[♛ FreemeGB] Niwalker Mini Max MM6S 6*XP-L HD 5500lm/ 6*219C 3500lm 21700 Flashlight - [Interest Check]
Does it has tail switch?
Yes.
Haha. I prefer to call it "a little hammer".
That's an ugly flashlight.
I actually like it. I like flat side by sides like the Shadow TC-750, MAXToch DX21. Tail switch lock out, side switch for modes, small enough to pocket. Only gripe is the high side switch.
If there is a high CRI variant of the light, I’m definitely interested.
Maybe 4000k SST-20s? Perfectly doable with 6 LEDs.
Looks very interesting indeed. Like the 21700, double switch, and 2 triples. Should run very efficiently. I wish it was 2 quad instead of 2 triples though. That way there would be more incentive for me to own this since I already have a bunch of E07 with 7 emitters.
Too thick for pocket or you afraid of accidental trigger?
I did make a request earlier. Hop it is not too late.
Dual quad might be too hot to handle.
I bet you cant guess why they dont show a picture with it face down.
I like it. As long as it doesn’t have a cold white tint with no blue or green in it, I would consider buying one. Price dependent of course.
I like this silver. Very beautiful flashlight. I will definitely buy it if there’ll be high CRI version.
+1. I will get a good price form them next month.
I am in for 1 of each color. Will look good next to Klarus X20.
If I am not wrong, there will be two variant. "Standard" and for cycling purpose.
put that thing in your pocket and when it finds its way over to your mid section have fun explaining how that shape is indeed the flashlight you’re claiming it to be!!
Then that means I will be buying 4 then?
Get one as try out first. You could always buy more later if it meets your expectations?
You see those six little switches around the main switch? They can be used to save and directly access any mode.
I like different, all the lights look boring and the same these days so this one will stand out and it won’t be any uglier than the guy using it (function over form) I think it will make a good work light or bike light.
I like that it will not roll, and will be able to find the button, unlike all these new lights that have the button on the side of a round tube that I always have trouble finding in the dark.
No way. :smiley:
