Emisar D18 introduction
957 posts / 0 new
chouster
Nice light.
Not sure if driving 18x SST-20 on 1x AMC7135 is a good idea tho. They have a rated minimum current of 200 mA and they’d be driven at 20 mA…
BlueSwordM
BlueSwordM's picture
Last seen: 13 min 53 sec ago
Why?
That’s minimum rated current, not minimum working current.
At least, that means the 350mA mode will be super efficient.
AEDe
AEDe's picture
Last seen: 2 days 18 hours ago
BlueSwordM wrote:
Why?
At very low current (<100mA) efficiency become decrease.
Unfortunately no test at BLF has low current range.
Diomedes
Diomedes's picture
Last seen: 6 months 2 days ago
Pavlo wrote:
Hank Wang wrote:
I’m surprised to see that nobody asks about what optics the D18 use. Ok, I can not wait to tell you, that in order to maintain a smaller head, and as pocket-able as possible, we use 18 pcs single optics, and squeeze every tiny room in the head. Not a easy work for the assembly, the production speed is slow.!https://intl-outdoor.com/images/20190314214330.png!
Hank, will you supply different optic choices that people can buy independently to customize their beam profile?
Also out of curiosity, are these single TIR optics taller than your standard Carclo triple optics?
I love that you went the extra mile to condense the LEDs and minimize empty space.
I too am interested in what choice of optics there are. I’m not really familiar with this type of individual optic per emitter. One thing I like about the Meteor (and D4) is the availability of different optics to adjust the beam from a balance of throw and flood (e.g. the Carclo 10621 or 10622) to very floody (e.g. the Carclo 10623 or 10624). Are there similar options for the type of TIR optic that the D18 will use?
adam7027
Last seen: 1 day 1 hour ago
Hank,
Can I ask, what is the diameter of the individual optics?
Gerrit
Last seen: 45 min 9 sec ago
Hank Wang wrote:
hIKARInoob wrote:
Just awesome! Somehow I’m really curious whether this beauty also has a red “Noctigon pure copper board” in the tailcap…. because that is just soooo pretty. Big Smile
Almost the same structure!https://intl-outdoor.com/images/8.jpg!
I love passion combined with quality Thumbs Up
ToyKeeper
ToyKeeper's picture
Last seen: 10 hours 48 min ago
Apologies for the long post. Trying to answer some questions all at once…
nick779 wrote:
PS: This has a bit of a DBCustom vibe coming from it haha.
It really does. Dale makes some insanely bright lights, and when I turn this on at turbo, I get a taste of how Dale must feel. Even without optics, it’s very bright. It’s like turning on 15 to 20 60W equivalent light bulbs all at once. Normally I find even two of those bulbs to be excessive for an average room, but the D18 turns a room into something surreal like in a movie when they want to convey a holy aura or something.
komeko wrote:
And one more question. Will the LED system be aligned with the switch? I had this problem with M43 and I had to correct the alignment myself.
Probably. The MCPCB is screwed into the same piece of metal the switch is in.
Pavlo wrote:
Regarding length, seems similar to m43. Doesn’t the boost driver in the m43 occupy alot of space?
Yes, the boost driver components took up a fair amount of space. I don’t have my Meteor apart to compare, but I think the extra space has been converted into additional thermal mass to help deal with the crazy amount of power running through the D18.
nokoff wrote:
I understand there is no AUX LED at first, and some people do not want, but is there any plan to add it because personally I love the D4S AUX LEDs.
I’m not sure there is even anywhere to put aux LEDs. The front surface is packed with white LEDs and I haven’t seen the optics but it looks like there may not be any room for anything else.
Firelight2 wrote:
Best option is to get Anduril firmware so you can turn off the aux leds if desired.
This light has no aux LEDs, so the firmware is built without that option. However, RampingIOS V3 and Anduril have the same aux LED controls so it makes no difference which is used.
OTOH, lightning mode would be fun on such a bright light. Smile
Johm wrote:
Does it have candle and lightning storm modes?
Probably not, but I’m still trying to confirm that. I’m not sure if Hank is willing to change the UI significantly from previous Emisar products, but I made Anduril available just in case.
joechina wrote:
That doesn’t sound like Andúril. Is it RampingIOS v3 or RampingIOS v4? Smile
I don’t think Hank plans to use Anduril, even though I keep asking him about it. Smile He’s probably sick of it by now.
