I have a solution! Run ~3A to each emitter and when you ramp up and down it turns on/off one emitter at a time from the inside out in a spiral pattern.
According to my theoretical calculations, every LED will get 2.6A in turbo. The whole will absorb about 160W. I have a question for Hank, is the weight given on the site with or without packaging, whether with or without batteries?
(think in the voice of USS Enterprise Chief Engineer Scotty), “I’ve got her patched together Captain and I’m giving er all she’s got but I don’t know how much longer she’ll hold together!”
A good tint mix would look awesome under a UV though…
1- is the $99 usd price a pre-order/early order price only?
2- if so, how long will you be running the $99 price for?
3- what will the regular price be once the $99 price changes?
I needs one but this is also new summer tires month…
If I was to order one it would be the khaki sand version. Not because I especially like the colour but more because black is too ubiquitous and having a different colour makes it feel more special and unique.
I have this message “Things don’t appear to be working at the moment. Please try again later. ” while redirecting to PP page .In other shops everything is OK.
Question for all regarding driver efficiency between the M43 and the D18.
Low VF leds excess voltage will burn off as heat in the D18 when running on 7135’s.
M43 will be more efficient in terms of how it takes advantage of the low Vf LEDs due to the boost driver.
Do you think the extra 6 LED’s in the D18 will offset the efficiency loss compared to the Boost driver of the Meteor?
