Yeah tritium vials are great if you can incorporate them. Just one at the switch is enough really, but there are some crazy tricked up lights out there, no need to turn on for moonlight…
They seem expensive at the time but last for a good few years at an acceptable output level. Green for lights, red for blades.
Gorgeous! I’m jealous. I’ve got an early NovaTac 120P that I’ve kept as a bedside light for some time now (it has a Peu bezel with trits), and would love to convert it to a 219 Nichia triple… but I can’t get myself over the investment required, when it would easily fund something like a Zebralight SC64c LE or Jetbeam RRT-01. Maybe I’ll change my mind when I finally get free of financial stress.
I hear you about HDS. They do make a great quality light, but the price... At this point, they're just periodically upgrading emitters. Everything else remains the same. So R&D costs have long been recouped. They're just cash-cowing it. Same thing for Oveready. I think there's a portion of the flashlight community that is loaded with disposable income, helping to keep such enterprises going.
I agree, some of them are so seriously impressive to behold in dim light or darkness. But over $100 in trits… seems like such a waste. They will remain reasonably bright up to about 10 years then the fading is more noticeable next to fresh tritium. That’s not bad. But the unspoken problem is fragility. You really need to be careful about seating them deeply enough. I discovered one day that one of the trits on my NovaTac 120P went dark. Sure enough, the vial had been compromised. When I looked at it up close with magnification, I could see it had cracked. Even though the vials should be protected with sufficient optical adhesive, there is the matter of “settling”… I have to wonder if in many cases, the vials lay precariously close to the metal of the flashlight and just the right amount of force from a 3’ drop could induce enough shock to crack tritium vials.
don;t forget these
—i THINK they can use 16340—
super cheap small cr123a lights on aliexpress
these things are super cheap, small and have 3 modes
$2.74 w free shipping – on aliexpress
twisty, super small, somewhat waterproof, light color is cool but not too bad
low mode uses PWM, but it isnt; ridiculous
no mode memory, starts on high
beam pattern is nice, hot spot then some spill – lensing is via cone reflector
i have no monetary interest
link is not ‘affiliate’
i just love these things
These days, might as well go 18350. Just a tad larger but greater mAh. But for standard (non-rechargeable) cells, can’t beat 16340 CR123A for shelf life.
actually, the ones with long shelf life are not 16340 (rechargeable) but CR123A - (not rechargeable but ’’lithium primaries”), available at any drug store or walmart
they will last 15 years sometimes, shelf life i mean
usually they are rated at least 10
3.3v max instead of 4.2 though
xtar lights could handle either
if, on installing a new cell, if it detected over 4V , it would assume rechargeable, and cut off when volts got down to 3.0
if it detected 3.2V, it would assume not rechargeable, and let the cell go down to 0V.
