I believe the copper heads are reserved for the titanium body for the first batch. If you guys would like to have copper with aluminium combi, do express your interest below. It is probably a good idea to state roughly how much more are you willing to pay for copper head option.
big heavy Cu head, tiny lightweight Ti body, can’t wait to hear the complaints about it…
Me, I want a complete recycled copper head, I mean ff is not Astrolux per se but it might be a $10 premium more or less normally, I don’t know, and more with a titanium body combo, but more importantly I want to know that he has fixed all of his other issues, there’s a whole list. He doesn’t respond to us but markets us special metals; it’s a bit of a conundrum.
My 219B version started acting weird. Click turn on and it blinks one to a high mode and dims to moonlight. If I try to ramp it up, it will also drop back down to moonlight. Sometimes clicking on the button have no effect at all. Cannot even turn it off.
Jacky responded in three days and said he will send me a new one. I will buy the copper one so he can send them together.
That’s what I used to think too but it’ll add significant weight for not much additional heat shedding. The majority of the heat shedding is done in the head so copper head makes good sense but body not that much. Also copper will sink heat so fast, it will make it uncomfortable for your hands to hold if the body is copper too. I’m not against full copper body but just copper head seems good enough.
Actually it does make a huge difference in turbo runtime. I compared S2+ copper with S2+ aluminum using same pill, the copper can maintain the turbo much longer, maybe twice as long but it also takes much longer to cool back down. Copper also helps with heat shedding since heat transfers to the surface faster but the difference it makes is probably not too significant.
Even though copper actually has a lower thermal mass per weight compared to aluminium, it’s so dense it actually eclipses aluminium in both thermal conductivity and mass.
I think heat conductivity works both ways, as it’s only one thing. It’s how fast the material transfers energy through it. The processes of heating and cooling down both involve energy transfer. But if we were talking two heatsinks of the exact same size, I could see the much heavier copper taking a little longer to fully cool down because it has much more mass to it, but that’s only if more energy was ran through it in the first place (ie 2 minutes of turbo vs 1 minute)
If we took copper and aluminum and allow both to absorb the heat from turbo for the same time, the higher thermal conductivity of copper means it should completely shed its heat faster than aluminum.
In that same manner though, if the copper were exposed to a level of heat that didn’t oversaturate it within seconds (turbo output), I would imagine it could allow the light to sustain a higher level of constant brightness than the aluminum heatsink.
