This was in the plans early on but the lumen output was not much better then the XP-G3 / SST-20 and the cost would have to be higher with XP-L HI, so they scrapped that idea.
It is possible to swap the LED’s yourself but considering the cost of 18 xp-l LED’s I can understand why they decided to not do it.
I do have one here with the XP-L HI setup and it works good but honestly I prefer the SST-20 version and have been using it for almost everything recently.
Lexel, will the aux LEDs be adjustable or be able to be completely disabled from the main firmware, or only from the trimmers on the aux board? And if it’s just the aux board, they better make sure not to glue it!
Yeah, the MT18 and MF01 are the same light, just a different logo. I just call it an MT18 as that was the working name when the project was started last year.
Size wise, it should be the same size as the MF01, just a little taller so we could fit the extra fins. I think the hand is just small and makes the light look larger.
