I was thinking about the Battle Lantern more this morning and I definitely think these Lenina reflectors and a Vero29 are the solution. Since LEDiL makes lenses for these that snap onto the front of the reflector, it allows me to make a much more compact stackup and the smaller OD gives me more face area for surface area increasing features to improve thermals. The shorter depth also gives me a shorter thermal path to the front.
So, I guess I need to order a Vero29. I’m also thinking that since this light will be thermally constrained, I might as well go for a high CRI part as there really isn’t a huge difference in lumens when under-driving them.
For the lumen bazooka, I’m still looking into designing my own driver and I’ve found a few chips that I think are up to the task of pushing a 72v Vero29 to full output.
LEDiL has a different base for Lena/Lenina reflectors… C15083 which is for Vero29 AND Vero29se! It is also much more compact than the giant C13867 which only works with Vero29.
If you design one I’d be willing to buy a few from you LOLOL.
I set up my Vero29 with my 6s2p battery config, and was able to reach 69.9V @ 2.4A. Way brighter than the previous setup. Glad I got the IceLED cooler because this thing does run a bit hotter.
Yeah, trying to keep something dumping ~200w cool will not be all that easy. I was playing around in CAD with using 3 cheap heatpipe tower coolers in a triangle with a single fan pulling air in the center since I know that once airflow goes above, ~5mph, there isn’t much additional cooling to be had. So, you’re better off adding more surface area and heatpipes if you have room.
Yes… That’s why i increased the depth of the pocket, so i can mount the housing directly to the adapter plate I made. Preliminary tests say it’s enough but that’s just by touch lolol. That said I’m not sure I believe IceLEDs claims of this suppirting up to 400W LEDs. Becausr if it can I might have to use it on my CPU lolol.
Likely… but since I have it running at 168W, I think it should be fine. Having a 1/4” aluminum plate and the housing (which has to weigh about 3 pounds) should help a lot. Maybe once I get my rotary axis up and running I’ll make a new heatsink housing. But for now, this is fast and effective.
I do have another solution but saving that for my CFT-90 project…
Well, no new CAD models from LEDiL despite e-mailing them this morning. I suppose I could just measure some key dimensions on the Leninas I have and make some progress with that…
Allegedly, my L6 will be delivered tomorrow so I guess I might waste some time disassembling that and figuring out what sort of stupid I can do with it.
Got the Vero29 to max at 70.5V @ 2.43A… If I’m reading the current vs. luminous flux charts right I should be right around 25K lumens… Will try to take some outdoor shots this weekend.
Did another test with just one 5200 mAh 3S LiPo. Still achieved 66.6V(!) @ 1A. According to Bridgelux’s charts that should produce around 10k lumens!
So now I know this works, I’ll get a cheapie 250W CV/CC boost converter to run it. This 900W one is a bit big. The IceLED heatsink just so happens to fit in 4” PVC pipe so making a housing should be pretty easy. It does end up weighing a bit more but I don’t think that’s too much a concern for its intended uses. Already have ideas for making vehicle mounting and powering, that would still be easily removed for handheld or tripod use.
As to dimming… I’ve mulled over this for a while. Really not much of anything I could find in the 60-72VDC range. Then after looking through my miscellaneous parts I find these DC motor speed controllers - basically a variable current drive. I hooked it up to the output of the boost converter, and voila! Dimming! Only thing is that this adds considerable bulk.
So I’m back to the TaskLED HyperBoost. Since they recommend a max 7A input current, I should be able to use 6 18650s easily, but I thought I read documentation that the max amount of cells in series that can be used is 5? I know VoB used 8 in the GT mod; I don’t know enough to know why that limitation exists…
I’d like to use battery holders because I have them, and it would seem easier for me to pop them out and throw them in my charger. The holders I have are the ones that the cells snap in, with metal tabs not springs. My thoughts were to mount the holders 4 a side on a custom milled circuit board, then just have something like an XT60 connector at one end to plug into.
Would like to just buy a 10S LiPo but then I’d have to buy a charger as well as my charger will only do 2S or 3S.
