What Legoes with What?
ughly! just because you can, doesn’t mean you should!
geneticists take note!
Remember, disappointment is to be expected when trying to “lego” parts — all you can do is report your own observations, but we know from experience that Chinese lights don’t have reliably consistent threading.
See What Legoes with What? - #9 by hank
Sofirn C01 legoes with the Maratac copper AAA :partying_face:
:smiley: :smiley: :smiley:
Would be nice to get the smaller ones to light up :stuck_out_tongue:
Button cells? That would be cool to see.
Hum, would it be possible? :open_mouth:
djoozzzzz, can you try it? :smiley: Just for fun :partying_face:
LOL, no chance, the driver boards are already touching each other.
:weary: Noooo fun then :person_facepalming:
:stuck_out_tongue:
Hmm… Any chance a DQG Hobi or Fairy tube would lego with those? If so, there is a short extension tube available for those from Banggood. It should be long enough to fit two button cells back-to-back with a divider in the middle, to light up both lights. There are actually two versions of the tube, one with a divider already and one that is just an open tube. I have both.
The Convoy S2 vs Convoy S2+ 18650 & 18350 tubes!
As posted on another thread, the Convoy S2 gray (bought from Simon) can be used with the black & desert tan 18650 tubes and the gray, black & desert tan 18350 tubes!
Also, the S2 gray tube can be used in the “short” Convoy S2+ (blueish gray) [no photo of that one, sorry].
lol
Fenix E01 also do not turn on:
these all work
and these
here is 18650 Eye15 and 18350 Eye10
The Skilhunt DS20 legoes with the (shorty) battery tube of the BLF-A6. The o-rings do not engage at all so the combination is not waterproof, but it works fine on a 18350.
Sofirn SF32(UV) legoes with Convoy S2+
BLF A6 legoes with Astroloux S41S
Sofirn C8T legoes with Convoy C8+
Jetbeam/Niteye RRT-01 to Jetbeam/Niteye TCR-1
Fire Flies E01 and E 07 are the same except for the head. All parts interchange, same tube same tailcap.
V10r Ti w AA extender from V11r
The Nitecore P12 tailcap fits perfectly onto the Nitecore P30. It makes it easier to use a lanyard without having to use the tactical ring on the P30, and it will tail stand. Tail standing is not perfect because the rubber boot on the P12 switch is a bit taller then the cap. However, It does work as you can see in the pic.
Would know if the New copper S2+ can Lego with others
Nope...completely different threads than any other S2
yes but myabe others brand with square threads can fit,would know wich
