This is a great thread. I was afraid it was about removing unwanted hair so I was a little hesitant to open it. Don’t usually want to see before and after pictures of that sort.
You’d first need to de-anodize the light, or start with a bare light, like the BLF A6.
You’d then need to nickel plate the light, since the copper solutions we have access to, even copper sulfate, can’t make a good coat directly on aluminium. But nickel can.
We could then copper plate the light with a copper sulfate/copper chloride solution for highest plating durability and thickness. Copper acetate will work, but isn’t optimal due to the higher than optimal pH of the solution.
HOWEVER, it is doable, and I’m waiting for some pure nickel, and a BLF A6 non-anodized to test it out, since I’ve bought hydrochloric acid today to make a copper chloride solution.
Used to do a lot of electroplating at a previous shop, now we work with cadmium and Nitrided surfaces, some times beryllium copper coatings and even machining BeCu parts which means a tyvex suit and respirator. I see you advertise BeCu spring BlueSwordM so Im sure you are familier with the side effects from that nasty material. Been trying to get a de-anodized A6 to be Cadmium coated but no luck so far haha. Might be able to sneak it through on the Nitriding rack though one day.
Yeah. I will never sand a BeCu spring in my entire life unless I want to end up with lung cancer.
Have you tried a zincate solution? That’s the only thing blocking me from plating aluminium, since nitric acid is even more expensive, so I’m not going to touch it.
I’ve done copper acetate, and copper chloride. That last one is super easy to get a thick durable coating quickly at low power levels, but hard to get a thick coating(50um) over time since the cathode/part tends to get coated in a copper crystal rough formation.
Copper sulfate is the one I’m looking for, but since copper sulfate is super expensive here(30$ for 2lbs!), I’ve decided to get myself some sulfuric acid…
Until I found it was even harder to acquire clean sulfuric acid. Or stupid expensive shipping, especially for a small quantity.
I’m currently working on the process of making a galvanic cell with a fiberglass separator to make large quantities of concentrated 98% sulfuric acid. It’s going to be amazing, and cheap to make.
I might sell leftover fiberglass separators to see if there is any interest.
Yeah, but
As soon as you start producing batches of copper plate RRT-01, with Nichia upgrades and trits.
And plated Sofirn C01s w trits
people will be throwing money at you
Interesting reading guys, keep us updated! Sadly we can’t get acid and things like that over her without a license - I was going to try some anodising myself!
It would still be illegal - having it is the illegal bit, no matter how it’s made etc. This is down to the rise in acid attacks (I say rise, there were a handful, say 100 people out of 50 million) - the question is where does it end? bleach, nail polish remover……
In my opinion if you really that twisted that you wanted to really harm someone, you’d find a way - acid or not. Worse still, you can just make it as you are about to explain making the whole thing a nonsense anyway - but that’s Governments for you, powered by the media front pages.
What kind of policy is that? If Canada has no problem regarding this, how come the UK has problems with this?
I mean, you could just make 15% sulfuric acid without a “license”, or even just buy copper sulfate and make H2SO4 that way. And just boil it to make it more concentrated.
Also, what kind of store would sell PURE 93% sulfuric acid? Every drain cleaner that I’ve had my hands on contain inhibitors to prevent metal corrosion.
Did they actually ask any chemists how to make products safer?
So, guys, I finally managed to make sulfuric acid!
I managed to make 20% sulfuric acid using a galvanic cell setup, with the fiberglass separator.
In the 1st part, I managed to get 200mL of sulfuric acid, which was good, but not good enough.
In the 2nd part, I decided to up the voltage to 12V, and replaced the carbon electrodes.
The current initially was small, but got massive, and I only limited the current to 1A, which was way too high for a D sized battery carbon rod.
What happened was that the bottom part of the electrode got damaged first, soo, the alligator clip moved, which let go of the electrode, and into the bath.
I noticed it during the night since I heard a click, but I thought it was something else. I was expecting 200mL of 40-60% sulfuric acid. I only got 30% sulfuric acid.
Meaning, I got 400mL of 20% sulfuric acid at the end. Which was nice, but I’m planning to scale it up a bit so I can get myself some nice 90% sulfuric acid.
Finally, I had to separate the carbon from the solution using a filter made of the fiberglass. Here’s the final results, and my setup with hot glue
Also, do not spill sulfuric acid on your hands. It will make your hands super dry initially.
@jon_slider, I have some good news, and some very good news.
The good news is that I can easily make a flash copper solution if I have a solution of sodium hydroxide to dissolve copper ions in, meaning I could plate aluminium.
That also means I can make a zincate solution to actually plate aluminium with copper
The very good news are:
I can easily buy sodium hydroxide.
I can easily make a zincate solution just by dropping zinc in a sodium hydroxide solution.
I can easily remove anodizing by dropping the part in sodium hydroxide(lye).
That means the copper electroplating solution of aluminium flashlights is on the way
