Here are some comparison shots between the old MF01 and the new MF01S. I had actually not seen a side by side before, The new version is actually a little shorter.
all this is correct, but in a 3-cell 18650 Flashlight (3P configuration, ) the body would be only 3-4mm thicker and 5mm longer with 21700 cells but around 40% more capacity and this make sense imo…(but not for this 2S2P configuration in this light, I know…)
im surpised still they want do a light 15k lumens and keep the size more or less to mf01, a little bigger would be better imo, i mean u cant expect a light this size be pocket friendly.
@Agro it would just be nice to see makers take use of newer cells and jump on it from this year, more capacity wouldnt hurt and light would just be a bit bigger not more but its astrolux deicision ofc, im sure this light will still be very nice even tho using 18650 only…
No, this is a very bad choice. You will want unprotected high drain. Panny B is a very old design rated at 5A continous and has very high voltage sag. Plus this version has an unknown pcb limit that might be as low as 3A. You can sometimes find 30Q cells for 4 x $20 or buy 2 for $11. Maybe two purchases of 2 batteries each at different times will get you under the tax limit?
