There is a box right besides the second line, just put 100 in it. THAT’S IT. Nothing more is required from you. Little naked elves will squeeze the picture to size.
How do you adjust the size when you have already inserted the picture using the simple post editor? I always forget, I know you insert something before the URL of the image
For example, to attach an image you use in simple post editor
Insert another picture with the “100” in the second line. Save it……you will see a small insert in front of the picture link. Not it’s position INSIDE the exclamation mark.
YES! Setting the display size maximum does not help with the file size. If the linked image is a huge file the entire file stiul has to download while the forum software then resizes the display size.
Changing the image size % on the forum does absolutely nothing to file size.
It only changes how big the image appears.
The full resolution image gets loaded regardless, whether you make it 1000% or 1% scaling.
Yep, you need to reduce your images before inserting them in BLF, the BLF editor will do nothing about the size, if your picture was full res. it will load the full res., it will just display it differently. For example, look at this cute little pic , then right-click it and open in a new window :
