13626 posts / 0 new
mortuus
mortuus's picture
Last seen: 51 min 32 sec ago
BlueSwordM wrote:
Much higher throw, comparable to the XP-L HI, and much better red color rendition.
If you thought a R9050 emitter made everything look great, then an R9580 emitter is an absolute beauty outside.
ok sounds like a good choice if the samsung cant be sourced.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
trakcon
trakcon's picture
Last seen: 1 hour 33 min ago
This may sound stupid, but what exactly do R9050 and R9580 refer to? I understand CRI, color temp, and tint binning, but I haven’t been able to find an explanation of these R values.
BlueSwordM
BlueSwordM's picture
Last seen: 4 days 2 hours ago
Basically, R means rating. Here are the numbers for say, an SST-20 95CRI.
R9580:
R95: CRI rating of 95 ran at 1A current.
R80: R9 rating of 80 minimum ran at 1A current. Basically how well reds are reproduced.
LEDs have quite a bit of trouble reproducing reds, so a high R9 rating(above 80), means it is guaranteed to reproduce reds very well.
djozz
djozz's picture
Last seen: 4 hours 14 min ago
It is specific naming of the Nichia company, R stands (I think) for rendering, 90 is minimal 90CRI, 50 is the R9 value (bright red rendering)
trakcon
trakcon's picture
That makes perfect sense. Thank you both! I knew about R9 values, but didn’t know this was simply shorthand for CRI+R9.
JasonWW
JasonWW's picture
Last seen: 8 hours 23 min ago
Each LED manufacturer has their own style of bin codes. We are used to Cree, at least I am, so these other companies bin codes are a bit Greek to me. Lol
electromage
electromage's picture
Last seen: 6 months 3 weeks ago
Well I’m a little confused about this R* code as well, the SST-20 is made by Luminus, and it doesn’t appear anywhere on their datasheet. Luminus calls this the SST-20-W40H (W=White, 40=4000k, H=95 CRI).
Personally I prefer a warm balanced light with less of an emphasis on total output. I find that cooler beams, while brighter to a machine, are less useful to me when I need them. You notice this especially outdoors, around dirt and trees. With a typical 60-70 CRI light everything is washed out and I lose a sense of depth. Trees look almost 2-dimensional.
Obviously, if you’re going for “pocket rocket” lumen records I think you’ll want to stick with an XP-L or something, but you’re not going to get a lot of throw out of a m-up light anyway.
CPF: electromage
Reddit: electromage
Yokiamy
Yokiamy's picture
Last seen: 2 hours 43 min ago
Well, i am not impressed by SST20 , i just put one from KD in an A6 and had high hopes, since everybody seems to hype them, which made me think, let’s try one.
Now that i switched on the light with a fresh 30Q it was quite disappointing, i got hot very quick and the sheer output with the A6 driver and 20AWG seems to be lower then a stock S2+ SMO XPL Hi on 3A. (With the original thin wires…)
Maybe there is a better emitter available when the FW3A finally is available.
LouieAtienza
Last seen: 1 year 4 months ago
Yourrid wrote:
Do I really need to insert the Futurama meme of Fry screaming “TAKE MY MONEY” ???
You mean,
Me too, now that the end looks near, where do I sign up?!
BlueSwordM
Of course. It’s a 95CRI 4000k small die emitter compared to a larger 70CRI average XP-L HI.
Yourrid
Yourrid's picture
Last seen: 1 week 2 days ago
LouieAtienza wrote:
You mean,
HAHAHAHA EXACTLY!
djozz
djozz's picture
@Yokiami, you must realise that the SST-20 has a XP-G size die, and the output is similar to a modern XP-G2 too, so it will throw quite well but it has not the output of leds with XM-size dies, like XP-L, SST-40, LH351D and Luxeon V.
Yokiamy
Yokiamy's picture
True, but t.b.h. i prefer a 219C which is the same size, if i compare the SST20 A6 (A6 driver with 20 AWG) vs a 219c S2+ (stock 2,8A driver).
