Interested
I’m pretty excited about this one, great grouping of features with the AUX LED and Anduril. I think the SST20 should manage to output a very postive runtime.
I’m not concerned that the MF01S isn’t the brightest or smallest soda can on the block. I already own an Acebeam X80 with 12x CREE XHP50.2,2x CREE XPE2-R2 630nm, 2x CREE XPE2-B4 475nm, 2x CREE XPE2-G3 530nm, 1x Nichia 233A 365nm. I’ve also got 4 ROT66 with SST-20, XPL-HI, and 219b emitter groups. IMO it’s really about features in this classification.
Interested.
interested!
Interested
i’m interested
Interested
I’m interested
Interested
Interested
I’m in depends on price.
Interested
Interested in XP-G3 model.
I am interested
Interested
Will you be able to turn the turbo timer off with the ui it has?
Anduril has no Turbo timer, goal is a thermal regulation or at least thermal step down
Yes, Narsil will have all the normal options to calibrate the thermal control as you desire or disable it completely.
I ran another test the other day with Anduril and it still overheated, so it is not looking like Anduril will be able to make it to production sadly. At this point there is nothing left for me to try to make it work.
Even if it was able to be tweaked into working most of the time I would not trust it until the root cause is fixed. There is some kind of bug that is allowing it to ramp the power up even when twice the set temperature when it should be locked to the lowest output mode. This means that unless the root issue is figured out, there is a high probability that a percentage of lights would still suffer from this. So I just can’t trust it for a production light until that is figured out.
I did add the flashing pogo-pins to the driver so re-flashing will be easy later when it is fixed or if you don’t care about the risks.
Hey TA/Freeme
Is there anyway to confirm if the opportunity suggested above could actually become a reality?
Colors … more colors … ALL THE COLORS! :smiling_imp: lol
Possible, yes.
Although the particulars are still very much TBD.
First we would need to show interest for a particular color or even custom LED ect. The issue would then be how to actually sell it. Banggood does not like dealing with a limited edition item, they want to sell it forever if they list it on their store.
There are a few options we are exploring but they are on the back burner until the light itself is finished.
