XTAR VC2S Colorful VA LCD Screen USB Charging Pro 17.99 14,85
Code gives “Invalid Coupon Code”
try code NA78
BTW: Pro means "Pomotion and the price should be lower now or soon (i got no time frame)
Ah didn’t know that! Thx. And yes code NA78 worked Thank you also for the quick response
Martin, did you get an answer if they renew the expired code for DGQ 4th Tiny 18650 GRAY? I found it with a lower price on AE than BG, but your coupon was even better. So, I’d like to know if there will be new/renewed coupon soon or if I should buy it on AE. Thanks
Now it’s sold out for a change, lol. Anyway, thanks for the code
Imalent original 26650 4500mAh battery
Code: A4P645UE
60% off for 20pcs or more
50% off for 10pcs or more
40% off for 1pcs or more
Hello my dear friend!
i got a nice list of deals for you:
Amazon.de deal
Sofirn hat mir den nächsten Blitzdeal verraten:
Dauer: Mar 20, 2019 11:10 AM ‐ Mar 20, 2019 5:10 PM
What firmware is the SP33 running?
It’s a Sofirn design with 5 well spaced brightness levels. Hidden moon light accessible from off with a press and hold.
Then you have the 3 main levels low, med, high which are memorized. You press and hold to cycle through them.
Then you have the Turbo mode which is accessible from on or off with a double click. One more click goes back to where it was previously.
One click for on/off.
It’s a boost driver running the 50.2.
I have a link in my sig with pictures and more details. It’s my current favorite light.
This is great. When did they change it? Or am I crazy? I remember a different UI from when this light was released. The UI you explained is a lot like Olight and Acebeam.
They came out with this new v2.0 using the XHP50.2 last November.
The first version used an xpl I think.
Wasn’t it click for on, click to cycle through modes, and long press to turn off? I think we had this discussion on another thread regarding the XHP50.2 version. I mentioned that the UI was a deal breaker because my E-switch lights all have almost the same UI. Except for some that have ramping firmware obviously. I might be wrong though…
You might be thinking of the older v1.0 light. I never bought that version because I don’t like that UI either.
Maybe we where talking about v2.0 before it actually came out so the written description was incorrect and we all assumed the wrong thing.
Thanks JasonWW
I created some kind of a UI chart for the SP33 V2.0 (XHP50.2)
A few more notes.
You can go from Eco mode to Turbo.
Double click from Turbo activates dual frequency Strobe.
From Strobe, a dbl clk goes back to Turbo. A single click goes back to last used mode.
That will complicate your diagram.
Thank you Jason! I will be glad to complete my chart.
And yes, it will be challenging to find some space for the missing parts of the UI.
