13489 posts / 0 new
cabfrank
Last seen: 7 hours 51 min ago
Agreed, I wouldn’t do it with this light.
charwinger21
Last seen: 2 weeks 1 day ago
djozz wrote:
It does make such a difference but more light is not always a good thing for a responsible manufacturer:
Often bypassing springs is done in flashlights with already high current/output in which case a bypass will add light in an inefficient region of the output curve of the led, so the bit of extra light comes with disproportional shorter runtime and lots of extra heat. This may be worth it for a flashoholic but in general it is a bad idea.
I mean, wouldn’t you pair the more efficient wiring with a lower output driver and/or scaled back regulation?
Yes, it might not play nice if you add it to something that is not designed for it, but if a responsible manufacturer is designing from the start with that more efficient path in mind, that would be part of their calculations.
djozz wrote:
If there is any light around in which bypassing springs could cause more trouble than is worth the extra light, it is the tiny FW3A.
Didn’t mean it necessarily in the context of this light specifically. The mention of it just reminded me of my curiosity about it in general.
djozz
djozz's picture
Last seen: 3 hours 54 min ago
Yes of course, that would be marvellous in case of that illusive 17mm one-sided slim buck/boost driver, but the plain reality is that many (most) single li-ion battery flashlights are driven by simple lineair drivers, so for a given current, regulated or not, over-voltage will simply be burnt off somewhere, if not in the springs then the driver will have to take care of that. In the special case of a unregulated FET-driver, which the FW3A is at its highest modes, the already very high current will just go further up.
JasonWW
JasonWW's picture
Last seen: 51 sec ago
charwinger21 wrote:
if it was actually such a major difference maker, wouldn’t it be more of a standard feature rather than something only seen in mods?
Part of the reason you don’t see it from the factory much is that it has to be done by hand, not by machine, so that adds time. It also has to be done properly which requires real technique. The average assembly worker has no time to learn nor does the company want to slow down the assembly line by doing it.
If not done properly, it can come loose and cause a short circuit and fry the battery. (Think of Haikelite MT09R bypass wires on the outside of the spring) So there are these legitimate safety concerns.
Add it all up and that’s why you don’t see it very often.
Double low resistance springs are something that is much better for a factory light and it seems it’s catching on. Especially as lights get brighter and currents get higher.
The FW3A is not meant to be a hot rod. It’s turbo is more “practical”.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
Pulsar
Pulsar's picture
Last seen: 1 week 1 day ago
Been gone a long time, has this been released? updates on the light?
teacher
teacher's picture
Last seen: 3 months 6 days ago
Not released yet…. should be soon. Updates in post #1.
cabfrank
I just checked my dictionary and couldn’t find the answer, what does soon mean again? Wink
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 19 min ago
“Valve time”
saypat
saypat's picture
Last seen: 16 min 14 sec ago
monsoon….
teacher
teacher's picture
I had a a slight feeling when I wrote that it would return to bite me in the arse…. FacepalmBig Smile
My definition of “soon” as it relates to the FW3A. ……
….. “It will happen within 2.25 months, which is 10% of the previous 22.5 months since the FW3A was Officially announced; 4 May 2017… the day of the OP.”
That’s my story & I’m sticking to it…. . Wink . Big Smile . Big Smile
soon /so͞on/adverb
  • 1. in or after a short time: “everyone will soon know the truth”
    synonyms: in a short time, shortly, presently, in the near future, before long, … more
  • 2. used to indicate one’s preference in a particular matter:
    “I’d just as soon Tim did it” , “I ‘hope’ it happens soon”.
mountainair26
mountainair26's picture
Last seen: 5 hours 34 min ago
Sign me up when its ready please
chinooker
chinooker's picture
Last seen: 41 min 38 sec ago
You can do that? Thumbs Up
cabfrank
I’ll take 2.25 months, sounds reasonable to me.
teacher
teacher's picture
Smile . Thumbs Up .. Me to at this point. It’s but a fraction of the total. If it really does happen in the 2.25 months that is…. Wink
cabfrank
I’m with you. It has been a long, long time. I’m counting on May, and keeping fingers crossed.
Bevo
Bevo's picture
Last seen: 4 months 6 days ago
I am #192…please put me down for 2 more (4 total).
Thanks!
Markymarcus
I’d like one, in LH351D.
mortuus
mortuus's picture
Last seen: 9 hours 9 min ago
please understand that it might be difficult it seems to get ahold of this type emitters for lumintop Sad they are looking at other options last time i heard anything..
...where Frugal meets with Flashlight!
Markymarcus
Oh really? Do you know what emitters would be among the options?
oweban
oweban's picture
Last seen: 1 hour 18 min ago
Currently the XPL-HI in 3D (roughly 5000K) and SST-20 4000K.
Markymarcus
Oh that’s great. I just got a d4 with the sst-20 4000k, and really enjoy it. Does anyone know why it is difficult to get ahold of the LH351D? Is it a demand issue? Just curious.
MascaratumB
MascaratumB's picture
Last seen: 8 hours 19 sec ago
I believe this is not entirely true!
As said here by Toykeeper :
ToyKeeper wrote:
[…]The supplier has been unable to get LH351D yet, so the first run is almost certainly going to be XP-L HI 3D only. After that, I’m not sure if it’ll be SST-20, LH351D, or other XP-L HI tints.
One thing is to talk about the emitter, another is to already have it as an option!
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
oweban
oweban's picture
Ah, I missed that one Sad oops!
MascaratumB
No problem, it is hard to keep track of all the relevant info after a while! Still, it is better to mention post #1 for the last updated information. Many things said in the middle are wishful thinking and our desires, what may be confuse. So, it is better to check post #1 or the posts from Toykeeper and tatasal that have been providing the last updates Beer
GIVEAWAY: 1
iamlucky13
Last seen: 3 hours 2 min ago
Quick related tip: If you click “Search within Thread” at the top of the page, you can enter a username to see posts in the thread by that person sorted by the most recent first.
Pwsmith
Last seen: 1 day 5 hours ago
If it’s not too late, I’d love to get one of these guys!
raccoon city
raccoon city's picture
Last seen: 14 hours 36 min ago
@Pwsmith:
You're not too late, but I don't know how long we all have to wait.  :THUMBS-UP:
tatasal
Last seen: 24 min 21 sec ago
As of this very moment, Lumintop is still waiting for the optics’ arrival so in the meantime, enjoy what you can enjoy from or with !! Beer
LargeDog
LargeDog's picture
Last seen: 6 months 2 hours ago
Oh crap, an actual update. Any very vague ETA on actual sales?
tatasal
Sorry, not even an ETA of the optics!
Any other talk is speculative, and I avoid speculations!
Again, Beer
