The first four of this eight-pack are off the charger, having gone through a break in cycle of something in excess of 38 hours. They terminated sometime during the night, so I’m not exactly sure how long they took.
Late last night before I went to bed they were in the final charge stage, and indicating a nice even 1.38 v.
The charger indicates: 1919 mAh, 1921, 1930, 1930. All terminated at 1.48 v.
The remaining four are on the charger now, also on break-in.
Considering that these cells lay new/dormant for almost 13 years, I wouldn’t have been the least surprised if they’d been deader than John Cleese’ parrot. That they show any life at all, let alone an honest ‘up-to-spec’ capacity is quite remarkable I think.
My first thought: sad you didn't check the capacity right from the package.. that would have been the oldest eneloop discharge test currently available....Or however I should phrase that.
Well, if you tell me how to do that, I have another identical unopened pack.
(I also have two unopened 2-packs of AAA with same date).
Edit: to say I have an even better idea.
P.M. me your mailing address and I’ll send these to you - we’ll just call it my sacrifice for science. . You run whatever tests you think will gain us the most information and share it with the board.
The last four pieces from that 8-pack finished their break in cycle overnight, and the results (read from the charger) were:
1914 mAh
1952
1941
1945
…three of them higher than the first four, with one notably lower.
I noticed one oddity that may be a function of my charger - the first four showed termination at 1.48 v , while these last four all showed 1.44 v when I fetched them off the charger. After 30 minutes all four showed 1.43 v on my DMM. I don’t know exactly how long each set remained on the charger after termination, or if the charger shows the voltage at termination, or ‘at the monent’.
(For those not familiar with the C-9000 charger, break in is a lengthy process of 40ish hours, and both sets terminated sometime during the second night.)
I wish I’d double checked the first four with the DMM after a half hour, but I didn’t.
ChibiM, if you’d like to run some more sophisticated analyses on these old cells, I have a couple of sealed packs remaining that I’d be pleased to send you at no cost.
I have Eneloop AA’s from 2008 that are still in use. They started out life in my camera flash units, taking a beating at weddings. They would come out of the flash unit too hot to hold after literally 700 or more flash photo’s. Nowadays they live an easier life in wireless Mouse units and small flashlights, but they still work fine.
AA Cycler has some very good long-duration cycle tests on Eneloops. Looks like they’re good for about 300-400 full cycles.
After that, internal resistance starts to sky-rocket very quickly. Capacity starts to drop as well, though more slowly. This is my personal anecdotal experience as well, so it’s good to see it’s backed up by real testing.
The conclusion seems to be that after a few hundred cycles, retire them to low-drain applications. If you do partial cycles, you’ll get a lot more out of them.
My personal experience is that they also start to lose their low-self-discharge ability as well, though they’ll still hold a charge for a few months. I have a few worn-out Eneloops that I still use in things like solar lawn lights.
With the advice of ChibiM, I opened another pack of eight, found that once again all eight tested exactly 1.27 v., and put the first four on ‘discharge’ mode right out of the pack.
After 150 minutes of discharge at 500 mA, the discharge stopped at 1.20 v.
Discharge readings were: 1146 mAh, 1153, 1138, and 1145.
After almost 13 years, these cells are still at roughly 60% capacity.
The last four are now being discharged in similar fashion.
Bravo! Thanks so much for the discharge test Tumbleweed48! Awesome numbers. And keep in mind that overseas cells didnt get charged 100% before shipping out but rather 70-75%.. So yeah, remarkable batteries! See how close those numbers are? Wow... any other brand would have been dead or mismatched numbers. I can't believe they were so close.
If you don't mind, I will add this info to the eneloop101 website.
