okok, i just think keeping the same size while on papers increasing lumens that much isnt maybe so good idea but what do i know xd, i mean that much lumens needs a bigger host imo but ofc this is they who decide, i can only try think a little bigger wouldnt hurt. im sure this will be a bestseller tho like the previous one which i like alot.
I said the same thing, I had to fight for the little change they did allow. This is why the thermal protection is so important. Left unchecked it will get WELL over 100C. I would stop the tests at ~105c but it was still climbing.
I will say it is a potent light as it is. With Narsil ramping it is far more usable then it was in the old version. Plus the parasitic drain is 1/20th of the old light (~200ua vs 5000ua, although that is before the auxled’s which have not been tested yet).
This was in the plans early on but the lumen output was not much better then the XP-G3 / SST-20 and the cost would have to be higher with XP-L HI, so they scrapped that idea.
It is possible to swap the LED’s yourself but considering the cost of 18 xp-l LED’s I can understand why they decided to not do it.
I do have one here with the XP-L HI setup and it works good but honestly I prefer the SST-20 version and have been using it for almost everything recently.
Lexel, will the aux LEDs be adjustable or be able to be completely disabled from the main firmware, or only from the trimmers on the aux board? And if it’s just the aux board, they better make sure not to glue it!
