Lexel, will the aux LEDs be adjustable or be able to be completely disabled from the main firmware, or only from the trimmers on the aux board? And if it’s just the aux board, they better make sure not to glue it!
Yeah, the MT18 and MF01 are the same light, just a different logo. I just call it an MT18 as that was the working name when the project was started last year.
Size wise, it should be the same size as the MF01, just a little taller so we could fit the extra fins. I think the hand is just small and makes the light look larger.
A clear version with some bezel selections or even set! I want Orange!
Can these batteries be used with this light? I know performance will be reduced but I want an every day option with some safety. I am limmited by local tax limit:
They’ll either trip, or it won’t go anywhere near max.
edit:: actually, even samsung 30Qs were a squeeze into the MF01; I don’t think they’ll even fit. I’ll let someone more knowledgeable than I answer that fully.
Here are some comparison shots between the old MF01 and the new MF01S. I had actually not seen a side by side before, The new version is actually a little shorter.
