Agreed, I wouldn’t do it with this light.
I mean, wouldn’t you pair the more efficient wiring with a lower output driver and/or scaled back regulation?
Yes, it might not play nice if you add it to something that is not designed for it, but if a responsible manufacturer is designing from the start with that more efficient path in mind, that would be part of their calculations.
Didn’t mean it necessarily in the context of this light specifically. The mention of it just reminded me of my curiosity about it in general.
Yes of course, that would be marvellous in case of that illusive 17mm one-sided slim buck/boost driver, but the plain reality is that many (most) single li-ion battery flashlights are driven by simple lineair drivers, so for a given current, regulated or not, over-voltage will simply be burnt off somewhere, if not in the springs then the driver will have to take care of that. In the special case of a unregulated FET-driver, which the FW3A is at its highest modes, the already very high current will just go further up.
Part of the reason you don’t see it from the factory much is that it has to be done by hand, not by machine, so that adds time. It also has to be done properly which requires real technique. The average assembly worker has no time to learn nor does the company want to slow down the assembly line by doing it.
If not done properly, it can come loose and cause a short circuit and fry the battery. (Think of Haikelite MT09R bypass wires on the outside of the spring) So there are these legitimate safety concerns.
Add it all up and that’s why you don’t see it very often.
Double low resistance springs are something that is much better for a factory light and it seems it’s catching on. Especially as lights get brighter and currents get higher.
The FW3A is not meant to be a hot rod. It’s turbo is more “practical”.
Been gone a long time, has this been released? updates on the light?
Not released yet…. should be soon. Updates in post #1.
I just checked my dictionary and couldn’t find the answer, what does soon mean again?
“Valve time”
monsoon….
I had a a slight feeling when I wrote that it would return to bite me in the arse…. :person_facepalming: …
My definition of “soon” as it relates to the FW3A. ……
…… “It will happen within 2.25 months, which is 10% of the previous 22.5 months since the FW3A was Officially announced; 4 May 2017… the day of the OP.”
That’s my story & I’m sticking to it…. . . .
soon /so͞on/adverb
- 1. in or after a short time: “everyone will soon know the truth”
synonyms: in a short time, shortly, presently, in the near future, before long, … more - 2. used to indicate one’s preference in a particular matter:
“I’d just as soon Tim did it” , “I ’hope’ it happens soon”.
Sign me up when its ready please
You can do that? :+1:
I’ll take 2.25 months, sounds reasonable to me.
. :+1: … Me to at this point. It’s but a fraction of the total. If it really does happen in the 2.25 months that is….
I’m with you. It has been a long, long time. I’m counting on May, and keeping fingers crossed.
I am #192…please put me down for 2 more (4 total).
Thanks!
I’d like one, in LH351D.
please understand that it might be difficult it seems to get ahold of this type emitters for lumintop they are looking at other options last time i heard anything…
Oh really? Do you know what emitters would be among the options?
Currently the XPL-HI in 3D (roughly 5000K) and SST-20 4000K.