In any case, when I update things in Anduril, I also apply those updates to RampingIOS V3. So it has received several updates since the D4S was released. I’m not sure it will make a meaningful difference to anyone, but it has at least received bugfixes and some small UI tweaks.
Firelight2 wrote:
* XPG3 – cheap, but inferior to SST-20 in output, CRI and throw.
Also, XP-G3 makes an ugly rainbow beam. Sad
Yelov wrote:
It’s probably gonna drop the output really fast I assume, right? It seems pretty small for the output it has. My Q8 is bigger and has 1/3rd of the lumens of this light.
Yes, it won’t sustain 14,000 lumens for extended lengths of time. Something this size simply can’t soak up and shed 200W forever, because physics. The batteries can’t sustain it for a long time either, because it’s an awful lot of current coming from each cell. I’d estimate the maximum turbo runtime at about 10 minutes, with water cooling. But without cooling it’ll step down sooner to protect itself.
It’s a pretty well-tested setup which has worked fine on many lights for years. In this case, it ramps down to a moon mode of about 1.7 mA, which should provide a runtime of about 9 months per charge.
Mtonne wrote:
I feel like number of equivalent Q8s should be the new standard measurement.
Sometimes I use car headlights as a unit of measurement, because it’s something most people are familiar with at night and it works out to a nice round number.
The D18 is similar in brightness to 14 car headlights all pointed at the same place, except the beam should be more focused so it looks more intense.
It also has lower modes though, for the times when we don’t want to blind anyone. ~0.2 lm to ~14,000 lm, in a smooth progression of 150 levels. To select one, simply hold the button and then let go when it reaches the desired level of brightness.
komeko
komeko's picture
Last seen: 23 min 56 sec ago
M43 was also constructed in the same way and still crooked. I had to drill holes again and make new screw threads.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
junkyardbiker
Last seen: 1 day 10 hours ago
I am a dedicated Emisar fan so of course I will have this, unfortunate that a XPL-HI option would be so expensive though. I have a good many flashlights that are EDC appropriate but I do EDC my D4 with XPL emitters. I like Emisar products for the hotrod wow factor so the D18 with a emitter that is pure show off would be nice. Not worried about heat and output stepdown with a hotrod. I was also hoping that the next release from Hank would be a D1s with 26650 cell.
Lurking flashaholic, Ive bought all my flashlights through lurking here, BLF A6, Sofirn C8F, Soforn Q8, Emisar D4, and a few not so budget lights but I mod them all the same! Been waiting for the FW3A to come out for years now.......
Xeen
Xeen's picture
Looks nice, 14000 lumen really a lot. actually i dont going buy D18 because i have not needed for powerful flashlight with more than single cell. and i already have one soda can torch
you completely right.
Acebeam X80-GT, Zebralight SC600w plus, Olight H1 Nova nw, Skilhunt H03 nw, Nitecore Tini
PBWilson
Last seen: 1 hour 39 sec ago
I was disappointed when the D7 (or was it D8?) was scrapped. I’m very excited that Hank doubled it and then some! Really cool, especially in the 3×18650 smaller diameter.
hIKARInoob
hIKARInoob's picture
Last seen: 3 min 21 sec ago
Absolutely. One trauma resolved! And I’ve always preferred 3×18650 over 1×26650 as well. Cool
dotBLF
Last seen: 1 day 21 hours ago
Figgy wrote:
I would like a copper+titanium D4S 2.0 in 21700 battery instead of 26650 O_o next please
Don’t we all!
deathless
Last seen: 1 month 1 week ago
Do we sign up, or is this first come first serve?
JasonWW
JasonWW's picture
Last seen: 2 min 6 sec ago
Scallywag wrote:
Also, someone defend this against MT03 TA Devourer. I was planning to get one of those…
I’m only on page 3 so I don’t know if this has already been mentioned.
The MT03 has been known to have multiple issues. The locating pins in the tail cap breaking off, shorts in tail cap, the FET leaking and/or burning out. Also, not everyone likes the yellow corona of the 70.2. You kinda get used to it, but it’s probably ugly compared directly to this Emisar light. Keep in mind the MT03 is bigger and uses 4 18650. That can be good or bad depending on your preferences.
