I’m only on page 3 so I don’t know if this has already been mentioned.
The MT03 has been known to have multiple issues. The locating pins in the tail cap breaking off, shorts in tail cap, the FET leaking and/or burning out. Also, not everyone likes the yellow corona of the 70.2. You kinda get used to it, but it’s probably ugly compared directly to this Emisar light. Keep in mind the MT03 is bigger and uses 4 18650. That can be good or bad depending on your preferences.
A 3x 18350 tube would be great. It would still output almost 10 000 lumens and be a huge advantage over the new MF01S. I’m sure nobody would complain about an almost cube formed flashlight!
Thanks @BlueSwordM and SKV89, I would have wasted some money experimenting with the 3500K, my favourite CCT if not your clarification.
It appears the best way to achieve a true below-bbl high CRI light is by mixing two leds with 1000K difference which already are on or slightly below the BBL.
So I’ll most likely go for a 5D HI version or wait till someone sources truly rosy SST-20’s.
Another option is to mod the Meteor with 4 VR21SP4 MCPCB’s with a total of 12 mixed E21A’s in R9080+ and some 20mm Yajiamei TIR LED optics
Keep shortening it and we’ll reach a form factor that I think should be called “Tuna Can Flashlight”.
Now that I think about it, a really flat flashlight with a ton of LEDs on the front could be the next big thing for pocket rockets. Maybe a smartphone form factor with a wall of LEDs or even a big COB on one side and a slim Li-Po to power it… That’s a discussion for another thread though.
We already have this. Smart phone sized, full of 2 color leds. You can change the tint from 6500K to 3000K. Built in battery pack. They use it for filming. They can’t handle much brightness/heat, though.
The best 3500k I’ve seen is my Tiara Pro quad E21A with 2x 3000k and 2x4000k. It is a good bit below the bbl even at low output. At max output, because how far it is below the BBL, it actually looks alot whiter/neutral than it should be for standard 3500k that looks warmish/yellowish. Just looking at it by itself, it looks more like 4000k. Another good 3500k option is the Oslon Square 3500k 92CRI, which is spec’ed at 5Q tint bin, supposedly very far below the BBL. It does not look above BBL for sure, more like what I would expect from a 6Q tint bin. It looks just below the BBL and not far below like the E21A mixed 3500k.
Clemence is coming up with some new MCPCBs for the E21A that will allow more options for this emitter. One of the most interesting ones is the 16xE21A mcpcb that he mentioned about in his thread. That should allow the E21A to output a good bit above the XHP70.2 with 9080 goodness.
Toykeeper, TA mentioned that there is an issue with active temperature regulation in Anduril for high output lights. Does RampIOS have ATR and does it have this problem fixed? I really hope it does especially considering the good heat shedding potential of this host.
I’m not sure of or why the marketing reason to go too big of a light for sales!
Profit in the long-run must be KING to stay alive and can not be forgotten for long run! Boil it down and you have to make a profit no mater who is offended even though flashlight folks are the easiest offended… Understanding its a give and take of service and product. Having 100’s of flashlights and use ONE everyday! I could float a battleship with Fivemega (Richard Socialist Head) Lights and even 18650 lights that go unused! The vast majority of consumers don’t want to modify a flashlight (although a significant number on BLF do, but not a majority in any stretch of the imagination) ( I don’t want or need to be bothered! Certainly not profitable!) (Emisar is barely mentioned on CPF as you know, which leaves Blf/Tlf - Asia/sensored)
1 x 18350 (because the 16340 suck) with 1 LED in neutral tint with good CRI and fair mix of spot/flood in a true small and compact EDC size, including a good clip & in the form like the Zebralight SC32 running latest Anduril (although the Zebra interface has its advantages of double modes and set placement, function & cc) would outsell the current Zebralights - Olights - Sofrin - Fenix HDS Oveready Boss - Surefire - Klarus - Convoy - TN - Astrolux - Armytek & etc currently on market given its proper due… Add upgrade or in some instances downgrade to 18650/21700 battery tube and it could be a game changer… Overly simplified for sure but something to think about, maybe! I say that because I can’t think of or find a light that hits the fit and function of a small cost effective EDC. Other than the Zebra (Olight doesn’t, can’t, wont…)
On the contrarian side of things the 18350/16340 is limited to flashlight enthusiast although so is BLF/CPF as well as in availability of the battery itself. The only other person in my city most likely that knows about the Emisar brand of lights is my brother that I encourage to buy. AA or 18650 makes more profit for the majority. Enthusiast vs the majority? ( For the muggle mode people old software is fine. For the Enthusiast market, people notice when TK offers updated software to the latest version at your fingertips and it doesn’t happen over a long period of time… Endless talk for the majority of sticking six pins or whatever into the board to upgrade equates to switching a dog from premium soft food to Old Roy hard cardboard!
Big powerful lights that can’t sustain the heat or brightness and sit on the shelf vs a usable very bright light that is small and versatile that fulfills a majority of needs… Where is the profit!
Is the Majority the target, who knows and that is the conundrum! As an enthusiast, which is the target market, I’d buy the 18350 with 1 LED with more than enough output given the outstanding versatility included in the user interface and I’d use it every day…
This light is making quite the impression. This thread is growing fast. What’s it been……30 hours or so.
Hank,
I’d really like an 18500 tube. May even leave a little body left to hold on to.
I have about 100 Efest 18500’s I need to do something with.
