Thanks for checking. As for the inconvenience: the 70CRI leds that I used have good output and a good tint so the flashlights that I built with them are still nice enough. But I really wanted the 80CRI, that is why I bought the leds.
Hi BanL,
Can you please give me some advice where to get this plasticine and white potting compound you use on this driver?
http://kaidomain.com/Flashlight-DIY-and-Tools/Circuit-Board-Driver-Board/S026841-KX70-32mm-4A-1-cell-6-Mode-Boost-Driver-Circuit-Board-with-Side-Switch-for-Cree-XHP70-6V
Is there any way to reach you besides of this thread? I have some technical questions concerning your H1-A and H2-C drivers (mostly about tweaking them with alternative resistors to run them with 12V LEDs like XHP35). I also sent you private messages before but did not get any response so far. I also started a new thread that I would like to invite you to: WTB: XHP35 20mm Boost Driver (improvements of Kaidomain H1-A)
It would be great if you were to help me as these tweaks might be beneficial for Kaidomain, selling a high performance XHP35 boost driver for flashlights like the brandnew Convoy S11 or Convoy L2 or your own KD-brand flashlights, of course.
Ban, did you check your current inventory of XHP35 Hi 4000K 80CRI? If these are indeed 80CRI, could I have a replacement of the two wrong 70CRI ones from last year?
No, Iām sorry. I never created an account on Kaidomain because it works fine to send the goods to my PayPal address. And it was still on the old site when I ordered them and your order conformation mail when the old site was still on, did not contain a summary of the ordered items, just an order nr and the amount of money. There is no way for me to know which of my 2018 orders were these leds.
So thereās no order nr coupled to the leds. Maybe it is in your administration? (Iām sure thereās just one Jos from Amsterdam )
I tested tint of the new batch of KDās 2700K SST-20 leds, claimed JA3, that came in today.
Kaidomainās previous batch was JC1, which should have been just above the BBL, I tested the tint here: KD (kaidomain): Deals and new products thread - #1222 by djozz , and, at ~400mA, from above and at 60 degrees the tint was under the BBL, just in the hotspot from a OP reflector it came very slightly above the BBL.
This evening I did the same tint test on the new claimed JA3, which should be under the BBL, and all three tints: straight above the led, at 60 degrees and in the hotspot of an OP reflector, measured almost exactly as the previous batch of claimed JC1 bin.
Also visually I can not tell the āJA3ā led tint apart from the āJC1ā tint.
This is an extremely nice led if you like 2700K light, nothing bad about that, but this is not good for trusting tint bins that are offered by Kaidomain, no matter where the problem is, at KD or at Luminus. Apparently everything must be checked, which costs money and time.
I bought 7 of these, if I had known that they were the same as the previous batch I would not have bought them, as I still have a few of the previous batch leftover.