Click this to go to signature links.
SKY69
Last seen: 22 hours 5 min ago
Hank, thanks for creating and executing another fantastic light!
Hank Wang
Last seen: 1 hour 7 sec ago
Skylight wrote:
Maybe produce a 3× 18350 tube for 7cm length? Crazy Cash I really like this golden color! Cool
If there is enough interest in the 3*18350 tube, sure we can make it.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
chooma
Last seen: 11 hours 4 min ago
I’m interested in the 3*18350 tube.
twisted raven
Last seen: 57 min 47 sec ago
The light already seems a little too stubby as it is. You guys are weird. Silly
freeme
freeme's picture
Last seen: 37 min 17 sec ago
Same LED arrangement as Foursevens.
©freemex1thedeals.com
JasonWW
JasonWW's picture
Except TIR instead of reflectors. Plus way, way cheaper! Lol
Skylight
Skylight's picture
Last seen: 9 min 27 sec ago
A 3× 18350 tube would be great. Crown It would still output almost 10 000 lumens and be a huge advantage over the new MF01S. LOL I’m sure nobody would complain about an almost cube formed flashlight! Silly Wink
Ryzbor
Ryzbor's picture
Last seen: 1 hour 17 min ago
Thanks @BlueSwordM and SKV89, I would have wasted some money experimenting with the 3500K, my favourite CCT if not your clarification.
It appears the best way to achieve a true below-bbl high CRI light is by mixing two leds with 1000K difference which already are on or slightly below the BBL.
So I’ll most likely go for a 5D HI version or wait till someone sources truly rosy SST-20’s.
Another option is to mod the Meteor with 4 VR21SP4 MCPCB’s with a total of 12 mixed E21A’s in R9080+ and some 20mm Yajiamei TIR LED optics Evil
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
Klayking
Klayking's picture
Last seen: 1 week 1 day ago
Keep shortening it and we’ll reach a form factor that I think should be called “Tuna Can Flashlight”.
Now that I think about it, a really flat flashlight with a ton of LEDs on the front could be the next big thing for pocket rockets. Maybe a smartphone form factor with a wall of LEDs or even a big COB on one side and a slim Li-Po to power it… That’s a discussion for another thread though.
Pete7874
Pete7874's picture
Last seen: 3 min 58 sec ago
Yeah, like one of those hockey puck closet lights. Smile
JasonWW
JasonWW's picture
We already have this. Smart phone sized, full of 2 color leds. You can change the tint from 6500K to 3000K. Built in battery pack. They use it for filming. They can’t handle much brightness/heat, though.
No need to invent what already exists. Lol
SKV89
Last seen: 8 hours 27 min ago
The best 3500k I’ve seen is my Tiara Pro quad E21A with 2× 3000k and 2×4000k. It is a good bit below the bbl even at low output. At max output, because how far it is below the BBL, it actually looks alot whiter/neutral than it should be for standard 3500k that looks warmish/yellowish. Just looking at it by itself, it looks more like 4000k. Another good 3500k option is the Oslon Square 3500k 92CRI, which is spec’ed at 5Q tint bin, supposedly very far below the BBL. It does not look above BBL for sure, more like what I would expect from a 6Q tint bin. It looks just below the BBL and not far below like the E21A mixed 3500k.
Clemence is coming up with some new MCPCBs for the E21A that will allow more options for this emitter. One of the most interesting ones is the 16xE21A mcpcb that he mentioned about in his thread. That should allow the E21A to output a good bit above the XHP70.2 with 9080 goodness.
SKV89
Toykeeper, TA mentioned that there is an issue with active temperature regulation in Anduril for high output lights. Does RampIOS have ATR and does it have this problem fixed? I really hope it does especially considering the good heat shedding potential of this host.
Barkuti
Barkuti's picture
Last seen: 7 hours 16 min ago
Hank Wang wrote:
It uses a FET+13*7135+1*7135 driver
Bunker fuel flashlight LoL.
Big Smile
The Light Innocent I am
Firelight2
Firelight2's picture
Last seen: 6 hours 59 min ago
I’d love a shorty 18350 tube for this light! Love
