I would buy an 1800K E21A in a heartbeat, but I think the warmest CCT they come in is 2000K.
The Luminus Cube in 1800K 90 CRI is available on Mouser , but you need a board like this to fit the small footprint of the Cube. I have that board on order. At this point it’s the main thing I am waiting for. I plan to run two of the 1800K emitters in parallel at just over 1000 milliamps. I’m still a bit undecided on the optics, maybe an LEDil Boom-s? I think that and an 18350 tube might be in my future.
So both the outer pads become hot+ and the thermal isolation pad becomes negative-? I hadn’t thought of that! That looks like a better idea, more of those ultra-warm lumens, and a better fit for optics
Heck yeah I got it to work. I used the board from Clemence since that 3535 quad board technique that makes the center DTP pad the - ended up tripping up any driver UI I had installed. It’s amber toned, definitely. It makes my 2000K E21A look like a regular warm white household bulb even though it’s something very different. Almost feels like LPS/SOX levels of warmth, but with the color rendering turned on. This is when compared to my NBA LED. I might give the 2200K cube a shot next, but maybe use a different board. I’m currently feeding the two Cube emitters in parallel with a 1.4 amp driver.
Yes, those boards for the XQ-E should work. The Cube and the XQ-E have nearly identical footprints, essentially like a zero ohm SMD jumper almost. Pretty easy to get solder paste on and reflow because of no separate thermal pad in the middle.
Are those boards running those emitters in parallel? Do you have to address each emitter individually or can you run them all off of one set of positive and negative leads? The second board should fit in something like a Convoy M1/M2/S11, but would need an XP-E size centering ring for the optics to fit properly. You can still get by without the ring. The first board would work in any of those hosts, but would need a spacer for the compact TIR optics to fit. Those boards are unfortunately a little too big to squeeze into an S2+ shorty.
For a 12 volt light you would need 4 of the Luminus Cubes in series. That second board Talley-Ho linked, if that came in a 4 series setup, that could be a candidate for your host. You would need to make sure the width of the MCPCB would fit.
Manufacturer specificication sheets for forward drive voltage and compatible footprints. Website specifications for MCPCB size; footprint compatibility; and operation type, like 4 series, 2 series operation and so on. Confirming those two pieces of information match will give us our compatibility. Sometimes, we can bend the rules a bit and use something like a 3030 footprint LED on a 3535 footprint. That information is gained from experience.
I ended up using a Convoy S3, so I could easily play around with different optics.
thanks for the info. did a bunch of reading and I think i understand everything you wrote. did you ever stumble upon any other mcpcbs were compatible with the luminus cube?
I have modded a lantern with 2000K LEDs, its basically a “Kerosene lamp yellow flame on low” tint. A very, very warm yellowish glow, but i like it for night lights & moon light modes. I bought a lot of 2000K flame-yellow cheap LEDs from Ebay for that purpose, (the 1W Luxeon bead-type LEDs.
I don’t have this on hand and was wondering the same. The jumper pads seem to be made to run LEDs in series and there is none for another configuration so it probably needs 3x sets of positive and negative leads.
The other board I was looking at was this. Since the thermal pad is electrically isolated it might work with the quad setup technique mentioned above a bit better. I’ve worked with those MCPCB’s, and they are difficult to solder. You would need a hot iron to get it to work.
This would be a better candidate, however. You would need to make sure its 20mm diameter fits in the light you want. It is configurable for 12 volt or 4 series operation, so it should electrically work in the light you mentioned earlier, but I don’t know if the diameter would fit. That is where you would need to measure the board that is in there already.
How could 6000K have high CRI, wouldn’t that be too blue, and not render reds/oranges accurately? Chromatic adaptation is the mechanism that in the human eye that corrects for CCT/SPD differences.
