BLF GT official support thread [FAQ updated 11 Jan 2018]
I received my GT in May. I have a couple of issues but just noticed one that is more critical (hardly used it yet):
1. Only one battery carrier works. I’ve been running 4 30Q’s and finally tried them in the other carrier. Doesn’t light.
2. Tail cap only spins with heavy force. I linked a fix to this somewhere when I was waiting for mine. I’ll dig that out.
3. I bought the lens cover with the package. Never received it. Moved a few months after getting the GT. Not sure where to turn anymore.
My big issue is the battery carrier. I’ll eventually get more batteries. Now that my attention is turned back to it I’d like to sort out the rest. Is there any kind soul that can provide some advice?
1. Are all the screws tight in the non-working carrier?
1.a. Are the batteries proper contact on the positive end??
2. O-ring is messed up/improperly installed. Disassemble tail cap & install properly
3. No idea
Check the voltage on the carrier. If all 4 batteries are making contact you’ll see 16+ volts. If you don’t see any volts, then maybe one of the batteries are not making contact.
Make sure the carrier is facing the correct direction.
The tail caps where the o-ring is pinched didn’t spin at all, IIRC. If yours spins, just put it in the correct position (in line with the other mount) and your good to go.
Otherwise you can take the sticker off and take the screws out to see what the problem is.
Did you buy the GT through Neal? If you added the cover, then he would usually fit it into the GT box with the light. I would contact Neal and let him know.
anyone know if the GT70 is glued?
This is the original GT thread. The GT70 thread is over here.
I have not heard of any GT70’s having glue added.
Hey guys
Who can I contact if I want to buy just the piece where the BLF GT label is printed on? I have a GT70 and don’t like that name, especially with the GT4 coming soon. I’d much rather replace the piece with one from a GT. Then my collection of GT mini < GT < GT4, makes sense :smiley:
You are talking about the light engine?
Sadly I don’t think that you can get this piece by itself but you could try contacting lumintop and see what they have on hand.
What font is used in the BLF GT logo? I am having a person’s name printed on the side and would like to use the same font.
The button led on my GT Micro is permanently off. How do I turn it back on?
This is the thread for the big GT light. The procedure is the same though. Here’s a video.
Thanks. Kind of tricky to get that timing just right.
Yeah, I’ve got a video that explains the blink system. https://youtu.be/xrwP3gG0I_A
You basically ignore the 2 fast blinks and then count the slower blinks. Then you only have about 2 seconds to do your first button press or else it moves on to the next setting. I recommend changing only one item at a time.
My BLF GT is not turning on.
I have tried to search these forums and also Google and Bing with no joy.
  • I purchased from original buy thread on these forums. Received around February 2018.
  • Batteries are fully charged
  • Button lights up and responds to presses properly (I think)
  • Going through the reset steps in the manual does seem to work as far as the flashes on the button are concerned but the LED just will not turn on.
  • Re-seated the end cap and head multiple times.
  • Battery Orientation is correct
  • Batteries are freshly charged and also close to brand new
  • Also tried different brand new batteries
  • NEVER dropped or physically mishandled
  • NEVER driven at full power for more than 2 to 3 minutes, typically 10-15 seconds at a time during dog walking.
Apologies if this has been addressed and I just suck at searching.
Thank you!
Hmm, sounds like either a wiring issue to the LED, a bad driver or a dead LED.
Can you see any black spots on the LED? or signs of damage?
You will need to remove the driver and see if there is any burn smell or signs of damage there. If not then next step is to test the LED, you can connect a 12v source (could use the carriers with some wire if needed) to the LED wires directly for a moment to see if it lights up. Only do it for a second since it will be driving it with too much power for extended use.
Also make sure polarity is correct, if put backwards it can fry the LED.
If the LED lights up directly then it is a driver issue, if the LED does not light up, then most likely a dead LED or possibly a short to the reflector. You will have to remove the head to do further testing.
Thanks for the prompt response
None. Yellow as can be. Clean, no signs of burn or other damage
No action :frowning: I used both a bench power supply and the actual battery pack. The pack is putting out about 16V as measured with a multimeter.
Now, how to disassemble or replace the LED? Any guides? Or is there a warranty/repair service?
Thanks again for the help
I think VOB had a video showing how to upgrade the GT to the GT70 but it could be applied to your situation as well.
Hardest part is opening the head, you need a strap wrench for that, after that it is a pretty basic LED swap.
Ah, oh well. I think I’ll sell it as is then :frowning: I haven’t used a soldering iron or similar in over 20 years LOL.
Thank you once again.
lol, up to you, it is really pretty simple to swap the LED, lots of writes and videos showing how as well.
Wow, when I Google your location, I can see exactly where you live!
I'm not brave enough to be so specific, but it is cool and different.
There are enough BLF members in your area who are willing to help you out.
