A clear version with some bezel selections or even set! I want Orange!
Can these batteries be used with this light? I know performance will be reduced but I want an every day option with some safety. I am limmited by local tax limit:
They’ll either trip, or it won’t go anywhere near max.
edit:: actually, even samsung 30Qs were a squeeze into the MF01; I don’t think they’ll even fit. I’ll let someone more knowledgeable than I answer that fully.
Here are some comparison shots between the old MF01 and the new MF01S. I had actually not seen a side by side before, The new version is actually a little shorter.
all this is correct, but in a 3-cell 18650 Flashlight (3P configuration, ) the body would be only 3-4mm thicker and 5mm longer with 21700 cells but around 40% more capacity and this make sense imo…(but not for this 2S2P configuration in this light, I know…)
