the other party is even in the US, reckon we’ll figure all that out when he finds out what happened.
I missed this post earlier. Did you ever get a copy of the code for this light?
There have been a handful lights lately where I haven’t found any indication of distributors actually following the license. Sometimes I try to chase these down and work toward a resolution, sometimes I put it on my todo list and then never get to it. It’s not really supposed to be my responsibility though, or yours, unless we’re actually involved in making the light.
This helps, but it may be a good idea to look over the license again. It allows for several solutions, but this isn’t one of them. The closest method is shown in section 6c:
For commercial purposes, a less ad-hoc method is needed. Ideally, the info and links should be posted somewhere visible to the public and easily discoverable, like on the manufacturer’s page for the product and on the retailers’ sites. However, it can also work to put that info in the manual or otherwise on materials which ship with the light. Specifically, it needs to be somewhere “prominent”… hard to miss… having a quality that thrusts itself into attention… conspicuous in position or importance.
The companies involved typically aren’t aware of this though, so it’s kind of up to us (whoever is working with those companies) to make sure it happens.
A prominent notice and a copy of the code.
And, although not legally required, it’s generally nice to let the upstream author(s) know about it, try to get any changes merged back into the upstream code, and link to their project. Not just for the warm fuzzies, but also in the interests of keeping things clean and straightforward.
