13184 posts / 0 new
cabfrank
Last seen: 1 hour 30 min ago
We are hoping it will be 2019. Some of us predicted even the first half of 2019. Honestly though, we have absolutely no idea. Things all have to come together, and they haven’t yet. There could be more delays. A lot of us have been following this for a very long time. All we can do is be patient, and as said previously in this thread by a wise and patient person, enjoy the lights we do have, while we wait.
tatasal
Last seen: 45 min 28 sec ago
Yes, I have said this I believe at least twice already lol!
Chances are, how many of us here have lights still in their boxes, just tested, some even unopened?
I even have untested brand-new chargers!
Again, enjoy what’s in your inventory…while we wait for the next Paypal.
Beer
saturdayturtle
Last seen: 1 month 2 days ago
Put me on the list for one!
electromage
electromage's picture
If SST-20 4000K 95 CRI is an option, that’s what I’d prefer!
CPF: electromage
Reddit: electromage
mortuus
mortuus's picture
Last seen: 1 hour 23 min ago
is it better in a triple optic vs the samsung then ?
...where Frugal meets with Flashlight!
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 57 min ago
Much higher throw, comparable to the XP-L HI, and much better red color rendition.
If you thought a R9050 emitter made everything look great, then an R9580 emitter is an absolute beauty outside.
trakcon
trakcon's picture
Last seen: 3 min 36 sec ago
Agreed!
mortuus
mortuus's picture
ok sounds like a good choice if the samsung cant be sourced.
trakcon
trakcon's picture
This may sound stupid, but what exactly do R9050 and R9580 refer to? I understand CRI, color temp, and tint binning, but I haven’t been able to find an explanation of these R values.
BlueSwordM
Basically, R means rating. Here are the numbers for say, an SST-20 95CRI.
R9580:
R95: CRI rating of 95 ran at 1A current.
R80: R9 rating of 80 minimum ran at 1A current. Basically how well reds are reproduced.
LEDs have quite a bit of trouble reproducing reds, so a high R9 rating(above 80), means it is guaranteed to reproduce reds very well.
djozz
djozz's picture
Last seen: 4 min 48 sec ago
It is specific naming of the Nichia company, R stands (I think) for rendering, 90 is minimal 90CRI, 50 is the R9 value (bright red rendering)
trakcon
trakcon's picture
That makes perfect sense. Thank you both! I knew about R9 values, but didn’t know this was simply shorthand for CRI+R9.
JasonWW
JasonWW's picture
Last seen: 1 hour 7 min ago
Each LED manufacturer has their own style of bin codes. We are used to Cree, at least I am, so these other companies bin codes are a bit Greek to me. Lol
electromage
Well I’m a little confused about this R* code as well, the SST-20 is made by Luminus, and it doesn’t appear anywhere on their datasheet. Luminus calls this the SST-20-W40H (W=White, 40=4000k, H=95 CRI).
Personally I prefer a warm balanced light with less of an emphasis on total output. I find that cooler beams, while brighter to a machine, are less useful to me when I need them. You notice this especially outdoors, around dirt and trees. With a typical 60-70 CRI light everything is washed out and I lose a sense of depth. Trees look almost 2-dimensional.
Obviously, if you’re going for “pocket rocket” lumen records I think you’ll want to stick with an XP-L or something, but you’re not going to get a lot of throw out of a m-up light anyway.
CPF: electromage
Reddit: electromage
Yokiamy
Yokiamy's picture
Last seen: 1 hour 54 min ago
Well, i am not impressed by SST20 , i just put one from KD in an A6 and had high hopes, since everybody seems to hype them, which made me think, let’s try one.
Now that i switched on the light with a fresh 30Q it was quite disappointing, i got hot very quick and the sheer output with the A6 driver and 20AWG seems to be lower then a stock S2+ SMO XPL Hi on 3A. (With the original thin wires…)
Maybe there is a better emitter available when the FW3A finally is available.
LouieAtienza
Yourrid wrote:
Do I really need to insert the Futurama meme of Fry screaming “TAKE MY MONEY” ???
You mean,
Me too, now that the end looks near, where do I sign up?!
BlueSwordM
Of course. It’s a 95CRI 4000k small die emitter compared to a larger 70CRI average XP-L HI.
Yourrid
Yourrid's picture
Last seen: 1 day 19 hours ago
LouieAtienza wrote:
You mean,
HAHAHAHA EXACTLY!
djozz
djozz's picture
@Yokiami, you must realise that the SST-20 has a XP-G size die, and the output is similar to a modern XP-G2 too, so it will throw quite well but it has not the output of leds with XM-size dies, like XP-L, SST-40, LH351D and Luxeon V.
Yokiamy
Yokiamy's picture
True, but t.b.h. i prefer a 219C which is the same size, if i compare the SST20 A6 (A6 driver with 20 AWG) vs a 219c S2+ (stock 2,8A driver).
I dont see why the SST20 is hyped that much.
trakcon
trakcon's picture
I’m very pleased with the SST-20’s in my D4 and D4S. I would love to have it in the FW3A with its higher regulated levels.
zak.wilson
Last seen: 8 hours 16 min ago
The 219C does not have the same emitter area as the SST-20. They’re in the same size package (as are the XP-L and the LH351D), but the actual area that emits light differs between these emitters. Smaller tends to be more throwy (candela per lumen) and to produce more absolute throw, but at a cost to output.
In terms of emitter area, LH351D > XP-L > 219C > SST-20.
Ceilingbounce – flashlight testing and runtime graphs for Android
vadimax
I hope you understand what are you asking for. Yes, SST-20 features very high CRI, but… it is obviously above BBL and produces green tint.
I am B2 color blind so this is not an issue to me, but my wife called it “cold green” whatever it means Smile
I use this light: https://skylumen.com/collections/v54-lights/products/eagletac-d25cvn-the... Spec 5 as a reference point.
teacher
teacher's picture
Last seen: 2 weeks 2 days ago
vadimax wrote:
(snip) ….but my wife called it “cold green” whatever it means Smile
To ‘me’, it means butt ugly. Thumbs Up
Please thank your wife for the description….. Beer .. Wink
trakcon
trakcon's picture
Well, I guess maybe I got lucky with the SST20’s I have.
Hikelite
I would want to join the list but I wonder if I should wait for the typical first batch mistake that often happens.
Tech25
Last seen: 7 hours 4 min ago
If you join now you probably will not be in the first (or second) batches.
Tad_LOL
Last seen: 2 days 15 hours ago
Hello, I’m new here. This light looks pretty awesome and I would like to get on the list for 1. I have fallen down the rabbit hole…
abbazaba
abbazaba's picture
Please add me to the list! Thank you!
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 4 hours 1 min ago
This is merely an interest list, it has nothing to do with the order lights will be received.