I dont see why the SST20 is hyped that much.
trakcon
trakcon's picture
I’m very pleased with the SST-20’s in my D4 and D4S. I would love to have it in the FW3A with its higher regulated levels.
zak.wilson
Last seen: 1 day 13 hours ago
The 219C does not have the same emitter area as the SST-20. They’re in the same size package (as are the XP-L and the LH351D), but the actual area that emits light differs between these emitters. Smaller tends to be more throwy (candela per lumen) and to produce more absolute throw, but at a cost to output.
In terms of emitter area, LH351D > XP-L > 219C > SST-20.
Ceilingbounce – flashlight testing and runtime graphs for Android
vadimax
I hope you understand what are you asking for. Yes, SST-20 features very high CRI, but… it is obviously above BBL and produces green tint.
I am B2 color blind so this is not an issue to me, but my wife called it “cold green” whatever it means Smile
I use this light: https://skylumen.com/collections/v54-lights/products/eagletac-d25cvn-the... Spec 5 as a reference point.
teacher
teacher's picture
Last seen: 1 year 1 month ago
vadimax wrote:
(snip) ….but my wife called it “cold green” whatever it means Smile
To ‘me’, it means butt ugly. Thumbs Up
Please thank your wife for the description….. Beer .. Wink
trakcon
trakcon's picture
Well, I guess maybe I got lucky with the SST20’s I have.
Hikelite
Last seen: 2 days 9 hours ago
I would want to join the list but I wonder if I should wait for the typical first batch mistake that often happens.
Tech25
Last seen: 2 weeks 4 days ago
If you join now you probably will not be in the first (or second) batches.
Tad_LOL
Last seen: 8 months 3 weeks ago
Hello, I’m new here. This light looks pretty awesome and I would like to get on the list for 1. I have fallen down the rabbit hole…
abbazaba
abbazaba's picture
Please add me to the list! Thank you!
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 min 39 sec ago
This is merely an interest list, it has nothing to do with the order lights will be received.
RobertB
RobertB's picture
Last seen: 5 hours 2 min ago
What makes you say that? In the past, the order in which pm’s were sent directly related to the order of the interest list. Like the GT, Q8, X5 & X6, etc… Maybe you’re right, and it will be a free for all order frenzy this time.
BurningPlayd0h
Order codes are received != order shipments are sent
Take the PL47 GB for example:
-Discount codes were sent in order based on interest list
-All emitter/color options were available for purchase right away IIRC
But then there were requests for no glue and magnets and that delayed some orders, I think some colors were shipped out later than others (waiting time estimates was listed on the product page too I believe), it seemed emitter types were sent out in batches, etc.
With the likelihood that not all emitter options will be available off the bat being far down the list certainly doesn’t mean you will necessarily have to wait much longer than others to receive your FW3A once order open up. Depends on whether the lights are built before or after the light is up for purchase and just how many/what versions are produced.
MtnDon
MtnDon's picture
Last seen: 2 hours 57 min ago
Perhaps it would be a good time now for the “people running the show” to explain how the actual ordering will be handled, including differences in emitters?
RobertB
RobertB's picture
Was just saying how BLF projects were handled in the past.
Firelight2
Firelight2's picture
Last seen: 23 min 31 sec ago
I see no reason why the FW3A should be handled any differently than prior BLF projects.
In my opinion, PMs with ordering info certainly should be sent in order on the interest list. Someone who first expressed interest 2 years ago should have priority over someone who first expressed interest a week ago.
MtnDon
MtnDon's picture
As #36 on the list here at BLF, I would agree wholeheartedly with that. Smile
Is it of any consequence that the interest list does not show what emitter we are interested in? I have no recollection what emitter was planned on back in the original post.
BurningPlayd0h
I don’t think there’s any hard factors delineating a “BLF” group buy from any others here other than that some BLF members are involved in the process to some extent. You’re making a fair point but most of the logisitics seem to be handled by Neal and Lumintop without much active engagement with BLF (not a bad thing, just how it seems to be going).
I was fairly sure I saw TK or someone else involved say something about how the interest list wasn’t a strict order of who would get their shot at ordering first but I can’t find it so I might just be dumb.
The emitter poll ended up with 5000K XPL HI and 4000K LH351D coming out on top but whether they can get a decent bin of 351Ds is up in the air AFAIK.
