The first mcpcb, 3 inductor driver, had the proper wiring (6v).
The second mcpcb, 4 inductor driver (21v), you can cut the traces and add jumper wires to get or back to 6v. It’s extra work, but the darn glue on the bezel is the real problem. Lexel had to build wooden clamp jigs to get it apart. :confounded:
Yes, the ramp will end short of full turbo. This has proven to be the best setup over time for a few reasons. In this light an important one is how fast it heats up on full turbo. The top of the ramp noticeably improves the heat up time.
Far as how big the jump is, something around the last 10-15 steps sounds right. Visually it looks like what you would expect the next mode to be.
I just ask, if a 2S3P or 3S2P battery compartment were considered.
That would be only as thick, as a 1S3P compartment, just twice the length. That could be good for hand holding - but the flashlight body would lose the ‘soda can’ format.
Still, it would be a nice to have for longer runtime and less strain on batteries.
I mentioned several options along these lines but they were adamant that the basic form factor must remain the same as the first version. Not sure why.
That said there is nothing keeping future lights from being developed in other form factors. Although the triple 21700 format is not something I am itching to jump behind for a few reasons. Most were stated above, there are just not many advantages over a 4x 18650 setup and 18650’s are a lot more common. A triple setup is also a very odd voltage that is hard to use as well.
This is the light you were asking about? I thought it was a GT variant of some sort.
There is a known bug, but it doesn’t involve slowly getting up to 100C… it’s something else entirely. The known bug is about responding quickly enough to the initial peak, and has nothing to do with what happens later.
The bug has an optional workaround called a “hard turbo drop”. However, the D4S does not use this workaround. It works fine as-is without any bandaids.
The code also seems to work fine on the Emisar D18, which is extremely similar to the MF01S, so I don’t think the issue is due to the overall type of light.
I haven’t been able to reproduce the slowly-rising-to-100C bug locally, and it doesn’t show up on any reviewers’ published runtime tests for existing lights.
I don’t have all the details, but from the limited information available, it sounds like it’s probably one or more of the following:
Not calibrated or configured correctly. PID systems oscillate when they’re not tuned right.
There could be insufficient thermal transfer from the emitters to the MCU’s sensor. If it was only sensing heat from chips on the driver, and not from the emitters, it would be inclined to drop while it has extra voltage to burn off, and then increase power when battery voltage gets close to emitter Vf. This could be the case if the driver is burning off extra voltage and the MCU is insulated from the emitter heat but not insulated from the driver’s own excess-voltage heat.
There could be something else related to the driver itself. I don’t know much about the driver in this light.
There could be something else changed in the code to introduce new issues.
I asked Matemineco to fasten up the thermal response a lot this way, hope this will fix the firmware issue
a thermal Pad between MCU and copper cylinder
also clearly visible the LED shelf got thicker from the original MF01
If I understand correctly, most of the thermal transfer generally comes through the driver’s copper layers. This can happen through the LED wires and then through traces leading back to the MCU, and through the driver’s outer ring and the copper pours which lead back toward the MCU. Also from the regulator chips and their traces connecting to the MCU. Some heat can also come in through the MCU’s outer shell, but I get the impression it might be a relatively small factor. I haven’t found significantly different results when I place thermal transfer foam between the MCU and the emitter shelf, but I also only tried it once.
The behavior I heard about was a matter of oscillating gradually upward after the initial peak had passed. Oscillating is typically a sign of poorly-tuned PID, and I’m not sure what made it rise over time. I haven’t looked into it in detail because I’m not really involved in making this light and Mateminco hasn’t asked me to.
